? about my "new" 08
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hardtaco, Nov 23, 2010.
  1. Nov 23, 2010 at 9:00 AM
    hardtaco
    hardtaco [OP] Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    I picked up a certified pre owned 08 dcab PreRunner SR5 yesterday, and have a question about the climate controls. I ran defrost this morning (with ac compressor), and couldn't get the recirculate to activate. The dealership is telling me that the recirculation mode can only be used in AC, and not while using defrost. In my 04, I could recirculate air while in defrost. Stumped................
  2. Nov 23, 2010 at 9:11 AM
    BBBsti LTD
    BBBsti LTD Well-Known Member
    Ashburn, VA
    2010 TRD Off Road 4WD
    Yep. The dealer is correct
  3. Nov 23, 2010 at 9:14 AM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    This is not quite right. I'm pretty sure it works even if the AC is off. After all think dusty roads. It's in the manual. It does turn off though if you select defrost.
  4. Nov 23, 2010 at 9:29 AM
    ec8
    ec8 Newby
    Stuart
    Can recirculate vents with a/c off
  5. Nov 23, 2010 at 9:34 AM
    mmadej87
    mmadej87 Mayday
    NMB, FL
    98 Xcab Prerunner
    you CAN recirculate with a/c off, but you CANNOT recirculate with it in the defrost setting, im thinking that the recirculation draws air from the defrost vents...
  6. Nov 23, 2010 at 9:37 AM
    BBBsti LTD
    Ashburn, VA
    I will check with my 2010 later. I know that my AC acts weird when in defrost mode. Also if I put it in the hottest setting I know it turns something off, which I thing is the recirculation mode, I can't remember now.
    I know that he AC acts different than other cars that I have owned.
