? about tacoma lean
Discussion in 'Suspension' started by jason1kyle, Jan 19, 2010.
  1. Jan 19, 2010 at 7:47 AM
    jason1kyle
    jason1kyle [OP] commander101
    JOHNSON CITY, TN
    08 double cab trd sr5
    77 series k&n 1inch throttle body spacer dual in single out catback exhaust (exhaust pros)
    ok i keep seeing random comments about a tacoma lean what is that does the truck lean to one side or the other or something????
  2. Jan 19, 2010 at 7:49 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    the Tacoma lean is a slight lean to the drivers side.
    Then there is the cali lean to the rear. :laugh:
  3. Jan 19, 2010 at 7:49 AM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    Yeah for some reason it seems to be leaning to one side and OME make a 5mm spacer to put on your shock to compensate for that lean.
  4. Jan 19, 2010 at 7:49 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    yea...when you install a lift on the front end sometimes it'll have a lil lean...its usually fixed by adjusting your coil overs (if their adj.) or adding a top plate spacer :)
  5. Jan 19, 2010 at 7:51 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I believe it's because the driver, battery, and gas tank are all on the same side.
  6. Jan 19, 2010 at 7:54 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    ^^Yea, OP fill your tank and see if you get it. No one has to be inside the truck IIRC.
  7. Jan 19, 2010 at 8:18 AM
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    I notice the lean is worse in the rear of the truck. I'm wondering if the rear leaf / spring TSB will correct this as a collateral benefit? Anybody with the TSB done notice this?
  8. Jan 19, 2010 at 8:20 AM
    Klipp11
    Klipp11 s3
    Kevin
    '06 DC 4x4 LB
    OME 885 coils, Bilstein 5100 shocks, 1.5" AAL, TC uca's, cab mount chop, 5000k HID heads and fogs, LED tails, satoshi GC w/ Hella 500's mounted behind it with 5000k HID upgrade, Extang solid tri-fold tonneau cover, Yakima roof rack, fog light anytime mod, disable a/c defrost mod
    it just takes a minute to measure from your wheel center cap to the bottom of the fender flare on each side if you're concerned about it. my truck was 1/2" higher on the passenger side. :)
  9. Jan 19, 2010 at 8:26 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    OK, so here's a related question - how do you explain a lean toward the Passenger side? Ever since my frame replacement in Oct., my drivers side is about 3/4 to 1 inch taller than the pass. side., only in the rear. The front's both measure the same height, from ground, through center hub, to fender.
  10. Jan 19, 2010 at 8:40 AM
    jason1kyle
    JOHNSON CITY, TN
    ok thanks for the answers never noticed that tho now it will probbaly bother me lol
  11. Jan 19, 2010 at 10:32 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Yeah now it's gonna get on ur nerves! ... Thanks tw!
  12. Jan 19, 2010 at 11:14 AM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    i think the gov made them change things for regulations....my old '88 taco had the gas tank on the passenger's side and the exhaust was on the drivers side
  13. Jan 19, 2010 at 11:15 AM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    I have both :D
  14. Feb 2, 2010 at 11:04 AM
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    Would relocating the battery from the engine bay to the bed or one of the bed storage boxes help a decent amount or has anyone done it (DIY thread perhaps)? It'd essentially be moving 50 pounds from one corner to another.
  15. Feb 2, 2010 at 11:12 AM
    TacoSupreem
    Hayden
    Kentucky
    I wouldn't think so? Just 50 lbs!
  16. Feb 2, 2010 at 11:21 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    If you have to measure your truck to find out if there is a lean, then who cares.
  17. Feb 2, 2010 at 11:33 AM
    TacoSupreem
    Hayden
    Kentucky
    I mean we're only talkin about a 1/4 inch! So I wouldn't worry yourself too much about it!
  18. Feb 2, 2010 at 12:10 PM
    Masada
    Taylor
    Laveen, AZ
    I don't even thing we are talking that much usually.
  19. Feb 3, 2010 at 7:46 AM
    virgilus11
    virgilus11 Well-Known Member
    kearny, nj
    09 sr5
    TRD supercharger,EMU 884 springs, 90000 shocks, air bags rear and TSB with EMU shocks, grillcraft mesh, Relentless front bumper,Armology rear bumper, byxenon hid's retro ,undercover lid with bike rack on top, Kenwood dnx9140,TRD cover seats
    I relocated the battery behind rear passenger seat. I can't say that it fixed, completely, the problem but it ballance the rear better. Now the battery is compensating for approx 5-6 gallons of gas and by removing 50 lbs of the front,, I made the front a lttle bit lighter.
    If you go four whelling with your truck, you are going to see, feel, that 50 lbs off your front is a big deal.
  20. Feb 3, 2010 at 8:03 AM
    kingston73
    North eastern Ohio
    09 SR5 4.0L 4x4
    The battery weighs 50lbs??? I guess I'm just dense, I really don't think I'd notice a shift in weight and handling. I can't notice the difference between just myself and a passenger, and that's at least a 150lb difference.
