Abnormal Chirp or Squeak Noise from High Pressure Fuel Pump
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoFister, May 6, 2016.
  1. Dec 23, 2017 at 1:42 PM
    #461
    zonks12
    zonks12 Member
    my point exactly why are all of us just taking this sitting down???? idk what to do but we need to do something!
  2. Dec 23, 2017 at 2:24 PM
    #462
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    I’m with ya, but fact is that even though it sounds like drunk crickets, the HPFP on my truck hasnt failed in 22k miles over the last year. Until they fail I doubt Toyota will do anything about them... poor move but i just don’t see them doing anything until it becomes a safety or reliability concern
    shakerhood and Drunken Chewbacca like this.
  3. Dec 23, 2017 at 2:51 PM
    #463
    Opihi59
    Opihi59 Vulgar Boatman
    Beyond Honolulu
    2016 TRD Sport DCSB 6MT
    Unknown lift, maybe 2" I don't know how to ID it, and would rather set it back to stock.
    So nobody has any input on how hot their HPFPs are after driving? Beuler? Beuler?
    If you don't know where it is located or what it looks like, I'll post up some pictures of it.
    (149.5F on my IR gun)
    Drunken Chewbacca likes this.
  4. Dec 23, 2017 at 6:57 PM
    #464
    zonks12
    zonks12 Member
    bshammer but they did recall the hpfp on the scion frs but only after 6 years
    shakerhood and bshammer0 like this.
  5. Dec 23, 2017 at 7:03 PM
    #465
    Opihi59
    Beyond Honolulu
    That is interesting.....any more detail on this you could share?
    EDIT-1/8/18-There is/was no recall on this. Six years? No idea where that came from either. There is a TSB, which advised if the HPFP was squeaking/chirping after 10 minutes of running time for the technician, the HPFP would be replaced. It was replaced by the same part number, so this seems to be no solution to the issue whatsoever.
    Editing Feb 22 '18--Zonks12 never came back in with any supporting data on his claim. I'm calling BS on his Scion FRS recall comment until he shows documentation, and then I'll "like" his post. Until then though........
  6. Jan 6, 2018 at 9:10 PM
    #466
    T-rev
    T-rev Resident Mall Crawler
    Tempe, AZ
    2017 TRD Offroad
    My '17 just developed a squeak/chirp at 19k miles.
    I normally fill up at the same gas station, 91 octane every time.
    Most recently I filled up with my typical choice, but their winter blend includes ethanol. Since my most recent fill up my truck is chirping like crazy. And under acceleration the truck squeals obnoxiously through 3500rpm, after which the intake drowns out all other noise. What I've noticed is the truck will only chirp/squeal after the truck is warm. From a cold start everything is fine, and for most of my commutes it makes no abnormal noises until roughly 10 minutes in.
    With the hood up and trying to pinpoint the noise, it looks like the sound is coming from the high pressure fuel pump. The chirping sounds very similar to what everyone else is experiencing, however the squealing I'm experiencing is significantly more obnoxious than the chirping I'm getting after the truck is warmed up. It sounds like bad belts on a 1990 Chrysler. Is anyone else having this same sound or am I dealing with a bad pulley/belt?
    shakerhood likes this.
  7. Jan 7, 2018 at 1:08 AM
    #467
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Sounds like you are describing the HPFP noise with the Cricket Chirping sound. Not sure what the squealing is unless that is somehow a weather related issue or an actual problem in the belt drive, a trip to the Dealer is probably worthwhile.
    T-rev[QUOTED] likes this.
  8. Jan 7, 2018 at 8:32 AM
    #468
    Rotekk
    Rotekk Well-Known Member
    17 TRD 4x4 OR
    dealer just said normal by comparison. My '17 F150 with the 2.7 did it but worse. In the end auto makers just really don't care about the product they are pushing.
  9. Jan 8, 2018 at 10:22 AM
    #469
    T-rev
    Tempe, AZ
    2017 TRD Offroad
    After some self diagnosing, I believe the two sounds I'm hearing are unrelated. My HPFP is absolutely chirping and I'm going to have it documented with the dealer, the squeal I'm hearing is from the pulley system. A quick spritz of water on the belt silenced the squeal entirely. But I'll have the dealership address the cause of that under warranty.
