AAL Suggestion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mdre29, Oct 22, 2014.
  1. Oct 22, 2014 at 12:03 PM
    mdre29
    mdre29 [OP] New Member
    Central Jersey
    '12 DCSB TRD TX
    So I've lurked around for some time and never really had a need to post until now. I know this has probably been answered on here hundreds of times, but I dont have the time to go searching through the forum.
    I've finally decided to pull the trigger and put the lift on my '12 Double Cab TX. Just recently got the TSB done on the leafs so now I've got some incentive to complete the lift.
    I'm most likely going to go with 5100s all around with OME 885s in the front. My only dilemma is whether or not to go with a 1.5" AAL in the back to go along with the TSB leafs.
    Anyone have any incite into this or rock that setup?
  2. Oct 22, 2014 at 12:16 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    AAL<Progressive AAL<New leaf pack
    :thumbsup:
  3. Oct 22, 2014 at 12:19 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    http://www.tacomaworld.com/forum/altsearch.php?q=Wheelers+1.5"+Progressive+AAL
    It takes less time to type into the search bar than it does to start a thread and wait for responses. I only say that because of your above statement ha Just admit it. You're too "lazy" to go looking. :thumbsup:
    To answer your question, my advice is also to go with Wheeler's 1.5" three leaf progressive AAL. If you leave your OL leaf in you get the extra 0.5" or so from that for a total of 2" of lift in the back. I ran that set up and liked it. Its a good combo of inexpensive but quality, relatively speaking. Go for it.
  4. Oct 22, 2014 at 12:20 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Perhaps you meant to swich the > to <.
  5. Oct 22, 2014 at 12:22 PM
    geekhouse23
    Yes -__-
    FIFY
  6. Oct 22, 2014 at 1:27 PM
    mdre29
    Central Jersey
    '12 DCSB TRD TX
    Thanks for all the input.
    Ill be sure to post photos when I get it done
  7. Oct 22, 2014 at 7:08 PM
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    Buy 5lug rear springs or get yours re-arched
