Abnormal Chirp or Squeak Noise from High Pressure Fuel Pump
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoFister, May 6, 2016.
  1. Jul 28, 2016 at 7:10 PM
    #101
    TacoFister
    TacoFister [OP] Well-Known Member
    Josh
    2016 QS TRD 4x4 Off Road
    Yupers
  2. Jul 28, 2016 at 7:10 PM
    #102
    TacoFister
    Josh
    No...... Its your High pressure fuel pump.. read the past posts
  3. Jul 28, 2016 at 7:11 PM
    #103
    TacoFister
    Josh
    Just get your High pressure Fuel pump changed out..
  4. Aug 7, 2016 at 5:15 PM
    #104
    skipatrol2219
    skipatrol2219 Member
    I had the field rep look at it,
    Said it was a normal noise......
  5. Aug 7, 2016 at 5:31 PM
    #105
    TacoFister
    Josh
    Nope.. is I making a chirp or tick? Tick is normal, chirp is not.
    jonnyozero3 likes this.
  6. Aug 7, 2016 at 10:30 PM
    #106
    Rramv1416
    Rramv1416 Well-Known Member
    SO CAL
    2016 DCSB V6 SR5 BLACK w/Tow
    What is the chirp noise? I just started hearing this noise yesterday. When the engine revs a little it goes away. I even made a thread and no one knew what was happening. The "chirp" is exactly what it sounds like though.
  7. Aug 7, 2016 at 10:35 PM
    #107
    Swat
    Swat Member
    Oregon
    2016 Silver Tacoma Off-road TRD DCLB
    It is most likely a high pressure fuel pump. The question remains whether it should actually make the chirping noise. Toyota says the sound is normal, but not all Tacomas develop the chirp.
  8. Aug 7, 2016 at 10:55 PM
    #108
    Rramv1416
    SO CAL
    I have the Chirp. The tick doesnt bother but this chirp sure does. Is it an immediate thing I need to takeit in for?
  9. Aug 8, 2016 at 1:53 AM
    #109
    TacoFister
    Josh
    Guys. Just watch my video. I've gotten the High pressure fuel pump and the sound is gone.
  10. Aug 8, 2016 at 6:06 AM
    #110
    gwozdz
    gwozdz Member
    Way Upstate New York
    2016 SR5
    I have been experiencing a loud ticking/rattling sound which gets louder with acceleration. While looking under the hood I noticed that the upper idler pulley was wobbling. After shutting off the engine, I grabbed the pulley and it had play and I could wiggle it. It was also very hot. On Friday, on my way to visit my brother, I took my 2016 Tacoma SR5 to a dealership on my route. They replaced the pulley and the new one did the same thing. No change, no difference with the noise. My rattle noise is quite loud, but I wouldn't call it a chirp. Should that pulley have play and wobble? And be hot to the touch? No 2016 Tacoma owners where I live (Adirondacks), so I have nothing to compare with. Nearest dealer is 60 miles away.
  11. Aug 8, 2016 at 6:22 AM
    #111
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    I have had the top pulley replaced and it still wobbling but no noise yet on this one
  12. Aug 8, 2016 at 6:48 AM
    #112
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Pulley shouldn't wobble, noise may come back
  13. Aug 8, 2016 at 6:56 AM
    #113
    whopper
    wayne
    north carolina
    On going
    Yes sir I told the dealer the same thing. He said just keep and eye on it he hopes enough people complaining will get a T-SB for a fix!
  14. Aug 8, 2016 at 7:05 AM
    #114
    The hammer
    I didn't know many ppl had that, how is the wobble compared to the other pulleys?
    All pulleys wobble as everything has tolerances, but it's not that noticeable to most folks, in other words, its tolerable.
    But as long as everything or all the other pulleys line up straight and correctly they don't wobble and your serpentine belt will last to its full.
    You may want to ask your dealer to check pulleys for proper alignment.
    Hope that helps
    Cheers!
  15. Aug 8, 2016 at 7:14 AM
    #115
    whopper
    wayne
    north carolina
    On going
    We checked 5 trucks on the lot ever one of them wobble.
    The top pulley above the A/C compressor
    The hammer likes this.
  16. Aug 8, 2016 at 7:24 AM
    #116
    skipatrol2219
    It is the high pressure pump,it is a chirp.
    I am a master cert tech for another car line.I would have put a pump in it the first time I brought it in.
    When I told them I was a tech and a shop foreman,they didn't want to hear it..
    I am almost tempted to put one in myself
    The hammer and whopper like this.
  17. Aug 8, 2016 at 7:31 AM
    #117
    The hammer
    OK you got me, you made me go check mine out! lmaoo!
    And yes I can verify it does have a little wobble to it, but pulley alignment is fine and the belt wear mark is right on center so I don't think there should be anything to worry about.
    It's also at a good easy to replace location unlike the one at the bottom by the oil cooler, that one's not so good a location but no wobble at all.
    Hope that helps
    Cheers!
  18. Aug 8, 2016 at 7:34 AM
    #118
    whopper
    wayne
    north carolina
    On going
    Yes belt runs true but that wobbling make me wonder if the bolt just doesn't tighten up enough to stop it from walking around a bit. This would cause premature bearing failure in my opinion
    The hammer[QUOTED] likes this.
  19. Aug 8, 2016 at 7:43 AM
    #119
    The hammer
    I don't think so, I have seen much worst on other new vehicle makes.
    I Hope we're not on that path with all the chirping noise b/s! :confused:
    Either way I have confidence we'll work things out here at TW if it should ever get to that with our awesome Taco brotherhood
    Cheers!
  20. Aug 8, 2016 at 7:58 AM
    #120
    The hammer
    I think other makes are/have experienced the noise on the high pressure fuel pump also. But the noise does not appear to be universal and comes under different conditions. :confused:
    Looks like they need to improve on the manufacturing of these things as there appear to be some bugs.
