Abnormal Chirp or Squeak Noise from High Pressure Fuel Pump
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoFister, May 6, 2016.
  1. Jul 7, 2016 at 4:41 PM
    #81
    Dhugh00s
    Dhugh00s Active Member
    Dustin
    Little rock ar
    2016 Tacoma dbl cab SR5 Inferno
    3 ready lift 20 inch rockstar2 with ko2 katzkin black with orange stitching and orange perforated inserts
    :fingerscrossed: Maybe it will go away I only have 2k miles if it hasn't by the first oil change I'll be getting a new fuel pump I can't have this badass looking truck sounding like a pos :poking:
  2. Jul 7, 2016 at 4:44 PM
    #82
    cabo wabo
    cabo wabo Well-Known Member
    billy
    virginia
    2019 dbc short bed trd sport
    I've noticed it on my Tacoma but not all the time.
  3. Jul 7, 2016 at 4:44 PM
    #83
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    My neighbor used to have a 1983'ish Chevy Chevette. That thing would squeal like a banshee when she started it up or took the corner around our neighborhood. I'd guess it was the power steering pump. Could hear her coming 2 blocks away. Made me chuckle thinking back about that...
  4. Jul 7, 2016 at 4:49 PM
    #84
    Dhugh00s
    Dustin
    Little rock ar
    :puke:o_OThanks smitty that makes me feel great
    smitty99 likes this.
  5. Jul 7, 2016 at 4:51 PM
    #85
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    Thank god it isn't as noticeable (if at all) with the windows up.
    Spent all this money on a nice catback only to pull up to a stoplight sounding like a bunch of baby birds :facepalm:
    trabo and smitty99 like this.
  6. Jul 7, 2016 at 4:53 PM
    #86
    Dhugh00s
    Dustin
    Little rock ar
    Maybe that explains the excessive bird feces on the hood
  7. Jul 7, 2016 at 8:08 PM
    #87
    TacoFister
    TacoFister [OP] Well-Known Member
    Josh
    2016 QS TRD 4x4 Off Road
    Mine also has a slight wobble. That however was not the chirp issue for me. The High pressure Fuel pump was the answer. I am almost at 15k miles here in Kodiak and still no chirp.
    jonnyozero3 likes this.
  8. Jul 11, 2016 at 10:18 PM
    #88
    Yzkiley
    Yzkiley Well-Known Member
    British Columbia, Canada
    2016 MGM Tacoma Sport DCSB MT
    rain guards, hood deflector, oem tonneau, BFG ko2's, led lightbar behind grill, highlift jack mount side rail, husky Xact front & rear mats, bedrug, AFE cold air intake with scoop, TB spacer, Spec U exhaust, Hikari - lumileds Led's, any time backup cam and gps, OV tune 103B, TRD pro grille, Cali raised pod fog lights, ECGS needle bearing, Bilstein 5100's, Low range offroad 3-1 level kit, SPC light racing ctrl arms, spidertraxx 1.25in spacers, Ride right airbags, clazzio seat covers, carrier bearing spacer, diff drop spacer.....
    Try putting 300ml of lucas oil upper cylinder lube fuel treatment in your fuel tank just before fill up and use highest non ethanol fuel you can get. It worked for my truck, had same chirping. It pretty much went away immediately. Known issue on Scion FRS and Subaru's. Just Google it known issue....
  9. Jul 11, 2016 at 10:27 PM
    #89
    Yzkiley
    The noise (as determined by Fuji engineers) is caused by cavitation (bubbles) in the high pressure pump with certain fuel blends in certain conditions. It makes sense to me that adding a lubricant to the fuel can affect the noise, as the oil changes the surface tension of the fuel making it less likely to foam up.
    The only potential downside is the additives may reduce the octane rating of the fuel, but 2 oz. per tank is negligible.
  10. Jul 12, 2016 at 12:41 PM
    #90
    TacoFister
    Josh
    Still not having the noise after the replacement. I just used whatever fuel I could get to on my journey north..
  11. Jul 12, 2016 at 12:44 PM
    #91
    Username:
    Username: I wear adult diapers at music festivals.
    CJ
    Pacific USA & Canada
    16 TRDS 6M w/ TRD Humidor
    "She's into malakas, Dino."
  12. Jul 26, 2016 at 8:01 PM
    #92
    Swat
    Swat Member
    Oregon
    2016 Silver Tacoma Off-road TRD DCLB
    I have the chirp. When I took it in for the tranny TSB they told me it was the fuel pump. I think it is interesting that some have the chirp and some don't.
    TacoFister[OP] likes this.
  13. Jul 26, 2016 at 8:25 PM
    #93
    TacoFister
    Josh
    Least it was noticed and troubleshot correctly.
  14. Jul 27, 2016 at 1:18 PM
    #94
    Yzkiley
    Okay, so I can absolutely confirm this issue. Today was my first fill up after initial treatment with Lucas upper cylinder fuel treatment. I filled up with Chevron 87 octane with tactrol which on the pump says also may contain 10% ethanol. I didnt have any chirps before this fill up right to empty after initial first teatment. Sure enough right after leaving the gas station and five minutes into drive, sitting at a stop light the chirps / crickets are in full force. I pull over at a safe spot and pull out the treatment and add 200ml. Guess what noise went away within 5mins. So my feeling is that its the ethanol or shit gas. Next fill up will be with 94 octane and no ethanol and then that should prove out that ethanol is the issue.
    trdgentaco likes this.
  15. Jul 27, 2016 at 10:41 PM
    #95
    TacoFister
    Josh
    You may be correct. Im honestly not sure. Putting in 94 octane is a waste IMO. All I can say is that I got my High pressure Fuel Pump changed out at 5k miles. I am almost at 14000 miles after driving across the world, using whatever gas was available and I still don't have any chirps......
  16. Jul 28, 2016 at 11:23 AM
    #96
    Swat
    Swat Member
    Oregon
    I found that my truck only chirps after it is good and warm. It never does it on first start up. Is this what others are experiencing, or do some have it on start up?
    trabo, Iroyal07 and Aussiek2000 like this.
  17. Jul 28, 2016 at 3:08 PM
    #97
    Yzkiley
    Mine was doing the same thing after warming up and more so if the weather outside is hot. Would be curious to know if anyone else has tried Lucas upper cylinder fuel treatment and if it worked for them.
  18. Jul 28, 2016 at 3:22 PM
    #98
    FirstTruck
    FirstTruck Member
    2016 TRD Sport 4x4
    I hear the chirping on 2016 TRD Sport. Doesn't make a difference if AC is on or off. If idling or coasting, the chirp is there. Press on gas, in P or D, chirping stops. Still thinking pulleys? I have no idea.
  19. Jul 28, 2016 at 3:23 PM
    #99
    FirstTruck
    FirstTruck Member
    2016 TRD Sport 4x4
    Yes SWAT, I don't hear it at first. After 5-10 minutes of driving around town, I start hearing the chirp.
    Iroyal07 likes this.
  20. Jul 28, 2016 at 6:21 PM
    #100
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    I only hear it after the truck has sat for a couple hours. Makes noise as I'm pulling out of sparking spot. Then I never hear it again
