AAL or full leaf pack?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dr. Emmett Brown, Dec 24, 2018.
Rear lift setup?
  1. Single AAL (suggest brand please)
    8 vote(s)
    9.3%
  2. 3 Leaf AAL (suggest brand please)
    18 vote(s)
    20.9%
  3. Dakar Medium Duty
    32 vote(s)
    37.2%
  4. Dakar Heavy Duty
    28 vote(s)
    32.6%
  1. Dec 24, 2018 at 4:21 PM
    #61
    Dr. Emmett Brown
    Dr. Emmett Brown [OP] Well-Known Member
    Mother of God, the bed mat is 30+ pounds!? Had no idea.
    What are you running in the front? I live in Hawaii where we spend our tax money on the homeless more than repaving some of the countries worst roads, so I know it's a truck but a nice ride would be nice. Lol
  2. Dec 24, 2018 at 4:27 PM
    #62
    jholc21
    jholc21 Well-Known Member
    Colorado
    2017 White Tacoma TRD OR
    Bilstein 6112/5160 w/Dakars Leafs 255/80/R17 Cooper ST MAXX Skinnies 4.88 Gears TRD Pro Fog Lights Cali Raised 5D Combo Leather Seats LED Bed Lighting ARE Overland Shell
    yep - all those little things add up and next thing you know your truck weighs as much as a full size. Front is Bilstein 6112 at 4/5 setting and rear is 5160 shocks.
  3. Dec 24, 2018 at 5:25 PM
    #63
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    I think the HD and Medium Dakars use the same pin. I was able to run an AAL and shim with the standard duty spring pack center pin.
  4. Dec 24, 2018 at 5:33 PM
    #64
    Dr. Emmett Brown
    Oh wow, okay so I should be fine on the heavy duty's center pin especially if a leaf is removed. Did you buy the shim as a precautionary measure or you found out you had vibes and ordered later?
  5. Dec 24, 2018 at 6:03 PM
    #65
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    get this shim
  6. Dec 24, 2018 at 6:08 PM
    #66
    Nixinus
    Oregon
    2010 4x4
    The shim I got came with the kit and I installed it with the leaf pack. I haven't had any vibes. The center pin is now flush with the nut, so its about maxed out but it tightened down fine.
  7. Dec 24, 2018 at 6:09 PM
    #67
    Dr. Emmett Brown
    Nice. This is exactly what I was looking at. Are Leaf spring center pins like rear axle u-bolts in the sense that it is recommended not to retorque them?
  8. Dec 24, 2018 at 9:12 PM
    #68
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    I have the bed mat, factory tonneau, some recovery gear, tools and my sliders. I'd guess a little less than 200 lbs over stock. The medium Dakar pack has settled to just 1" of rear lift with a full tank of gas.
    The people reporting significant lift from the medium are either carrying no weight over stock or they are measuring too soon after installation. Mine sank about a half inch overnight the day I bolted them on and almost a full inch over the next several weeks.
    I'm happy with my setup and don't have any driveline vibrations but with your front lift and load plans I think you need the HD pack.
    Nixinus and gotblika like this.
  9. Dec 25, 2018 at 8:09 PM
    #69
    Dr. Emmett Brown
    Will 5125s that have 15 collapsed length and 24.38 be good for the Dakars after I take out a leaf? Eventually I'll grab some performance shocks all around but for now it seems like 5100 front and 5125 should work right?
  10. Dec 25, 2018 at 8:37 PM
    #70
    gotblika
    Maui
    2015 DCLB Sport 4X4
    OME Shock Specifications:
    - Collapsed: 14.173"
    - Extended: 23.583"
    - Travel: 9.41"
    These are the Nitro Charger shocks that were designed to run with the Dakar pack but they have a conservative extended length so they will limit the droop. No brake line or bump modifications needed.
    The 5125 are a little longer so you may need brake lines and bumps, also they are a universal shock, not valved to the tacoma.
  11. Dec 25, 2018 at 8:48 PM
    #71
    Dr. Emmett Brown
    I've been looking at those too but thought it would be weird to have Bilstein up front and OME in the rear. Would that be okay?
  12. Dec 25, 2018 at 8:54 PM
    #72
    gotblika
    Maui
    2015 DCLB Sport 4X4
    IDK.. if you plan on replacing them with performance shocks I'd check whatevers cheapest, 5100 probably.
  13. Dec 25, 2018 at 8:56 PM
    #73
    Dr. Emmett Brown
    I've got rear 5100s right now. The 5125s are he same price as the 5100s but accommodate a higher rear lift. I didn't feel very comfortable putting the dakars on with my 5100s unless they will be okay
  14. Dec 26, 2018 at 8:44 AM
    #74
    gotblika
    Maui
    2015 DCLB Sport 4X4
    how long till you to get performance shocks?
  15. Dec 26, 2018 at 11:20 AM
    #75
    Dr. Emmett Brown
    Maybe another year just to see how I like my spring setup. Thinking about going the Bilstein 8112/8110 combo route in 2020
  16. Dec 26, 2018 at 11:43 AM
    #76
    gotblika
    Maui
    2015 DCLB Sport 4X4
    if you gonna buy something now just get the B110 with brake lines, u-bolt flip and bumps of your choice. You'll need those anyways.
  17. Dec 26, 2018 at 12:25 PM
    #77
    Dr. Emmett Brown
    Are those better than the 5125s? I understand the 5100s are valves for the Tacoma but would that be too much extension?
  18. Dec 26, 2018 at 3:16 PM
    #78
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Run the leaf liners the entire length + a half inch extra on each end (to allow for the leaf to flex etc) keep the anti friction pads in, put a good dollop of grease all over the anti friction pads when assembling. My whole rear suspension is SO smooth and doesnt make a damn sound. FYI the two overload leafs, do not get a leaf liner as its not necessary.
    I run 2* shims (but fat end forward to till the pinion down) as that worked the best for my truck. I would skip shims for now. If you get the heavy pack your center pin for the leafs will be plenty long especially if you pull out the 3rd leaf to make it a medium pack. Also, you can go with vibes for however long you want.... i still have a few vibes around 5-10mph but they arent bad an are MUCH better than any combo i have had before on the truck.
  19. Dec 26, 2018 at 3:19 PM
    #79
    nd4spdbh
    SoCal
    Best thing to do would be to get the leaf pack in with even the stock shocks, get driveline angles sorted to minimize vibes if they are present, get whatever bumpstop setup you wanna go with. then go flex the truck and measure the compressed shock length. This number is the absolute maximum compressed length you can go (i always error with at least 1/2in smaller in compressed length if not 3/4in)... once you have that measurement then buy shocks that fit at or under that compressed shock length. Last thing you want is a shock bottoming before full bumpstop compression.
    EDIT- after doing some measureing the other day on my truck ill probably be running the proper specd 5125's with my medium packs and the stock bumpstops as the b110 5100s are likely too long of a compressed length.
  20. Dec 26, 2018 at 4:14 PM
    #80
    Dr. Emmett Brown
    I really appreciate the response, man. I'm definitely gunna do all the recommended leaf liners, grease and prep work to the springs hat you guys are talking about. All the trucks I've worked on in the past have had vibes after lifts/drops so I'm pretty comfortable with vibes and I know they will wear things out faster than normal but it's good to hear that it isn't the end of the world.
    I'm running 5100s in the rear and I've flexed my suspension pretty good when I had 2" blocks and the shocks seemed to handle the articulation fine on the 5100s so maybe I don't need new shocks just yet. I always bring my stock rear shocks and my tools with me whenever I go off-roading just in case I blow a shock I can at least get home on the stocks.
