Abnormal Chirp or Squeak Noise from High Pressure Fuel Pump
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoFister, May 6, 2016.
  1. Mar 8, 2018 at 7:38 PM
    #481
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    well add another 3rd gen to the hpfp chirping in the engine, well see if my local stealership fixes it or give the standard...."normal operation" Sdie note: I heard switching gas sometimes fixes that....any thoughts. I typically use shell, so off to chevron it is.
  2. Mar 9, 2018 at 4:30 AM
    #482
    canadiangreentaco
    canadiangreentaco Active Member
    Brad
    2017 BBP Tacoma TRD
    I have a 17' and have had the issue from 3 months into ownership. Always use the same gas station and brand, Shell. If I use regular I get the chirp, if I use mid-grade or premium no chirp at all! I have done this test off and on every so often since I noticed the problem 13 months ago and every single time I put regular grade in it chirps at idle. I mentioned this to 3 different dealers in the area and they attributed it to "normal operation"
    I have since learned to live with just ensuring I use mid-grade/premium from the same gas station. I do notice that the truck has less hesitation on acceleration at low rpm using mid-premium grade as well.
  3. Mar 9, 2018 at 6:57 PM
    #483
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    I always use 91, shell. Switched to chevron 91, well see.
  4. May 30, 2018 at 12:07 PM
    #484
    Toyota09
    Toyota09 Well-Known Member
    2016 Tacoma TRD Off-Road Inferno
    I have a 2016 with almost 40k on it, and it just started chirping. So annoying. Back to the dealership later this month I guess- this truck is wearing me out.
  5. Jul 11, 2018 at 10:57 AM
    #485
    BozemanTaco
    BozemanTaco Well-Known Member
    Aaron
    Bozeman, MT
    2016 Inferno TRD OR Crew SB
    Had mine replaced at 25K and it is back at 40k
  6. Jul 11, 2018 at 11:14 AM
    #486
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Damn. I hope this doesn't happen to me. Mine was replaced 5k ago and I hear no chirps whatsoever anymore. Hope it stays...
  7. Jul 25, 2018 at 7:51 AM
    #487
    Rownan
    Rownan Well-Known Member
    Tim
    Highland, MI
    '17 OR DCSB 6MT *Quicksand*
    For those that have had the HPFP chirp, does it get more rapid with engine RPM? My idle chirp has just gotten a lot louder recently (almost 30k miles) and sounds a lot like the videos in this thread but mine seems to fluctuate as the engine winds up and down. Is that a sign that it's probably a pulley/belt/tensioner?
  8. Jul 25, 2018 at 8:23 AM
    #488
    Freegolf
    Freegolf Well-Known Member
    Denver
    2016 offroad, manual tran
    Mine went away with increased rpms. Chirp should only be audible at IDLE. IDLE.
  9. Aug 6, 2018 at 3:19 PM
    #489
    zonks12
    zonks12 Member
    Finally got toyota to replace the pump! Let me know if you guys need help i got the low down on how to make them change it for sure!!
  10. Aug 6, 2018 at 7:12 PM
    #490
    Opihi59
    Opihi59 Vulgar Boatman
    Beyond Honolulu
    2016 TRD Sport DCSB 6MT
    Unknown lift, maybe 2" I don't know how to ID it, and would rather set it back to stock.
    Well, don't keep it a secret...........
    shakerhood likes this.
  11. Oct 22, 2018 at 2:03 PM
    #491
    zonks12
    zonks12 Member
    pm me if you would like to know how i did it
  12. Sep 16, 2019 at 6:30 PM
    #492
    Don A
    Don A Active Member
    Don
    Barcelona Red SR5 4x4 Access Cab
    Well after paying extra for ethanol-free gasoline and Lucas additive for years ... and with only a few months of warranty left on my '16 i decided to fill 'er up with regular and went for a nice long ride to get it to full operating temperature and then drove it straight to the dealership (with the TSB # in hand) so they could hear that super annoying chirping in all its glory!
    Two mechanics had a listen and before you know it i was booked in for a new high-pressure fuel pump and i haven't heard the chirp since PLUS i have saved $$ by not having to search or pay for non-ethanol gas!!
  13. Sep 17, 2019 at 8:06 AM
    #493
    zonks12
    zonks12 Member
    Stop making yourself into a doormat! DO not put different gas in or anything! Make Toyota fix it! stop making excuses for there mistakes!
  14. Jan 17, 2020 at 4:49 PM
    #494
    KingZee
    KingZee Well-Known Member
    Z
    Los Angeles
    2018 TRD OR
    Bootleg Pro Grill / 16” SCS Ray 10 Black / 265/75/16 KO2s / Voodoo 10” Rack / DA Warrior XL
    Hey guys, I have a loud squealing/cricket noise coming from my truck. 3rd gen, TRDOR with 19k miles currently. I read through this thread and it seems to differ from the fuel pump issue because it’s not there during idle but increases during throttle. I thought I’d start by posting in here to see what you guys think? Pulley?
  15. Mar 9, 2020 at 7:25 PM
    #495
    Pine State
    Pine State Well-Known Member
    Maine
    2018 Tacoma DCSB SR5 4x4
    What did this turn out to be?
  16. Jun 4, 2020 at 6:56 PM
    #496
    BattlecryTaco
    BattlecryTaco Well-Known Member
    So Cal
    3rd Gen TRD Off Road DCSB
    The chirping has been coming and going ever so often on the 2017 TRD Off Road that I drive. It’s recently come back. It’s got close to 48K miles and I haven’t had the hpfp changed. I’m planning to try and get it changed out soon. With all of the successful replacements of the hpfp’s in these trucks, has anyone ever heard of why the hpfp’s chirp? I haven’t read all of the posts in this thread, but from what I have read, it seems to have something to do with perhaps the fuel being used having ethanol and or the temperature of the hpfp, fuel temp, or engine’s rpm. Wth, Toyota? Get your QC act together! The truck looks very silly going along chirping like a cartoon dog that swallowed a whistle.
  17. Jun 5, 2020 at 6:15 PM
    #497
    BattlecryTaco
    So Cal
  18. Oct 10, 2024 at 8:55 PM
    #498
    GawainXR
    GawainXR Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    I got this today. Normally get Chevron e89 but filled up from near empty with Shell e91. After 20 minutes or so I began to hear a subtle slapping noise from the engine bay I was working was detonation or knocking, which got a bit louder as I let the vehicle idle. After letting the vehicle idle for another 20 minutes or so it began to sound like there was a swarm of angry crickets under the hood.
    Does the TSB cover the 2020 year?
