About that Clutch Start Cancel button
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bonifacio_629, Jun 18, 2019.
Has your Clutch Start Cancel button ever come in clutch?
  1. Yes
    29 vote(s)
    76.3%
  2. Maybe
    9 vote(s)
    23.7%
  1. Jun 18, 2019 at 11:53 AM
    Azza
    Azza ㅤㅤㅤㅤㅤㅤㅤㅤㅤ
    I'm pretty curious, would it be okay to use this on a daily basis to start the truck? I don't I ever would because I'm so used to pushing in the clutch but I wouldn't mind knowing.
  2. Jun 18, 2019 at 11:53 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Awesome!
    Thanks for posting that.
    I stalled once in 4Lo with folks around getting over an obstacle (no sliders). It was hilarious. I didn't think to try CSC.
    shakerhood likes this.
  3. Jun 18, 2019 at 11:56 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Daily basis in neutral? Sure.
    In gear? You're eventually going to wear the starter or flywheel unless your going downhill. But in that case, you could just bump start the engine with the clutch. I do that when backing down my driveway.
    DanoT and doublethebass like this.
  4. Jun 18, 2019 at 11:58 AM
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    I used it twice. Once to start on an incline while off-roading to prevent rolling back and the other when my clutch position switch broke and I couldn't start it without the clutch switch override.
  5. Jun 18, 2019 at 11:59 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I mentioned this in the other thread, but I believe this is why we still have a key instead of push button start.
    OZ TRD, rubiconjp, Beretta4x4 and 4 others like this.
  6. Jun 18, 2019 at 12:03 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I don't think it would. As long as you're not on it for minutes to overheat things. I try to avoid using it for longer than 30 seconds without giving it a break.
    I have also used it to creep off the interstate 50yds or so when my fuel pump became disconnected.
  7. Jun 18, 2019 at 12:07 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I can see both sides of this. I am just thinking about the dry mesh between the starter and flywheel. If it was lubricated / sealed, then I would have your view of it.
    stun gun and Reh5108[QUOTED] like this.
  8. Jun 18, 2019 at 12:12 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I've been doing stuff like @Reh5108 posted for years now, and use it nearly ever time I start from a stop when in 4L.
    I'm on my factory starter and flywheel both with 288k miles on them.
    It's not going to hurt your truck.
  9. Jun 18, 2019 at 12:14 PM
    ArmandHammer83
    ArmandHammer83 This truck is AMAZING
    Raymond
    Alabama
    2018 Tacoma AC V6 MT 4x4
    none yet
    @Reh5108 since you have experience with this in its intended purpose..my question is to make it up something like that after it started and got moving did you have to give it gas at all or did it make up that at idle?
    bonifacio_629[OP] likes this.
  10. Jun 18, 2019 at 12:18 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sounds good. I will defer to you guys. I'm just over 20k.
    :cheers:
    bonifacio_629[OP] and stun gun like this.
  11. Jun 18, 2019 at 12:20 PM
    Squeaky Penguin
    Brett
    Here's a little clutch start crawling action near the start of this video. Sometimes I purposely turn the engine off and start in gear as it helps prevent rolling backwards when on an obstacle.
    https://www.youtube.com/watch?v=1Tv82LaZrUI
  12. Jun 18, 2019 at 12:30 PM
    Reh5108
    Idaho
    Makes sense with the increased load on it, though it's minimal especially in 1st low.
    Simple answer is no it won't idle up. It needs some gas but even then it's to much load for the engine to pull through the low rpms.
    tonered[QUOTED] likes this.
  13. Jun 18, 2019 at 12:30 PM
    Azza
    Azza ㅤㅤㅤㅤㅤㅤㅤㅤㅤ
    I'm a wee bit confused. The one day where I used CSC to turn on the truck (in neutral) and drove to work was a bad idea?
  14. Jun 18, 2019 at 12:32 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Agreed. :cheers:
    Reh5108[QUOTED] likes this.
  15. Jun 18, 2019 at 12:32 PM
    #35
    Reh5108
    Idaho
    No. Once you let off the ignition the starter disengages like normal. The light stays on until you shut the ignition off. This is nice when you're in difficult terrain and so that you don't need to keep enabling the button.
    Azza[QUOTED], shakerhood and tonered like this.
  16. Jun 18, 2019 at 12:36 PM
    #36
    Azza
    Azza ㅤㅤㅤㅤㅤㅤㅤㅤㅤ
    Okay that's what I thought lol Cheers
  17. Jun 18, 2019 at 12:41 PM
    #37
    Lima_Delta
    Lima_Delta Well-Known Member
    PacificNW
    2015 TRDOR AC MT
    What would make more sense—if Toyota would put the switch back-light on the Fog Light button—makes no sense to have a back-light on the CSC.
  18. Jun 18, 2019 at 12:45 PM
    #38
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    I use it when I need to jump my mower or john deere, which has been pretty darn "clutch" :thumbsup:
  19. Jun 18, 2019 at 12:47 PM
    #39
    squarenone
    squarenone Well-Known Member
    SoCal
    2018 TRD OR 4x4 6sp-mt
    I use it all the time, not having to depress the clutch will reduce wear on the thrust bearing during start up where oil pressure is at its lowest. I'm not saying that your thrust bearing will wear out if you don't do this or that this will magically make anything last longer but I'll take any opportunity to reduce wear during start up where the most wear happens. There are millions of cars that don't have thrust bearing wear using the traditional clutch in starting so it's a solution to a problem that doesn't really exist but again, I'll take any opportunity to reduce wear during start up.
    Google it and you'll see what I mean.
  20. Jun 18, 2019 at 1:04 PM
    #40
    WoodsGhost
    WoodsGhost Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
    Learned alot on this thread. Thanks gents:hattip:
    shakerhood and bonifacio_629[OP] like this.
