Ability to add ATRAC to 2008?
Discussion in 'Technical Chat' started by Chickenmunga, Jun 16, 2010.
  1. Jun 16, 2010 at 10:36 PM
    Chickenmunga
    Chickenmunga [OP] Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Wondering if the same trick works for Tacos:
    I saw this video on the FJ Crusier:
    http://www.youtube.com/watch?v=GT8E7BGYzns&feature=related
    Basically for FJs, they follow these rules:
    Not all FJ's come with the locker.
    Not all FJ's come with atrac.
    All FJ's that have the locker have everything for atrac except the switch.
    All FJ's with atrac have the locker.
    So this is probably unlikely, but has anyone tried the same on a pre-2009 Taco?
  2. Jun 17, 2010 at 6:12 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  3. Jun 17, 2010 at 9:44 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I would strongly encourage you to reach out to the dealer network and ask someone experienced there.
    My opinion which could be wrong is that it's not possible to add A-TRAC to the Tacoma without serous modifications to the truck. Why? Because A-TRAC requires a hydraulic brake booster and a skid control ECU which is programmed to perform with the A-TRAC feature.
    If someone took the time to compare part numbers between the 2008 and 2009 models and came to the conclusion that it's the same part for the skid control ECU, that would be a very telling sign that the A-TRAC feature may be there all along...
    But one thing is clear. If your truck had the vacuum brake booster, it will not work. Sea attached PDF for clarification.
    Tacoma 2008 and earlier models had the hydraulic brake booster as optional equipment if the truck came equipped with VSC/HAC/DAC. It may be possible to replace the skid control ECU with a more updated one but it may be more complicated than that.
    When I look at the wiring diagram for a 2009 it is very obvious that there are many complex systems which interface to achieve the desired effect for the traction systems. If anyone of those supplementary systems are not there, then its not going to work. For example: does your truck have an A-TRAC indicator lamp in the dash combination meter? No? Well then you'll have to replace that too.
    Look at the attached diagram for a detailed understanding.
  4. Jun 17, 2010 at 3:58 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    ATRAC will only function correctly with the newer style wheelspeed sensor. So the short answer is no, it will not work on any Tacomas. The TRAC mod will work on 2009+. The VSC ECU pre 09 is also different, and the truck is not pre-wired. I could go on and on. Short answer, doesn't work. The above was however inspiration for the TRAC mod.
  5. Jun 17, 2010 at 7:54 PM
    Chickenmunga
    Keizer, Oregon
    Thanks guys. It was worth asking, but no free lunch on this one it looks like.
  6. Jun 17, 2010 at 8:01 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Make a deal for a 2010 Off Road 4X4... the A-TRAC is soooo worth it! ;)
  7. Jun 20, 2010 at 5:39 PM
    Chickenmunga
    Keizer, Oregon
    With the money I'd lose, I might as well install a front locker.
    DistortedAxis likes this.
  8. Jun 20, 2010 at 6:20 PM
    David K
    Lose? Don't be so sure... I traded my 2005 with 102,000 miles for the new 2010 with nothing else down and only $20/ month increase in my lease payment. Tacomas hold their value and are in demand.
  9. Jun 20, 2010 at 6:50 PM
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    just checked my 09 for the wires behind the blank, nada. could be taped to the harness at some pooint behind the dash. i have the 2.7, could be a different harness altogether. any v6ers willing to check?
  10. Jun 21, 2010 at 9:05 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    x2 for the money wasted you can get SFA with elocker. :)
  11. Jun 21, 2010 at 8:21 PM
    Isthatahemi
    TRD OFF ROAD
    The wiring is different on the OR's. But it doesn't matter, the other hardware is not present....
  12. Jun 21, 2010 at 8:22 PM
    Isthatahemi
    TRD OFF ROAD
