? about rims, BS, tire size
Discussion in '1st Gen. Tacomas (1995-2004)' started by preCHRIS, Feb 20, 2012.
  1. Feb 20, 2012 at 10:00 PM
    preCHRIS
    preCHRIS [OP] Member
    Huntington Beach, CA
    02 PreRunner XCab
    I have an 02 prerunner 2.7 on 16" prerunner wheels and 265/75/16 tires.
    I'm looking to restore some power back into it because it's slow (ha)
    I want to get 15x7 procomp steel wheels but what backspacing should I get so the wheels will clear the caliper?
    i have 5100's in front at max lift (2.5")
    i want to maintain a some what aggressive look.
    will 255/75/15 be ok?
    thx
  2. Feb 20, 2012 at 10:09 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    to get back to stock MPG, i would consider going with a shorter tire, not narrower...
  3. Feb 21, 2012 at 12:24 AM
    Anthony250
    Anthony250 Fabricator
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    If you want to save mpgs dont get steel wheels. Stick with a 265/75/16 size or smaller.
  4. Feb 21, 2012 at 9:09 AM
    preCHRIS
    02 PreRunner XCab
    wouldn't a narrower tire reduce grip therefore require less power to "push" forward?
    thats the theory for us mtb'ers hah
  5. Feb 21, 2012 at 9:18 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    yah, i know that concept works for bikes... i ride a chopper bike so im always hurting... hahaha...
    on a truck, the overall circumference of the wheel/tire impacts it as well... there is a technical explanation for it, but i can't remember it...
  6. Feb 21, 2012 at 9:20 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
  7. Feb 21, 2012 at 9:26 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    found this too...
    "The experts, however, offered a word of caution lest truck drivers assume they should switch to smaller tires:
    It is probably not worth switching to smaller tires, since any gains in fuel economy would be offset by the added cost of re-gearing to keep your engine operating in its most efficient rpm range. Remember, power and economy are affected by transmission, drive axle ratios and tire size (revolution per mile). Change one, and you throw the equation off. With today’s new tires, there is virtually no difference in mpg due to tire size."
  8. Feb 21, 2012 at 8:55 PM
    Cvd2312
    Cvd2312 Well-Known Member
    Cory
    Oregon
    97 Tacoma 3.4L
    Bilstein 5100's all the way around, 2" shackles in rear, front diff drop, 32x11.50.15 BFG A/T, 15x8 Ultra 164 Wheels
    Don't get steel wheels, they're heavier. And I doubt you will gain much mpg by going smaller than 265. My truck had 235/75/15 on it when I bought it, and I got the same mileage even after I upsized to 265.
    If you want mileage, buy a Civic.