  10. Jan 12, 2018 at 10:44 AM
    #470
    makuaoiloa
    makuaoiloa New Member
    2016 Gray Tacoma TRD Sport
    TRex Phantom Grille, Borla Muffler single in dual out, Roll-n-Lock Tonneau cover, Led Cabin lights, weather tech floor mats, titanium tint
    I have 25,000 miles on my 2016 and the high pressure fuel pump has started to chirp. It is quite loud, and I can hear it from the cab. My Dealer said that it is normal and all of them do it. I tried to push him but it doesn't seem that they are doing anything about it currently.
  11. Jan 12, 2018 at 10:49 AM
    #471
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
    Goto a different dealership as I did...
    Taco Addiction and shakerhood like this.
  12. Jan 12, 2018 at 10:51 AM
    #472
    makuaoiloa
    Unfortunately my dealer has a monopoly on Toyota here. What did they do to your truck? Did they fix it?
  13. Jan 12, 2018 at 11:17 AM
    #473
    Opihi59
    Beyond Honolulu
    Hmmmmm. Sounds like the 808 area code.....
  14. Jan 12, 2018 at 11:38 AM
    #474
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    i had mine replaced when they were replacing them...they have so many that they stopped and now say it is normal....the new one is now chirping as we'll.....very embarrassing
  15. Jan 12, 2018 at 12:03 PM
    #475
    Drunken Chewbacca
    Josh
    3rd Gen Taco
    Not enough to list
    replaced my High pressure fuel pump @5k miles. 23k on it right now and no chirps... I put whatever gas and still good.
  16. Jan 12, 2018 at 9:30 PM
    #476
    mtnfox
    mtnfox Well-Known Member
    Dave
    1991 4x4 p/u, 2016 Quicksand TRD Off-Road 4x4 DCLB
    Similar experience here. Replaced high pressure fuel pump at just over 5,000 miles, now at just over 20,000. Chirp has not returned. Only difference is they put on my service receipt that I should try different gas so I switched from Costco to Arco...:rolleyes:
  17. Feb 22, 2018 at 3:21 PM
    #477
    DIRTT_Fish
    DIRTT_Fish Well-Known Member
    2017 TRD OR DCSB
    Cbi t3, 888, HD Dakar, b110, wheelers bumps,ubolt flip, spc uca, +4" rear brake lines.
    Just noticed mine chirping at 12k miles...always filled up at same gas station on base. I'll try another place on my next fill up to see if it makes any difference. Fun stuff.
  18. Feb 22, 2018 at 3:30 PM
    #478
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    If it's heat related you guys should throw on a couple of heat sinks. Those so a back up job of dissipating heat.
    Addicore Raspberry Pi Heatsink Set for B B+ 2 and 3 set of three for $3.
    You could get fancier ones too that are probably way more effective that those.
  19. Feb 22, 2018 at 5:03 PM
    #479
    Opihi59
    Beyond Honolulu
    There's the big "if" for you. If it's heat related....... Well, nobody seems to know this information, and I haven't found any other posts documenting what the expected operating temperature range is on this unit (HPFP) other than my IR read of 149.5 degrees F. I measured a 152.6 degrees F off of a buddy's '16 Tacoma, and @shakerhood sent me a 92 deg F reading after driving his Tacoma but it was 35 deg F ambient then. @Tharris242 sent me a 140 deg F reading on his, @jsey21 sent me 131-140 deg F as well as a 100-115 deg F at about 60 F ambient. It seems to me that @over60 sent me info as well but I can't find it.
    So we don't know what we should be expecting temperature-wise on our HPFPs, Toyota doesn't seem to recognize this as an issue but if someone who knows the true expected operating temperature on these pumps and could post in some documentation, it could be helpful. At this point I'm approaching 7K miles and not hearing any chirps, and all my personal temp tests after a decent distance/running time show 150 deg F.
    This HPFP technology is not unique to our Tacomas, it's been used in Scion, and in Lexus, but I don't lurk on their forums so don't have input on what message traffic is going on over there.
  20. Feb 23, 2018 at 3:55 PM
    #480
    zonks12
    zonks12 Member
    Is their an after market hpfp available yet ...and did they use they same one for the 2018 if so are they going to have an issue too? im pissed my weather seal on my door is making sound on the freeway now.....and my hpfp is so embarrassing going through drive through s
