Abnormally Terrible Gas Mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andrewlaf, Apr 2, 2014.
  1. Apr 2, 2014 at 6:49 PM
    andrewlaf
    andrewlaf [OP] Member
    Andrew
    Vancouver
    09 PreRunner SR5
    Been a member since I bought my Tacoma last November but this is my first post because I'm a tad lost.
    For the last 3 tanks now my fuel consumption has been terrible compared to previous tanks. I'm getting 25 liters per 100kms. Roughly 300kms per tank and that's just not good.
    Within the last month to two months I was bringing her up to speed; New iridium plugs, oil change with AMS (along with both diffs and transfer case), and a new drop in k&n air filter. Tire pressure is fine, no check engine light, so what do I do next? O2 sensor? Purge the injectors? Fuel pressure?
    Appreciate any info or tips
  2. Apr 2, 2014 at 6:51 PM
    andrewlaf
    Andrew
    Vancouver
    09 PreRunner SR5
    Oh and that's my Tacoma.
    2009 TRD
  3. Apr 2, 2014 at 6:52 PM
    JohnNP
    JohnNP ForeRunners Future Wife :)~
    Hobe Sound, FL
    2014 DCSB 4x4 TRD Sport JBL
    As of 11/4/15 1) Tailgate Anti-Theft Mod 2) ND4SPDBP's Fog Light Mod 3) Devil Horn Emblem 4) Weathertech Digital Floor Liners 5) ADD W-1 Vers 2 Baffled Oil Catch Can- constantly surprised at how much oil this thing captures 6) Weatherproof Under the rail LED bedlights Warm White (by Mattgecko) with hidden small cubby switch 7) Sliding Window Security Bar 8) Hood Lighting Kit Warm White /Pro Kit (by BeeRad) 9) Morimoto mini D2S retrofit HID lights w/ 55W ballasts and XB 5000k bulbs from TRS- one of the best modifications I have ever made, blows the stock lights out of the water 10) ImMrYo bracket 11) Scangauge II 12) Autodimming mirror w/ Compass/Temperature/Homelink 13) Bedrug Mat and Tailgate rug. 14) Pop n Lock Power tailgate lock w/ bolt coded to factory key. 15) Map Light w/ Door Mod 16) BakFlip HD Tonneau Cover 17) 35% Front windows ceramic tint - a very good match to factory 19) Gerber machete, because every truck needs a machete 20) Various flashlights, really love my Black Diamond Miner Mole Headlamp 21) AFE Pro Dry drop in filter 22) removed secondary charcoal air filter 23) Back up light Mod- I used the light bulb as found on page 14, 35W from Lowes. https://www.tacomaworld.com/threads/886-backup-light-mod.209578/page-14 24) Hi-Lift Off Road Recovery Kit- thank you TW Secret Santa 25) Tailgate Seal 26 interior footwell/rear seat dome light controlled LEDS https://www.tacomaworld.com/threads/footwell-and-rear-seat-led-light-dome-switched-mod-lots-of-pics.409428/#post-11529460 27) pelfrybilt aluminum front skid 28) morimoto XB fog lights 29) mob town front recovery bar with 2 Smitty bilt D-Rings 30) 48" Extreme Hi-Lift Jacks w/ ATO rail mounts 31) Prinsu rack 32) Rigid D2 Ditch lights 33) 40" Heretic LED bar on Prinsu Rack 34) Kawell x 6 side lights 2 spot and 1 wide per side 35) Rigid SRQ2 x 2 rear facing asshole/backup lights 36) NSA switch panel to 150amp bussman fuse on custom made mount 37) 267/70/17 BFG KO2's in C rating Pending installation 1) Rock Lights Upcoming/Possible Mods 1) Katzkin Leather Seats in black/ice grey (supposedly better factory match for the 2014) w/ Degreeze heater/cooling and TRD stitched into the seat faces thru jhuey - once I get to Arizona will buy them and have him install them 3) Total chaos UCA's 4) Kinda want to get some of the 2016 TRD Sport Rims or the grey TRD wheels the FJ cruiser/4Runners have. 5) BAMF LCA Skids 6) ICON or KING coilover 8) BAMF hidden grill light mounts 9) 20" or 30" LED light by Rigid Industries for behind the Grill. . 10) full leave pack maybe the Deaver 10 leaf set 11) ? Warn m8000 winch- really depends on if I end up doing more off roading 12) Possibly a console vault, not entirely convinced those are as secure as they would have you believe.
    Go to the top of the page. Click on mods/tutorials then go to improve gas mileage
  4. Apr 2, 2014 at 7:54 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    What brand and model plugs
    Also what gap did you set them to?
