AAL vs. rear blocks?
Discussion in 'Suspension' started by colinb17, Jan 29, 2009.
  1. Jan 29, 2009 at 11:43 AM
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    hey everyone. i have an 07 4x4 double cab shortbed. i know that i will be getting a toyotec 3'' lift in the near future. i have decided to (unles someone persuades me optherwise) to go with the medeum replacement springs in the front, but i am still debating on the rear. like most of us, the majority of my driving is on the road, but i hit the trails as much as i can. (not much lately since i'm busy with college). i am jsut wondering abotu the main differences in the two...i'm assuming that the rear blocks keep a stock ride and the AALs make the rear siffer. is this true? i don't mind if the stiffeness changes or not. also, a poor colleges studen doesn't have the money to pay someone to install a kit for them, so since i will be doing it myself, is either one easier to install? and the last wuestion is, is there a difference on the wear they put on the components of your truck?
    thanks for your help!
  2. Jan 29, 2009 at 11:47 AM
    colinb17
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    sorry, i forgot one more question.....will i need to buy any other parts other than what comes with the lift? or are there any parts you reccomend?
  3. Jan 29, 2009 at 11:49 AM
    Top Gun Customz
    Top Gun Customz Active Member
    A block will be easier to install than the aal. The aal will make it slightly stiffer but won't let your axle wrap as much. Unless you do a lot of towing, burnouts, or racing just go with the block.
  4. Jan 29, 2009 at 12:13 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I would go with an AAL, for there is more pros about them. The block will cause axle wrap and could break. The AAl will make it a little stiffer but you will increase load compasity. Everybody I've talked to, has told me to stay away from blocks.
    -You will need a diff drop kit If you go with a 3" lift
    - It also wouldn't be a bad isea to go with Bilstein shocks all the way around for a better ride quality.
  5. Jan 29, 2009 at 12:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
  6. Jan 29, 2009 at 1:12 PM
    colinb17
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    i don't know if it makes a difference, but i forgot to mention that i have the rear spring tsb already. will that affect anything? also, if i don't get new shocks, will i have problems with them fullyextending? do i need longer travel shocks, or is it purely for a smoother ride?
