aal's with a level lift?
Discussion in '4 Cylinder' started by quicksilvertacoma, Oct 17, 2009.
  1. Oct 17, 2009 at 1:39 PM
    quicksilvertacoma
    quicksilvertacoma [OP] Well-Known Member
    Harlingen, TX.
    08 Reg. Cab Tacoma 4x4
    NA
    i put a pro comp level lift on my reg. cab a while back and now(to me) it seems like the front is higher then the rear, should i put 1.5 aal's on it? anyone done thins before? the level lift was supposed to give the front 2.25 of lift by the way..
  2. Oct 17, 2009 at 1:42 PM
    TACOFEAVER
    TACOFEAVER Well-Known Member
    Newfoundland, Canada
    09 SR5
    3" lift, and 265 75 R16 Trxus M/T's enroute. (to be installed in about 2 weeks)
    I used the 3" pro comp level kit with AAL's .. worked great... gave me about 3.5" of actual lift.
    AAL changed the ride in the back - made it quite a bit more stiff - but have been very impressed with lift so far. (And it is level!)
  3. Oct 17, 2009 at 1:47 PM
    quicksilvertacoma
    Harlingen, TX.
    NA
    what size aal's did u put on there?
  4. Oct 23, 2009 at 1:36 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    just a hint AAL have nothing to do with 4-cylinders. when he says 3.5 inches of lift that is probably in the front so he probably has something like 2 inch lift AAL's. Just a guess.
  5. Oct 23, 2009 at 9:06 PM
    quicksilvertacoma
    Harlingen, TX.
    NA
    wow! thanks for the hint!
  6. Oct 24, 2009 at 4:54 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    :rofl:
    I did answer your question:D
  7. Oct 25, 2009 at 6:06 AM
    bcsnave
    bcsnave Well-Known Member
    Wisconsin
    06 4x4
    I have a 3 leaf pack in my 4cyl 4x4. It seems that the reat is sitting low. Does anyone know of an AAL that will provide a good ride quality and keep the rear at the stock height?
    Bill
  8. Oct 25, 2009 at 8:35 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    Adding any kind of AAL will make the ride some what stiffer and it will raise the back end of the truck. so to answer your question. 1: good ride quality, yes but it will be a little stiffer...2: keep the stock ride height, no but i thought you said the rear was sagging? in that case just mesure out the correct height you want in the rear of the truck and find an AAL that lifts it X amount, and you will be good to go.
