? about Budbuilts
Discussion in '1st Gen. Tacomas (1995-2004)' started by 01tacoprerunner, Nov 29, 2010.
  1. Nov 29, 2010 at 7:04 PM
    01tacoprerunner
    01tacoprerunner [OP] Lifted 'n Locked 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner with No-slip locker
    4WD Conversion, No-slip locker, 5100s set at 2.5" and shackles in the back. Black 2nd gen rims, and Courser M/T tires, Bull Bar,Fog lights, UWS toolbox, CB Radio, Fiberglass antenna, 2nd Gen Badges, Deck Plate Mod, Diff Breather Mod, Sockmonkey decals.
    Do they come with extended bolts for attaching it at the front and in the middle?
    I got mine from a guy for free, and i cant get it attached, i got the bracket attached to the rack and Pinion, but i cant get my orignal bolts to catch on the front an middle.
  2. Nov 29, 2010 at 7:54 PM
    01tacoprerunner
    Brian
    Raleigh, NC
  3. Nov 29, 2010 at 8:50 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    I only have the front piece of the two pieces, but the bolts he sent with it for the front attachment really aren't all that long. Maybe an 1" - 1.5". They are grade 8 bolts as well.
    The bolts just fit right in the screw clips that were already on the vehicle. Could you take a pic of what you're trying to do? Maybe you have something wrong.
    Does your skid plate look like the ones pictured http://www.budbuilt.com/new/tacoma.html
    Really, if you got the bracket on the steering rack on ok, there's only one place that it can bolt on. I just use my floor jack to lift it up and screw everything in. (a racheting wrench helps a ton for the bolts that attach to the rack bracket since theres no room for a socket)
  4. Nov 30, 2010 at 9:00 AM
    01tacoprerunner
    Brian
    Raleigh, NC
    Yea i have that first picture on that page. I was using a floor jack, but i dont have the bolts which came with the skid plate to use for at the front, so im gonna go out and pick up some longer grade 8 bolts to use for the front part. Plus mine is Line-xed which makes it a little thicker than it normally would be.
