AAL with Stock U bolts???
Discussion in 'Suspension' started by bboyd89, Apr 2, 2013.
  1. Apr 2, 2013 at 2:17 PM
    bboyd89
    bboyd89 [OP] New Member
    york, pa
    '11 sr5
    So i just got a three inch spacer lift with aal in the rear came with centering pins only. i called toytec and talked to a rep and they said it is typical to use stock u bolts with the AAL no offence to toytec just thought it sounded too good to be true. btw i have 2011 sr5 double cab. any help would be greatly appreciated
  2. Apr 2, 2013 at 2:20 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    if you have the change to get the ubolts, get them.
    they can be run with stocks, but it's not recommended (I did, without any problems)
  3. Apr 2, 2013 at 2:22 PM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    Why would it be too good to be true? Yes my ubolts work fine with my 05 and toytec AAL. I don't see a reason to replace them if they are in good shape and long enough.
  4. Apr 2, 2013 at 2:23 PM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Columbia, SC
    2015 DCSB 4x4 trd offroad
    Ome 885, dakars, lr uca, bed bars sos sliders
    I have a rough country AAL 1-2" and used stock U-bolts.. with enough room to tighten really well
  5. Apr 2, 2013 at 2:23 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    My AAL is mounted with stock u bolts.
