AAL question
Discussion in 'Suspension' started by kessler89, Dec 8, 2010.
  1. Dec 8, 2010 at 11:08 AM
    kessler89
    kessler89 [OP] Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    is there a AAL i can get for my non TSB truck that wont really raise the rear but will increase my cargo capacity? i need to haul a ATV in the bed and i've read the non tsb trucks will hit the bumpstops with this kind of weight out back
  2. Dec 8, 2010 at 11:10 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    why not get an aal "progressive"
  3. Dec 8, 2010 at 11:13 AM
    kessler89
    OH
    12' Pro4x 6MT
    TBA
    hmm i'm not really sure what this is?
  4. Dec 8, 2010 at 11:17 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    you will still have some lift but as the weight bears down on it the spring rate increases or gets stiffer.....
    mabye one of the pros will chime in here......
  5. Dec 8, 2010 at 11:19 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Don't bend the tailgate with the ATV.
  6. Dec 8, 2010 at 11:29 AM
    kessler89
    OH
    12' Pro4x 6MT
    TBA
    are you talking something like a helper spring? i'm looking at them right now, hopefully someone will chime in and recomend a good pair to get
    i'm kinda nervous about this, is there anyway to avoid doing so?
  7. Dec 8, 2010 at 11:33 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    :rofl::rofl::rofl::rofl::rofl:
  8. Dec 8, 2010 at 4:55 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    what? he has 06. tailgates weren't reinforced until 09 IIRC. Many has posted here about bending them puttin motorcycles and heavy stuff in the bed. One good thing about the ATV is the weight is spread out from the center of the tailgate vs. all the weight being in center loading a motorcycle. Just be aware and be careful is all I'm gettin at.
  9. Dec 8, 2010 at 9:19 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Helper springs and air-bags are good options for you.
    Personally I like the airbags (don't have them on the Taco) since you can increase load cap. when you want to. Set for a Taco is about $250-300.
    Helper springs do the trick but they can make the rear super ridgid under load. I put some on a Chevy 2500 a while back, once I had more than 300lbs in the bed it got really harsh (it was fine with a full bed of cement). Granted, the rear didn't sag any but the ride sucked. Make sure you get a lighter capacity on the helper spring; don't way overdue it.
    Also, you could go to a leafspring/iron shop and have anything you want made for like $50: zero lift AAL for example, although just adding another leaf will raise the rear .5" too.
    Helper or airbag = no lift.
    Also, I've ridden quads and dirtbikes across my tailgate many times, it's still straight. Probably would taco it if you put a Harley up there tho.
  10. Dec 9, 2010 at 10:50 AM
    kessler89
    OH
    12' Pro4x 6MT
    TBA
    Thanks for the input, mabye ill just get a 600lb helper, they're only $50 as for the tailgate I think ill just cut a piece of plywood to lay across the gate/bed to help spread out the weight
  11. Dec 9, 2010 at 11:35 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    :eek::eek::eek::eek:you went wheeling with my skid in the bak well all the skids .........you crazy s.o.b.
    i saw someone on here and he had his overload leaf on along witht the 3 leaf aal....and wheelers chimed in and said that it was fine to do that
  12. Dec 9, 2010 at 11:38 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    You have an 09, betting you have the tailgate that came with proper reinforcement to begin with unlike the earlier ones from 05,06 thru 08.
  13. Dec 9, 2010 at 11:40 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    so that means mine is strong too..
    i have had 500lbs standing on it before i told my friend to get off
    (2 - 250lb people)
  14. Dec 9, 2010 at 11:46 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    dam theft must be big down there......
    thats like what 300lb + slaming around in the back
    must have had to turn the radio up
