? About front brake lines
Discussion in 'Long Travel Suspension' started by BMiller421, Aug 5, 2011.
  1. Aug 5, 2011 at 11:12 AM
    BMiller421
    BMiller421 [OP] FMLYHM
    Brandon
    Bakersfield, CA
    05 Pre-runner
    LT, Kings, Fabricated Trucks Worldwide For The Win, K&N and Doug Thorley LT Headers
    I'm in need of some new brake lines..
    Looking for braided stainless steel..
    Where can I find a decent set that will accommodate the travel from the lt kit?
    The ones that came with my engage kit get destroyed. So I want to try to get a pair that are 6" longer than what came with the kit..
    Thanks in advance..
  2. Aug 5, 2011 at 6:09 PM
    Socalrunner
    Socalrunner Toyota Its Like A Jeep Thing Only Better
    Glendora
    2010 TRD Offroad 4x4 DCSB
    Icon Coilovers
    They got destroyed because you had the basica kit before then added the race spindle. Mine are 24 inches long
  3. Aug 5, 2011 at 7:29 PM
    BMiller421
    Brandon
    Bakersfield, CA
    05 Pre-runner
    Mine got destroyed cus the little tubing coming off of the caliper bent towards the rim..and rubbed a hole through the actual line..
    So I want something tougher..like stainless steel..so hopefully a little tire contact won't destroy it..
  4. Aug 5, 2011 at 7:29 PM
    BMiller421
    Brandon
    Bakersfield, CA
    05 Pre-runner
  5. Aug 5, 2011 at 8:34 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I got mine here- http://www.wheelersoffroad.com/05uptacomabrakes.htm
    I also went with drilled and slotted rotors and porterfield racing carbon kevlar pads. I can lock up 37's with them, pretty good brakes, and the stainless lines don't swell under pressure so you get better pedal feel.
  6. Aug 5, 2011 at 9:31 PM
    BMiller421
    Brandon
    Bakersfield, CA
    05 Pre-runner
    I think i'll get a set of those brake lines..wheelers has never disappointed..
  7. Aug 5, 2011 at 9:35 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Yeah and NO TAXES! lol. The trick to making the lines last is zip-tie engineering so they don't rub on anything.
  8. Aug 10, 2011 at 3:32 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Engage gave you rubber brake lines??
  9. Aug 10, 2011 at 5:33 PM
    BMiller421
    Brandon
    Bakersfield, CA
    05 Pre-runner
    I'll take a pic in a few minutes..
  10. Aug 17, 2011 at 8:51 PM
    Deanthemachine
    Deanthemachine Well-Known Member
    07 Prerunner
    hey B. I think I had that same problem. did they pinch at the hardline that goes to the caliper?
    edit:
    I lied. I see what your talking about now. my hardline got pinched at the part that screws into the actual caliper
  11. Aug 17, 2011 at 9:10 PM
    BMiller421
    Brandon
    Bakersfield, CA
    05 Pre-runner
    The same thing happened to mine..so the hard line bent in towards the wheel..running a hole in the line from wear on the tire..
  12. Aug 19, 2011 at 8:33 PM
    Deanthemachine
    07 Prerunner
    So you can run a soft stainless braided line to the caliper? I was informed by hassim at engage you can only run an oem hardline to the caliper due to the fitting inside not sealing right when you tighten it
