Abnormally bad gas mileage?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JustADummyInATaco, May 1, 2015.
  1. May 1, 2015 at 5:44 PM
    JustADummyInATaco
    JustADummyInATaco [OP] Active Member
    Riley
    UTAH
    06 sr5 driven by noob
    6" Procomp Coilover lift, 18 inch motometal wheels, too small of tires, magnaflow exaust, highly illegal tint, poser TRD off-road stickers, TRD intake, NFAB nerf bars, lots of love.
    Okay Tacoma world guys I've got another question for you. So I have been trying to save gas lately, and I have been trying my absolute best to keep my foot off the pedal. I have been driving like a grandma everywhere I go, never letting it there at tachometer go over 2000 RPM. I got only about 280 miles off of my most recent full tank which I think translates out to about like 10 to 14 miles to the gallon. I have 285/65R18's A TR D intake and a magna flow exhaust, on a 6 inch lift. What it what would it possibly be causing my mileage to be so for? Is it simply because the V-6 can't handle the size of the tires and a lift?
  2. May 1, 2015 at 5:47 PM
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    Lift and tires. you are now a rolling brick haha that and since our trucks don't have excessive power they lose mpg faster.
  3. May 1, 2015 at 5:51 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Did you calculate the odo difference because of the larger tires? 285s cause about a 7% difference in your speedometer/odo. so multiply your 280 miles by 1.07 and you get an actual number of 299.6 miles. now redo the math... the 7% difference is assuming your stock tires were 265s.
  4. May 1, 2015 at 5:53 PM
    JustADummyInATaco
    Riley
    UTAH
    So if I like my truck tall and mighty, is there anything I can do to make it a little better? Mass airflow sensor calibration? Supercharger? Injector cleaners?
  5. May 1, 2015 at 8:25 PM
    Josh828
    Josh
    Avery NC
    Nothing you can really do if your trying to save money by getting better gas mileage, there are things you can do that just barely help but you would never recoup the cost.
  6. May 2, 2015 at 4:21 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    How are you calculating your mileage. If your getting 280 miles when the fuel light comes on that's about 16.5 mpgs. 280 miles ÷ 17 gallons = 16.47 miles. The light comes on with about 3-4 gallons left. To calculate you should: Fill the tank, set the odometer to 0, drive, refill at some point, divide miles driven into gallons used to refill tank. That will give you the exact mileage you're getting.
  7. May 2, 2015 at 4:33 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    tire size!
  8. May 2, 2015 at 5:55 AM
    Justn868
    Justn868 Well-Known Member
    Justin
    Kansas City
    14 4x4 TRD OR
    If it is gas milage you are concerned about, you should have purchased a Prius instead of a Taco with a 6" lift and 285s...
