AAL with rear Block
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRD2013Chris, Oct 17, 2014.
  1. Oct 17, 2014 at 8:27 AM
    TRD2013Chris
    TRD2013Chris [OP] Well-Known Member
    chris
    CT
    Black 2013 Tacoma TRD Sport Dbl Cab Long bed
    Hey TW ...
    So i recently adjusted my 5100s to first notch from 0 to 0.85. I have 885 OEM coils. I was running the setup for a little over a year and i have noticed my 285/70s began to rub a tiny tiny bit at full lock. So that's why i bumped them up.
    Anyway the truck sits a little higher in the front then the rear obviously. I have a 1 1/2" Block back there now. I like the look of a little bit of a rake to the truck so should i just go with a 1.5" Add a leaf ?
    If i go that route would i need longer U bolts then what came with the 1.5" block?
  2. Oct 17, 2014 at 8:47 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if you go with an AAL do like a wheelers single leaf 2in AAL only ~ 5/16th's of an inch thicker so if you have that much extra threads on your u bolts you will be good.
    That stated... blocks = no good.
  3. Oct 17, 2014 at 4:24 PM
    watchdog
    watchdog Well-Known Member
    jim
    nanuet n.y.
    09 tacoma
    Rims and tires , exhaust , stereo , Bhlm ,Changed carpet to black from grey. toytec ultimate lift kit. Allpro front bumper and light bar. In process of blacking out interior. Otrattw switches, black vinyl armrest mod, clazzio leather seat covers with heaters, flowmaster dual exhaust, hornblasters train horns,
    A good add a leaf and you can get rid of the blocks. Got mine from Toytec and they lifted my truck by 3 inches.
  4. Oct 20, 2014 at 9:44 AM
    TRD2013Chris
    chris
    CT
    Wow yeah I heard a lot of people saying blocks were no good. I just thought that was when they start to get over 2" when you could run into trouble .
    Wow 3 inches from a 1 Toytec leaf?
  5. Oct 20, 2014 at 7:48 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    I got about 4" from a Tough Country AAL.
  6. Oct 20, 2014 at 7:56 PM
    bzzr2
    bzzr2 Well-Known Member
    going from a 1.5 block to a single aal (if you remove your block that is with a leaf that gives you the 3 inches you want..) you might find that your ubolts are too long. i think the rule of thumb is you want 1/2inch of threads sticking out at the least.. somebody will have another opinion on that shortly i'm sure
  7. Oct 21, 2014 at 5:57 AM
    TRD2013Chris
    chris
    CT
    I already have longer U Bolts or my block, so i wont need them. I was just saying if i used the block and added 1 leaf would the U bolts be long enough.
    But i think im going to get rid of the block and just go with an add a leaf or Progressive AAL from toytec and keep my overload leaf in...
    Anyone know how many inches that would bring me at? 2 1/2?
  8. Oct 21, 2014 at 6:14 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Wheeler's is saying 1.5" of lift with the Icon Progressive AAL: Good choice on choosing the Progressive AAL over the single AAL. While the optimal choice is to swap out the toyota leafs completely, the single AAL is horrible and sucks all around. Unless you don't tow or haul ever (have absolutely ZERO weight in the back) and never take it off pavement, single AAL is alright.
  9. Oct 21, 2014 at 10:16 AM
    n.gardner
    n.gardner Spacer Hater
    Nick
    Hawaii
    '13 SR5 4x4
    OME 3" 887s + Dakars 1" 4 Crawler BL Pro-Comp Uniballs Nitrochargers + Super Bumps Diff Drop + Drive Shaft Drop
    #DAKARS
