AAL to offset 200lbs of weight?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pbcolt, Aug 26, 2012.
  1. Aug 26, 2012 at 8:23 PM
    pbcolt
    pbcolt [OP] Well-Known Member
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    Would the Wheelers (or someone elses) 3 leaf AAL offset about 200lbs of weight on the rear of my truck?
    I will be getting a Pelfreybilt bed rack and a RTT in the near future and I am hoping that the Wheelers 1.5" AAL will lift 1.5", and the added weight of the RTT, rack and some camping gear will sag it 1.5" allowing me to use my stock shocks.
    I DO NOT...want to spend the dinero on a 3" lift right now and just doing the rear with Dakars would give me a stupid rake.
    Thoughts?
  2. Aug 26, 2012 at 8:26 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Even the Dakars sagged under the 250lb constant load of my commercial cap
  3. Aug 26, 2012 at 8:27 PM
    acdronin
    acdronin Well-Known Member
    Yes it will no problem, 200 is not that much weight, it's about the weight of a body (don't ask me how i know)
  4. Aug 26, 2012 at 8:27 PM
    pbcolt
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    Well crap.
    Haha nice.
    I just don't want to hit bump stops running over every off-road pebble, and not lift my truck so much that it looks dumb, or have issues with the rear shocks.
  5. Aug 26, 2012 at 8:28 PM
    acdronin
    My cap and rack is 450 and my 2 inch did fine until I crushed everything with 3k in gravel
  6. Aug 26, 2012 at 8:38 PM
    OZ-T
    Peter North
    British Columbia
    I should clarify , my Daks have settled about 5/8" in a year with the cap and some heavy loads , but I'm never on the bumpstops , even with as much firewood as I can carry
  7. Aug 27, 2012 at 6:11 PM
    Priddle
    Priddle And now for something completely different....
    St. John's, NL Canada
    2014 Tacoma 4x4 TRD Sport DCSB
    Current: Pelfreybilt front and rear bumpers, winch, icon front coils/shocks, Icon rear shocks, Dakar leafs, Camberg UCAs, Pumpkin Android stereo, custom sub box w/ 2x10" RF subs and Kicker amp, short shifter kit, Fuel Beast 18" wheels w/ 1mm offset, BFG AT2 285/65/18
    Consider Firestone Ride Rites airbags. I decided that over AALs and can adjust pressure based on weight, thereby always keeping the truck level.
  8. Aug 27, 2012 at 6:34 PM
    pbcolt
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    Those do look good, but at 290 dollars a set they are a little steep.
  9. Aug 27, 2012 at 6:35 PM
    OZ-T
    Peter North
    British Columbia
    Budget ?
  10. Aug 27, 2012 at 6:38 PM
    pbcolt
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    I guess it's not that the air bags are way out there, but I really just want to get a functional set-up for my tent and rack combo as inexpensively as possible (without blocks)
    I know in a year or two I'll get coilovers, rear dakars, shocks and UCA's, so this will just be to get me by until then.
  11. Aug 27, 2012 at 6:39 PM
    OZ-T
    Peter North
    British Columbia
    Dakars
    or AAL , then Daks
  12. Aug 27, 2012 at 6:41 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm happy with the Icon 3-leaf AAL. I have a fiberglass shell and keep a plywood platform and my tools in the bed at all times. I'd guesstimate around 300 lbs in the bed at all times. I kept the overload in place and it seems to be doing very well so far after a year and a half. I do load it up pretty heavy for camping and Home Depot runs and it will set on the overload if I put enough weight back there.
  13. Aug 27, 2012 at 6:42 PM
    pbcolt
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    Yep, that's what I'll do. Talked to wheelers today and apparently they make a HD 3 leaf aal for 10 bucks more. He agreed that with that set-up new shocks are not necessary given that the 100lb rack will always be on, and especially when I add the 120lb tent.
    That's good to know. I'll look into those too. I wouldnt mind sitting on the overloads when the girl and I climb up there, because I'll be parked. Just going down the road is where I'd like to have some travel.
  14. Aug 27, 2012 at 6:46 PM
    Pugga
    Massachusetts
    You'll need more than that. It takes almost an additional 1,000 lbs to put the setup on the overload. I do hope you have some lift in the front though. I've got the front lifted with Eibach coils (1.6" lift) and with the cap, plywood and tools, I've got about a factory rake.
  15. Aug 27, 2012 at 6:49 PM
    pbcolt
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    negatory on the front lift...
  16. Aug 27, 2012 at 8:16 PM
    pbcolt
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    If I need one then maybe I should just run stock and see where I am when the dust settles?
  17. Aug 27, 2012 at 8:22 PM
    OZ-T
    Peter North
    British Columbia
    Here's a thought .
    I know you said it's outta your budget , but I hate doing things twice , and paying twice .
    Buy the Dakars now , remove 3rd leaf , reinstall when you do your lift
  18. Aug 27, 2012 at 8:25 PM
    pbcolt
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
    I hate doing things twice too. I did 3 lift versions when I had my 99 4runner. I didn't even know that was an option...
  19. Aug 27, 2012 at 8:26 PM
    OZ-T
    Peter North
    British Columbia
    It drops the capacity , but also lowers the lift by approx 5/8" according to ARB specs
