About back spacing..
Discussion in '1st Gen. Tacomas (1995-2004)' started by LostCoastGen1, Dec 19, 2013.
  1. Dec 19, 2013 at 8:27 PM
    LostCoastGen1
    LostCoastGen1 [OP] Well-Known Member
    Walker
    Eureka, CA
    '00 Tacoma 4x4
    Projector headlights, flowmaster 40 series muffler, deckplate, a lot to come!
    I'm curious about back spacing on wheels. I have 31/10.50/15 cooper discoverer S/T's on stock suspension. I want a wider stance but I want to know if there are any risks/ things to consider about lower backspaced wheels. Thanks y'all's bunches :D
  2. Dec 19, 2013 at 9:22 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    How much BS are you talking about?
    Usually, as you move the wheel center outboard, you increase the potential for a tire rub on the pinch weld, the area behind the mud flap. However, 31's on stock may not be an issue. Especially if it is only on the street.
    Now if your front coils are sagging a bit and you are planning on flexing out on a trail, then you may see rubbing...depending on how much you increase the backspacing over stock.
  3. Dec 19, 2013 at 9:26 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    I've run 265/75r16s on 16x8 rims with 4" BS and had no issues of rubbing on the pinch weld. (That was with an OME lift.) 4" BS is as low as I've gone though.
  4. Dec 20, 2013 at 10:04 AM
    LostCoastGen1
    Walker
    Eureka, CA
    '00 Tacoma 4x4
    Thanks you guys, my suspension is looking tired so I'm gonna opt to upgrade that first. Thanks for the info though!
