AAL Settled more than expected - what to do?
Discussion in 'Suspension' started by bjamison01, Sep 14, 2009.
  1. Sep 14, 2009 at 9:43 AM
    bjamison01
    bjamison01 [OP] Member
    Brent
    Sacramento, CA
    09 Taco DC 4x4 Sport
    Icon C/Os, TC UCAs, Rear Billie 5100's, Toytec AAL, Shim, Moto Metal 955's (machined), Nitto TGs 285/70/17.
    Thanks in advance for anyone's help with this.
    Installed my lift about 2 weeks ago. Among other parts, I went with a toytec aal (non-tsb) and 5100s in the rear and icons up front.
    Once installed i set everything to a level height and wound up with about 3 inches of lift all around. Unfortunately, I'm just noticing that the truck is now starting to rake upward. Seems like the rear AAL's are starting to settle and I've lost about a 1/2 inch of clearance in the back. I know I could just lower the front C/O's but really liked the height it was at when first installed. So I'm wondering what my options might be to get more height in the back again.
    I was looking at installing a 1 inch block in addtition to the ALL, but everything I've read here says to stay the hell away from blocks :).
    Anyone have any other ideas or solutions? Dakar pack maybe?
  2. Sep 14, 2009 at 9:52 AM
    shockittillyareconizeit
    shockittillyareconizeit Well-Known Member
    Dustin
    California
    '07 Coma PreRunner
    Front - Icon 2.5 Coilovers, Maxtrac 4" lift spindles, TC UCA's Rear - Billy's 5100/1.5 AAL, 3" lift blocks MB Predator wheels - 16x8 plasti-dipped matte black Toyo Open Country A/T 305/70/16 Satoshi grille Blacked out badges DTRL Wet Okole seat covers
    Yep. Probably another leaf. Whether it's another 1.5 or a whole pack and just take out the first one you put in. kinda sucks to have to do that.
    Mine has settled quite nicely and now i have that super mean cali lean. :D just a little bit though. not totally bro'd out.
  3. Sep 14, 2009 at 9:56 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    yes, stay away from blocks.
    any leaf spring is going to settle over time, cant avoid it. some will settle more than others and quicker than other. alot of factors go into it. but a whole new leaf pack should settle less and be a better choice than any AAL. dakars are good and deavers and alcans are also available.
  4. Sep 14, 2009 at 9:56 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I had the same thing happen. I installed a 1" block and didnt notice any adverse effects from it. Its a cheap, easy solution to the problem and I'd recommend doing it. The neg wrap that blocks get is from the larger ones(like 3"+) that some lifts come with which increase the leverage on the leafs and lead to excessive axlewrap. With only a 1" block, you shouldnt even notice it.
  5. Sep 25, 2009 at 10:34 AM
    bjamison01
    Brent
    Sacramento, CA
    Just wanted to thank everyone for their comments. I wound up going with the 1 inch block solution with the AAL as it really was the simpler, cheaper solution for the time being. No noticeable difference in ride quality. Interestingly enough, the truck looks like its back to the same factory rake it originally had, only three inches higher front and back.
    My only concern now is how much more settling may happen in the coming months. I don't want the front any lower or the rear any higher. it'll be interesting to see how it shakes out. In either case, thanks everyone for the advice.
