AAL question
Discussion in 'ToyTec Lifts' started by BassMaster06, Sep 1, 2010.
  1. Sep 1, 2010 at 10:14 AM
    BassMaster06
    BassMaster06 [OP] Well-Known Member
    Dan
    Lady's Island, SC
    Sand and dog hair
    this may be a dumb question, but my 06 double cab has not had the TSB done to the rear suspension. I am preparing to buy the OME 3" Kit ($699). At checkout, there are two options for the rear, as follows:
    -Toytec Add-a-Leafs Standard
    -Toytec Add-a-leafs for TSB springs
    Whats the difference between these two options, and which should I choose? I'm guessing I would need the Standard?? Thanks!
  2. Sep 1, 2010 at 11:54 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are they listed as having the same lift amount?
  3. Sep 1, 2010 at 12:00 PM
    28Gauge
    28Gauge Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
    You can use either one on non TSB trucks. I just put the Toytec 1.5" for TSB on my 2006 non TSB truck.
  4. Sep 1, 2010 at 6:13 PM
    BassMaster06
    Dan
    Lady's Island, SC
    Sand and dog hair
    It does not specify. I just dont know the difference between the two..I would rather get the set that would make up for the same thing that the TSB correction makes.
  5. Sep 1, 2010 at 6:14 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    tsb is 1.5 inch
    and the regular aal is 2.5 inch i think
  6. Sep 2, 2010 at 4:16 AM
    Janster
    Jandy
    Lancaster, PA
    Is that total lift or lift of the AAL's only??
    If the tsb springs have a 1.5" lift by themselves and you put it in with the tsb springs - you'll get 2.5
    Do you get where I'm headed with this?
    BassMaster - call toytec, maybe they'll have some explaination for you. OR - people who have actually used these can specify what lift they'll give.
  7. Sep 2, 2010 at 4:26 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    The ToyTec aal for the tsb springs gave me 1.5" of lift on top of what I had from the tsb pack.
  8. Sep 2, 2010 at 9:05 AM
    ToyTec Lifts
    ToyTec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    The TSB AAL is 1.5 inches of lift and the non-TSB is 2 inches. If you have not had the TSB done, you can use either one. If you do have the TSB, you have to use the TSB AAL
    :thumbsup:
  9. Sep 2, 2010 at 2:56 PM
    Janster
    Jandy
    Lancaster, PA
    Ok....just so I got this straight (for anyone who cares)
    TSB springs + toytec TSB AAL = 2-2.5" total lift approx
    Non TSB springs + toytec regular AAL = 2" total lift
    Toytec - why can't you interchange the AAL's??
    Assuming....
    Non TSB springs + toytec TSB AAL = 1.5" lift
    TSB springs + non tsb toytec AAL = 2.5-3" approx
    Sorry, I'm often over thinking things. :rolleyes:
  10. Sep 2, 2010 at 4:57 PM
    johnw
    john
    orlando florida
    i think the reason you cant put the regular AAL with the TSB leaves is because the regular AAL will be the exact same length as another leaf. do you get what im sayin? (hopefully)
  11. Sep 3, 2010 at 7:18 AM
    ToyTec Lifts
    Rocky Mountains
    Johnw is correct the standard AAL for the 05 up Tacoma is too long to fit on the TSB springs, it is about the same length as the last leaf above the overload on the tsb springs, so it just will not fit.
  12. Feb 17, 2011 at 1:17 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    So is it possible to use any regular AAL with the TSB and only the TSB AAL with the TSB and not the regulars?
  13. Feb 18, 2011 at 9:18 AM
    ToyTec Lifts
    Rocky Mountains
    The standard AAL will only work if you have not had the TSB done. The TSB AAL will work either way.
  14. Feb 18, 2011 at 10:45 AM
    Drunknsloth
    Retribution
    South West
    Okay sweet thanks, I got confused with all the analyzing above