    The K&N filter is useless to put it nicely. If it was over coated with oil it can contaminate your MAF and would need to be cleaned.
  5. Apr 2, 2014 at 8:31 PM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    OP, do you have fill-up receipts with what the odometer was at when you went to the pump? For those in the USA... OP is reporting 9.5mpg which I've never heard of. Really doubting the math. Open up a fuelly account (banner below) as I find it's the best way to accurately track fuel usage.
    Like others have said, stock air filter is probably the best medium you'll get. Spending more money on more expensive filters is just a waste of cash. Also don't rely on the TPMS and check your tire pressure with a gauge to be sure they aren't running low (could be low just not low enough to set off the warning). How fast are you driving? Going over 105kph you really start to see a decline in economy.
  6. Apr 2, 2014 at 9:07 PM
    andrewlaf
    Andrew
    Vancouver
    09 PreRunner SR5
    Thanks guys.
    NGK iridium plugs
    How would one clean the MAF sensor?
    As for speed, all city driving, 50- 80 kms an hour.
    I went to fill the tires up the other day, used a gauge, they were perfect.
    I was thinking about filling up the tank, driving 100kms and then filling up again to see exactly how many liters I used. Thought maybe the truck isn't giving me the right reading of my mileage.
    I'll look into opening one of those accounts too.
  7. Apr 2, 2014 at 9:35 PM
    ziggynagy
    Stoughton, MA
    Your mileage would be correct, but the fuel gauge is just an estimate and useless for determining fuel economy. If you don't go the fuelly.com route:
    1. Fill up your tank, write down the current odometer on the receipt/paper. Don't top off the tank, just fill-up and let the pump auto shut-off.
    2. Next time you fill-up write down how many litres pumped and current odometer.
    3. Calculate L/100km (#litres/#km)*100
    4. Repeat 2. and 3. for 3x fill-ups (full tank, no top off) and see how you fair.
  8. Apr 2, 2014 at 10:36 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Cold weather is one cause.
    Has your gas stations recently switched to 10% ethanol? Ethanol is bad for mileage and power.
  9. Apr 3, 2014 at 2:21 AM
    ZEROPILOT
    ZEROPILOT Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    Has the power backed off? Could your CAT Converter be plugged?
  10. Apr 3, 2014 at 3:22 AM
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    Get rid of the KN filter and stick with stock filter for air. The plugs should be those recommended by Toyota.
  11. Apr 3, 2014 at 3:23 AM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    pretty sure all 87-92 oct in Canada contains 10% ethanol, only chevron 94 is contaminant free!!!
    also its Vancouver it don't get cold it just rains :p lol
    If your're not throwing any codes I'd check to see if your cat is plugged being emissions exempt means a lot of newer cars don't have those systems checked often. like previously mentioned if you're way down on power thats probably the reason!!!
  12. Apr 3, 2014 at 7:07 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If you are correct at 9MPG you got a leak some where!
  13. Apr 3, 2014 at 7:27 AM
    Ehc0720
    Ehc0720 Active Member
    You driving in too low of a gear, that is in 4 and not D?
  14. Apr 3, 2014 at 11:21 AM
    GreatCanadian
    GreatCanadian Well-Known Member
    Newfoundland
    SR5 4X4 V6
  15. Apr 3, 2014 at 4:38 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
  16. Apr 3, 2014 at 5:21 PM
    andrewlaf
    Andrew
    Vancouver
    09 PreRunner SR5
    How can you tell if your cat converter is plugged? or how can you unplug it?
  17. Apr 3, 2014 at 5:23 PM
    andrewlaf
    Andrew
    Vancouver
    09 PreRunner SR5
    I do switch from 4 to D in the city. I just figured with Vancouver being so hilly that cruising at 30 - 50 kms an hour in D puts too much strain on the vehicle.
  18. Apr 3, 2014 at 5:25 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Shell V Power 91 is still ethanol free in Canada
  19. Apr 3, 2014 at 5:28 PM
    OZ-T
    Peter North
    British Columbia
  20. Apr 4, 2014 at 1:37 AM
    ZEROPILOT
    ED
    SUNRISE,FLORIDA
    It might not be practical with EFI. I don't know what codes your truck will throw, or how it would run. But there is a thing called a "test pipe" that you can install temporarily in place of the cat to see if it is better without it. But I simply haven't used one since about 1978, honestly. If it were me, I'd find an honest muffler shop and tell them my symptoms. Maybe they have a way to test it, or at best can steer you in the direction of a cheaper replacement. If it is the cat, it can not be "unclogged". It can be hollowed out, but, you don't want to do that.
