AAL problems continue...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by matt45648, Apr 27, 2009.
  1. Apr 27, 2009 at 3:34 PM
    matt45648
    matt45648 [OP] Well-Known Member
    So after installing the toytec AAL's my truck sits 1" lower on the drivers side. I checked to make sure I have the correct tsb spring combo and it is. Contacted toytec and they have no idea how to correct this. So Im stuck with a lopsided truck!
  2. Apr 27, 2009 at 3:36 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you maybe able to add one of your stock springs into the pack to make up for the weight on the driver side. worth a shot anyway.
  3. Apr 27, 2009 at 3:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Did you try and swap sides with the spring? Are the TSB springs on the correct side?
  4. Apr 27, 2009 at 3:39 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Looks like a great reason to start dating one of Chris' "Chunky Cheerleaders".
  5. Apr 27, 2009 at 3:40 PM
    matt45648
    Yes. I checked the numbers with a dealer that toytec recommended. Have not tried to swap them. How would that fix anything?
  6. Apr 27, 2009 at 3:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If one had/has more arch than the other, you would want the one with more arch on the driver side.
  7. Apr 27, 2009 at 3:46 PM
    matt45648
    Hmmm, they appeared identical before I installed them...
  8. Apr 27, 2009 at 3:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Did you install them both with the long side tward the front?
  9. Apr 27, 2009 at 3:55 PM
    matt45648
    However the instructions said to...
  10. Apr 27, 2009 at 4:13 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    Hmm, I have the same kit. Toytec 3" - coils and aal. just went and measured my truck after reading this and there is only 1/4" difference. I have heard of this before, just cant remember where.
    :popcorn:
  11. Apr 27, 2009 at 4:27 PM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    I had the same problem initially with my AAL's from Fat Bob's. After about 200 miles, they settled and are damn near even. I would check the part #'s and make sure both are for your truck. You never know, maybe someone packed one of them in the wrong kit.
  12. Apr 27, 2009 at 6:31 PM
    matt45648
    Hrmmm. Do they even have anything written on them?
  13. Apr 27, 2009 at 7:22 PM
    badguybuster
    Michael
    Mine were stamped with a #.
  14. Apr 27, 2009 at 10:31 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Did you recently gain a lot of weight?
  15. Apr 27, 2009 at 10:34 PM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    Hertford NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
    This is where I would start. It is very easy to install them wrong.
  16. Apr 28, 2009 at 12:30 AM
    m_yota
    m_yota Well-Known Member
    Paradise
    08 4x4 dbl cab
    K&N airfilter, HID conversion for headlights/fogs. Wet Okole Seat covers, Kove Aphex processor Kenwood comp 6.5" and 6.5"coaxial 5100 billy shocks 2.5", 1.5" fabtech AAL,Epicenter and MTX Sub, debadged, tinted, kenwood dnx812, black mesh grill, led ext/int.
    that's :devil::smack:
