AAL question
Discussion in 'Suspension' started by Studder, Jan 21, 2012.
  1. Jan 21, 2012 at 5:32 PM
    Studder
    Studder [OP] Well-Known Member
    NY
    truck cap eyelids and halo lights
    with the Bilstein Adjustable lift kit with 5100 shocks from Toytec it comes with the 2" AAL. it doesn't come with new Ubolts do i need to get those or will all the stock equipment work with this set up?
  2. Jan 21, 2012 at 5:33 PM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    It's recommended to get new U-bolts. I did, and I would if I were you.
  3. Jan 21, 2012 at 5:34 PM
    tbturner47
    tbturner47 Well-Known Member
    Travis
    Lenoir, NC
    '07 Indigo Ink Off Road
    Supercharger
    From my understanding the stock u bolts will fit.
    Do you have the rear leaf tsb pack by the way?
  4. Jan 21, 2012 at 5:36 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Be on safe side and use new bolts
  5. Jan 21, 2012 at 5:37 PM
    Bogg
    Bogg Well-Known Member
    Surrey, Canada
    07 TRD Sport 4x4
    I installed a Wheelers 2" AAL with 5100s. The U Bolts do fit. However, it is recommended to not re use old U Bolts. A few weeks down the road I did the U Bolt flip kit :)
  6. Jan 21, 2012 at 5:39 PM
    Studder
    NY
    No tsb i havn't had problems with my rear springs and towing. mostly my concern is comeing from only being able to spend 700 and the lift plus the centering pin plus u bolts comes out to about 720
    what could happen if i don't use the new U bolt or centering pin? also would i be ordering the 7 1/2 or 8 1/2 for the 2" AAL?
  7. Jan 21, 2012 at 11:12 PM
    VooDoo
    Carter Ivey
    '06 DC LB PreRunner
    You're gonna need a new centering pin no matter what because the AAL will be too wide for the old centering pin. The 7.5 is what you need unless you're running blocks.
