AB6 Retrofit Headlights
Discussion in 'Lighting' started by joechef, Dec 13, 2019.
  1. Apr 6, 2020 at 8:32 PM
    jhmw815
    jhmw815 Well-Known Member
    Los Angeles, CA
    2018 Tacoma Trd Pro
    I think taco twonz on YouTube has these
  2. Apr 6, 2020 at 8:48 PM
    kustom54lighting
    kustom54lighting Well-Known Member Vendor
    He does he owns ab6 on his Tacoma and 4runner
  3. Apr 15, 2020 at 6:36 AM
    yaycolin
    yaycolin Well-Known Member
    Colin
    Orange County, CA
    2016 4x4 White DCLB Sport
    King 2.5 CO, Total Chaos UCA
    Just received my headlights, along with the add-a-fuse harness, yesterday. They look sick! Will be installing them this weekend. Thanks @kustom54lighting
    @joechef How did you secure the relays and the ballasts to the vehicle? did you screw them into the body or use Velcro or something? Also, did you choose the RX-350 projectors or stay with the stock ones?
  4. Apr 15, 2020 at 7:56 AM
    joechef
    joechef [OP] Well-Known Member
    Joe
    Seattle, WA
    I could clean up my setup a bit, although I just zip tied the ballasts/relays/loose wires right behind the lights.
  5. May 10, 2020 at 2:32 AM
    cmt_taco28
    cmt_taco28 Well-Known Member
    Johnny
    2020 Cement Tacoma TRD Off Road
    hey, how is the lighting? are they pretty bright? I'm debating on buying these and selling my 2020 headlights.
    kustom54lighting likes this.
  6. May 10, 2020 at 8:32 AM
    joechef
    Joe
    Seattle, WA
    Very bright and the cutoffs are effective. Can’t beat how these things look either.
  7. May 10, 2020 at 1:00 PM
    cmt_taco28
    Johnny
    awesome! Sounds good! Was it easy to get it working with the DRL?
  8. May 10, 2020 at 1:18 PM
    joechef
    Joe
    Seattle, WA
    I have not done any alternative wiring methods to enable that. They currently come on with the tail lights / fog lights setting. Kustom54 Lighting will eventually release a plug and play harness to enable that if one doesn’t want to do it themselves
  9. May 10, 2020 at 1:52 PM
    cmt_taco28
    Johnny
    ahh ok. Thanks man! Appreciate it!
  10. May 11, 2020 at 9:46 AM
    yaycolin
    Colin
    Orange County, CA
    I have their plug and play harness installed on my AB6 headlights, and it works great. DRLs come on when you turn the truck on, and you don't need to have the switch in the second position (side marker/running light function). The only downfall with the plug and play harness is that the hazard lights on the headlights themselves will not flash when the truck is off.
  11. May 11, 2020 at 10:38 AM
    cmt_taco28
    Johnny
    ohh ok. Has it been a problem with the hazard lights not working while its off? And did you get the plug and play harness from their website?
  12. May 11, 2020 at 2:34 PM
    yaycolin
    Colin
    Orange County, CA
    No, it's not a problem. It just makes it hard to tell if your hazards are on or not when you are looking from the front of the truck. But the side mirror lights will still flash when the hazards are on.
    I don't think they are selling the harness yet. When I placed my order, I requested to have the lights wired using the harness instead of taping into the side marker light.
  13. May 11, 2020 at 2:37 PM
    cmt_taco28
    Johnny
    ok ill definitely do that. im still contemplating but I really like the look of it. I have a 2020 off road with the new updated headlights and I love the way the way it looks already but the AB6 looks so good and mean. did you add the RGB lights?? I'm debating if I want that as well.
  14. May 12, 2020 at 6:25 AM
    yaycolin
    Colin
    Orange County, CA
    I did not do the demon eyes because I didn't feel like the price was worth the amount of use I would get out of them. It is illegal to drive around with them on, and I don't take my truck to shows or events, so I felt that it was pointless for me to get them. Just my opinion. They do look badass if you actually use them though.
  15. May 12, 2020 at 10:35 AM
    #35
    cmt_taco28
    Johnny
    yeahh thats kind of true. I really dig the RGB but you made a good point, u get no use out of it. That part still turns on though right? And are the headlights pretty bright? I'm thinking of going with 5500k HID kit
  16. May 12, 2020 at 1:11 PM
    #36
    yaycolin
    Colin
    Orange County, CA
    the RGB demon eye would go inside of the projector. The projector will still work like normal even if you don't get the RGB demon eye. If you do get the RGB demon eye, then the projector will just be able to change different colors. But yes, the projector will always work as intended. The headlights are definitely bright. I went with the RX350 retrofit and 5500k HIDs. The adjustment takes a little fine tuning to get them just right
  17. May 17, 2020 at 11:43 AM
    #37
    jhmw815
    Los Angeles, CA
    2018 Tacoma Trd Pro
    :worthless:
  18. Jun 9, 2020 at 8:12 PM
    #38
    cmt_taco28
    Johnny
    Does anyone know if the AB6 headlights work with the new 2020 LED headlights? Kustom54 said no but they sounded unsure about it though.
  19. Jun 9, 2020 at 8:15 PM
    #39
    kustom54lighting
    they will require a special harness at least due to the headlight connector but since we don’t have one we can test on, we can’t say they work
  20. Jun 9, 2020 at 8:19 PM
    #40
    cmt_taco28
    Johnny
    can you guys send me a set with the harness and I can test them out for u.
