AAL with Stock Shocks
Discussion in 'Suspension' started by 28Gauge, Jun 14, 2010.
  1. Jun 14, 2010 at 8:32 AM
    28Gauge
    28Gauge [OP] Well-Known Member
    Brian
    Grapevine, TX
    06 PreRunner SR5
    Sockmonkey Graphics, K&N Drop In Air Filter, 265/75/16 Bridgestone Dueler A/T's, Weathertech Digital Fit Floor Mats, Dee Zee Bed Mat, Map Light/Dome Light LED's, Flo-Pro Muffler w/Stainless Steel Tip, Dome Light/Map Light Mod, Mobil 1 Synthetic Motor Oil, LED Cupholder Mod, Grillcraft with TOYOTA emblem, Vision 375 Warrior Wheels, Extra Bed D Ring Mod, TRD Skidplate, Bilstein 5100's on all four corners, Front 5100's set at zero with Eibach springs, Toytec 1.5" rear TSB add-a-leaf springs, Toytec swaybar relocate kit, Katzkin Leather Seating, Front Window Tint
    Can I put in Toytec's 1.5 add a leaf springs with the stock Toyota shocks? I'm going to do 5100's, but DSM will not have them in stock until late July. I don't have the TSB and the stock shocks are black ones (can't remember the name).
  2. Jun 14, 2010 at 8:51 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    get some shock extenders for 10 bucks
  3. Jun 14, 2010 at 3:47 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Yes you can run stock shocks with a 1.5. I am in a similar boat with the wait for 5100 rears... Do you have a non-tsb or tsb? If non, the aal is said to be 2". Just installed, and currently sits at about 2.5
  4. Jun 14, 2010 at 3:51 PM
    djs05tacoma
    djs05tacoma Well-Known Member
    Martinez, CA
    05 Double Cab TRD offroad 4x4
    3" OME Lift, 285's
    Not sure if you have a trd but I ran the stock billys for over 40k w/ and aal.
  5. Jun 14, 2010 at 3:51 PM
    28Gauge
    Brian
    Grapevine, TX
    06 PreRunner SR5
    I have none TSB springs.
  6. Jun 14, 2010 at 3:52 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    You will be fine...
  7. Aug 4, 2010 at 8:19 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    Im thinking about doing this same thing. 2 inch aal in the back without bilsteins.
    So i just need some shock extenders? are there any recomended shock extenders? And are there and problems or issues that i could run into when going this route?
    Thanks
  8. Aug 4, 2010 at 9:05 PM
    djs05tacoma
    Martinez, CA
    3" OME Lift, 285's
    I've got a pair of toytec shock extenders brand new in the box. I'm in Martinez. Free if you wan to pick them up.
  9. Aug 4, 2010 at 9:31 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    The extenders essentially just make the top bolt on your shock longer. Normally a design like this would make the shaft more likely to break but since the force is up and down (not side to side) it doesn't really create any problems.
    They look a little funny in my opinion but other than that they're fine... if you mash real hard or jump the truck they might break... but then again, if you drive like that, everything could break.
  10. Aug 4, 2010 at 11:24 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    any place to get them at?
  11. Aug 5, 2010 at 7:54 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Whats TSB?
  12. Aug 5, 2010 at 10:14 AM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
  13. Aug 5, 2010 at 10:27 AM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
  14. Aug 5, 2010 at 10:01 PM
    nvdeserted
    Reno, NV
