AAL's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Finallyhaveatoyota, Jan 23, 2018.
  1. Jan 23, 2018 at 9:47 AM
    Finallyhaveatoyota
    Finallyhaveatoyota [OP] Well-Known Member
    Northern Michigan
    2011 TRD Double Cab
    Bilstein 5100 Front and Rear. Firestone Riderite Rear Airbags. Aprox. 2.75" front lift, 3" rear. Everything else stock :)
    Hello: Running into some confusion and was hoping someone might be able to shed a little light on this. Currently have: Tacoma 2011, 4 door, 4x4. Front has 2" spacers. The rear of the truck sits just slightly lower than the front, not a huge issue.
    I am looking for way to help the rear of the truck. We haul a 20', 4,000 camper as well as a utility trailer. The camper uses a weight distribution hitch and works great. However the utility doesn't. I need a little more strength in the rear of the truck and have been looking at AAL's but got lost quickly.
    Specifically: https://bilsteinlifts.com/shop/toyota-tacoma/2005-2015/rear-lifts-05-15/toytec-progressive-mini-leaf-add-a-leaf-for-2005-toyota-tacoma/
    Mechanic is asking me: Do these AAL's require dissembling the existing leafs or do they bolt on with existing leafs? Do I need a different shock in the rear (stock) for height? If so, can you recommend one, I have seen in many posts the Bilistein 5100 series but I am unsure on what to get?
    I am also not opposed to removing the front 2" spacers and replacing those shocks with a Bilistein that can do the same thing as the spacer in regards to height. Maybe now is the time do it all? In short, if I have to lift 2" all the way around, I am fine with that.
    Any help would be appreciated for the AAL's. Main goal is to add a stronger rear end for hauling trailers and load in bed. Works now, but does sag.
    Thank you
  2. Jan 23, 2018 at 9:49 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    do yourself a favor. Buy a full leaf pack. new Dakar HD packs sound like they would fit your needs well.
    Alexely999 likes this.
  3. Jan 23, 2018 at 9:51 AM
    Finallyhaveatoyota
    Northern Michigan
    2011 TRD Double Cab
    Thank you. My only concern was, the leaf springs are less than 4 months old, factory warranty replacement. Otherwise I was considering doing just that, buying an entire pack but didn't want to throw away something that has less than 5,000 miles on it. With that being known, do you still recommend a full replacement?
  4. Jan 23, 2018 at 9:52 AM
    nd4spdbh
    SoCal
    Yes for your use, a full pack. AAL's dont help much for load carying
  5. Jan 23, 2018 at 9:52 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    You could also sell the stock ones
  6. Jan 23, 2018 at 9:52 AM
    Finallyhaveatoyota
    Northern Michigan
    2011 TRD Double Cab
    Thank you. That is what I was afraid of.
    Alexely999[QUOTED] likes this.
  7. Jan 23, 2018 at 9:53 AM
    Finallyhaveatoyota
    Northern Michigan
    2011 TRD Double Cab
    Ok thank you everyone. Knew I would get the right answer here. So a full pack is what I need and will try to sell the current springs with 5,000 miles on them. Second part, do I need to change the rear shocks with the new spring pack?
  8. Jan 23, 2018 at 11:30 AM
    nd4spdbh
    SoCal
    Idealy yes. OME makes some good shocks to pair with the dakars, but others have no issue running 5100's
