AAL vs Dakar?
Discussion in 'Suspension' started by cdn_bacon, Jan 22, 2010.
  1. Jan 22, 2010 at 6:31 AM
    cdn_bacon
    cdn_bacon [OP] Well-Known Member
    Christopher
    Houston
    07 Tacoma Dbl Cab short box 4x4 TRD
    Slim's HID 6000k headlights and fog lights; Redline hood and tailgate struts, TRD CAI
    whats the diff? worth the price diff?
    if needed...installing the reg 3" OME kit you see everyone talk about, 9000 shocks and 885s, rear OME N182 shocks etc...
    oh...do you need brake line extenders for this set up?
  2. Jan 22, 2010 at 6:38 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    1st-Generally if you have a 3" lift and you off-road extended brake lines are a good idea.
    2-As far as shocks go, it just depends on what kind of ride you want and what you want to spend. The Bilsteins are the best bang for your buck IMHO.
    3-I have the TSB springs with AAL and could not be happier. It just depends on what you want to spend, what kind of ride you are looking for, and how abusive you are to them. Do the research on each type you are interested in and choose then.
    jmoto likes this.
  3. Jan 22, 2010 at 7:10 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    An AAL is just an additional leaf in your existing pack..The Dakar pack is a complete replacement with like 7 or 8 leaves. Different spring rates and feel. The OME shocks are built/tested with the Dakar packs...so they will go together nicely. If you have the extra coin-I would totally recommend the Dakars with some good bushings.
    You will want extended brake lines if you go offroad- The extra height from the lift and flex travel will stress your stock lines alot.
  4. Jan 22, 2010 at 7:58 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    Full leaf pack!!!!
    :d
  5. Jan 22, 2010 at 8:10 AM
    valleythunder
    valleythunder Well-Known Member
    Rob
    Dahlgren, VA
    08 DC/LB
    I think you would be better served replacing the factory GARBAGE!!
    I am replacing with the dakar full leaf pack and the XL overload leaf.
    With 3.25" up front and the dakars in the rear I am replacing both front and rear brakelines with extended length braided lines. Just my 2 cents!!
    :D:DAnything worth doing is worth doing right the FIRST time...???? :D:D
  6. Jan 22, 2010 at 9:20 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    i may be mistaken, but i think i read somewhere that since the dakar packs are designed with off roading in mind, they are not as good for hauling and towing as an aal would be...but they are far superior off road becasue of that
  7. Jan 22, 2010 at 9:24 AM
    Toytec Lifts
    Rocky Mountains
    NOT true!
    They are made for hauling because they have two overload springs.
    It's packs like ALCAN's, etc that are more for just off roading...
  8. Jan 22, 2010 at 9:30 AM
    djs05tacoma
    djs05tacoma Well-Known Member
    Martinez, CA
    05 Double Cab TRD offroad 4x4
    3" OME Lift, 285's
    Go with the full pack. The stock springs sag pretty bad if you carry any weight, I've got a 1.5" aal from when I put my ome lift on and recently had to had a 1.5" block to level out the truck once again because the stock leafs are so terrible.
  9. Jan 22, 2010 at 9:32 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    my mistake, i knew there was a leaf pack out there like that, just not sure which one
  10. Jan 22, 2010 at 9:35 AM
    Toytec Lifts
    Rocky Mountains
    You know it! [​IMG]
  11. Jan 22, 2010 at 9:35 AM
    Toytec Lifts
    Rocky Mountains
    No worries. It does get very confusing!
  12. Feb 16, 2010 at 8:16 PM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    I just got some of these leafs from you guys to compliment my toytec ultimate lift kit. My question is that right now on the rears I have the AAL for the non-tsb leafs - how much higher is the full dakar leaf packs in comparison ?
  13. Feb 17, 2010 at 7:10 PM
    Toytec Lifts
    Rocky Mountains
    Probably about .5 inches.
    Just a little more.
  14. Feb 17, 2010 at 7:12 PM
    Toytec Lifts
    Rocky Mountains
    Your looking at more like an inch higher.
  15. Feb 17, 2010 at 11:18 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    do you have a set for the 1st gens? I looked but couldnt find it
  16. Feb 18, 2010 at 8:47 AM
    Razorecko
    awesome thanks ! with my toytec's cranked to a 3.5" lift on the front its perfectly level but i could use that .5 rake height because if i load anything in the truck it looks funny. Not too mention with my blower and lead foot the front of the truck is usually up in the air :D
  17. Feb 18, 2010 at 6:28 PM
    dylandercole
    Dylan
    very interested in these if they exist for first gens
  18. Feb 18, 2010 at 6:42 PM
    Blumpkinson
    Blumpkinson Fuelled by plutonium and wild animals
    OR
    03 4x4 5spd
    Here you go, these seem to be a good alternative to the 600 dollar alcans/deaver packs
  19. Feb 18, 2010 at 6:53 PM
    dylandercole
    Dylan
    nice. do you know if ill need the new shackle bushings they roccomend if I have th toytec 1'' lift shackles??
  20. Feb 18, 2010 at 7:31 PM
    Blumpkinson
    OR
    03 4x4 5spd
    Probably, but i would contact wheelers they'll be able to answer your questions.
