About 25K miles from the stock Dunlops?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BuddyS, Oct 20, 2016.
  1. Oct 20, 2016 at 7:11 AM
    BuddyS
    BuddyS [OP] Well-Known Member
    Maryland
    2013 TRD Sport 4x4 MT
    I was fine with the stock Dunlops on my 2013 since most of my driving is highway, but at 25K I found that they were spinning a bit when taking off from a stop in the wet and even let the tail kick out a bit on fairly moderate wet corners. Is this about right for these unloved tires? The tread still looks decent and I was expecting to get 50K or so from them, but maybe it's age/rubber hardness that's catching up with them?
    Is the above typical of other's experience with the Dunflops?
    PvilleJohn likes this.
  2. Oct 20, 2016 at 7:12 AM
    PvilleJohn
    PvilleJohn SVT Raptor
    Powdersville SC
    SVT Raptor
    No, I had 20k on my 2015 with the Dunlops and they still looked pretty new.
  3. Oct 20, 2016 at 7:14 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Mine were bald at 21k miles, stock truck, no extra weight, and all highway use.
    Regularly rotated, proper inflation.
  4. Oct 20, 2016 at 7:14 AM
    PvilleJohn
    Powdersville SC
    SVT Raptor
    My wife's 2012 Camry we bought new and only got 25 out of those tires...and they were Michelin. Toyota told us that the stock tires do not last as long as replacements. Even if I were to go buy the same Michelin tire that came on it, the replacement tire would last longer??? Not sure why but that's what I was told by numerous Toyota techs.
    We're at 32k on my wife's 2015 4Runner and we probably have another 10k left in them
  5. Oct 20, 2016 at 7:15 AM
    BuddyS
    Maryland
    That's the thing... they still look pretty new at 25K but they seem to be getting slippery in the wet. Not very confidence inspiring.
  6. Oct 20, 2016 at 7:16 AM
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    IMOP, They are junk!, I dumped mine at 25k, I was very surprised that Toyota (although they all do it) put such junk tires on a vehicle.
    NAAC3TACO and PvilleJohn like this.
  7. Oct 20, 2016 at 7:16 AM
    T4RFTMFW
    I've heard OEM tires are built to a price point and aren't the same construction/compounds as the "same" tire not installed at the factory.
    Cant say it's true or false, above my paygrade.
  8. Oct 20, 2016 at 7:20 AM
    PvilleJohn
    Powdersville SC
    SVT Raptor
    I agree with ya, they are junk. My 2016 has Goodyear Wrangler a/t so we'll see how they do until I get the lift and new tires
  9. Oct 20, 2016 at 7:35 AM
    hobiecat111629
    hobiecat111629 Well-Known Member
    2015 Tacoma Access Cab
    I've got 26k on my 2015 and am noticing the same behavior
  10. Oct 20, 2016 at 9:20 AM
    SoCalSteve
    SoCalSteve Sunshine Tax
    San Diego
    2017 F150 XLT
    About right for stock tires. 20 to 30k and they're done.
  11. Oct 20, 2016 at 10:02 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    I experienced this too, I got about 35k out of mine. The tread looked like new yet when I would make a u-turn or drove in the rain, it would slip. I replaced my tires with hankooks which am much happier
  12. Oct 20, 2016 at 10:04 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Dunlop and hydroplaning are synonymous
    Mush Mouse likes this.
  13. Oct 20, 2016 at 10:29 AM
    BuddyS
    Maryland
    Cool, thanks for all the replies and affirmations!
  14. Oct 21, 2016 at 7:50 AM
    jmgtp
    jmgtp Well-Known Member
    2013 2.7 4x4 5sp
    None
    Just replaced mine at 38k. They had some tread left but I too noticed them losing traction on mild acceleration and turns.
  15. Oct 21, 2016 at 7:53 AM
    big_jarv
    big_jarv Well-Known Member
    2020 TRD Pro
    I sold my truck with 19k miles and my dunlops were just about ready to be replaced.
    They were garbage tires.
  16. Oct 21, 2016 at 7:55 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    It's because the tires don't have full-depth siping in the tread blocks. Sipes act like fingers when it comes to a tire gripping the road. Once you wear down through the siping and are left with full tread blocks the tires aren't able to channel water as efficiently, which is why you're experiencing slipping now. They aren't worn out, technically, but they definitely won't perform as well as they did when they were new. :notsure:
    However, it's not just the stock Dunlops that are like that; partial-depth siping is very common across the entire industry, since full-depth siping can contribute to a 'squirming' feeling while you're driving since they allow more movement from the tread blocks themselves. Also, tire manufacturers cut sipes of varying shape and depth to help control noise from the tires, since full-depth siping creates more road noise.
    Edit- More in-depth article about siping, if you're interested:
    http://www.tirereview.com/sipes-deserve-credit-for-tire-traction/
  17. Oct 21, 2016 at 8:28 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Got about 37k out of oem Dunlops (not quite down to wear bars), and they were poor in the rain from day 1. Maybe Toyota used them for higher mpg in addition to the price point. Much happier with Michelin MS2's with 70,000 mile warranty, especially in the rain.
  18. Oct 21, 2016 at 8:49 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    My '15 Tacoma PreRunner 6 cyl came with Dunlop AT20 Grand Trek P245/75R16 tires. Truck presently has just over 19K on the odometer. The tread wear is OK for 19K, but it's obvious these are not long-wearing tires. I don't live in a place where rain fall is common, but when it does rain, I'm inclined to take more caution. To date, I've had just one scary situation on wet pavement with these tires, but it got my attention.
    One of these days I'll replace them, just not sure yet what I'll replace them with. The truck is 2WD and spends 90% of it's time on the highway. No off-roading.
  19. Oct 21, 2016 at 8:57 AM
    dedmouse
    dedmouse Well-Known Member
    Dammit
    South Central Missouri
    2010 Black Tacoma Base, 6 spd manual tranny, V6.
    My dealer put Dunlop AT20's on my 2010 before I took delivery. I have about 4500 miles on them. I'm hoping they will take me through a NH winter and then next year I will be looking for some decent tires to put on my Taco. I used to run BFG T/A KO's on my Wrangler and really liked them. Not sure how they will play on my Taco.
    This winter I will be doing some research as to other choices I have. I do about 75% hard surface driving and the rest off road.
  20. Oct 21, 2016 at 9:17 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Mine came with the BFG Rugged Trails... I think Toyota puts on the cheapest POS tires they can get away with. Got rid of the Rugged Fails at 15,000 miles and went with BFG KO A/T's... every set of them I've owned (about 5 sets) averaged 60-70,000 miles.
