About to burn this truck. Someone help me please!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kibmj43, Jan 18, 2025.
  1. Jan 18, 2025 at 3:15 PM
    Kibmj43
    Kibmj43 [OP] Member
    Mason
    2009 Blue Tacoma TRD
    All of them
    Hey crew.
    Long time lurker here. I bought A 2009 Tacoma in 2019, I got the truck, and Toyota replaced the frame, the leafs, and the shocks shortly after due to a recall. Since then I've put 230k miles on it. I replaced all the front end components about a year ago, around 200k miles. I also replaced the shocks, and went to bilstein 5100s. I had a driveline shop here in Knoxville make me a new driveshaft with a dropped carrier bearing for my lift. Im Running 35s, with a big custom off road bumper I made, some side steps, a full exhaust, aftermarket wheels, and the truck is spotless. I replaced all the brakes, Brake drums, shoes, front calipers, pads, rotors, etc.
    Two issues currently. A few weeks ago I heard a grinding from the rear end of the truck. Right side. Sounded very very wheel bearing ish. took it to toyota, and they said it needed 3 wheel bearings.
    So, I ordered them, jacked it up, started changing them all. I had new axle shaft bearings pressed onto the axle shafts, and ordered new hub assemblies as well. Went ahead and threw new cv axles and pads on the front and then bled everything.
    Now my current two issues.
    Whatever that damn grinding is, I cannot find it. It is loud as hell. The rear end is completely fine, even Toyota said so. Ive replaced anything that could grind, so Im at a loss for words here.
    Second problem, No matter what I do, or how many times I bleed the brakes, after I drive 300ft down the road, I have no brakes.
    I've babied this truck, and its always been good to me, but now im starting to get frustrated. I just put $1500 worth of parts on it and its still making the noise. I've never ran into this problem. Also, no, the drums are not warped, they are new, and with the wheels off and snugged with lug nuts, they rotate freely, and quietly.
    Thanks ahead of time!
  2. Jan 18, 2025 at 3:26 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Does the grinding sound happen with the rear wheels off the ground in drive?
    As for the brakes, if you got air into the ABS module, you'll need a scan tool to bleed the brakes.
    Did the master cylinder ever go dry while you were installing the rear axle?
    The brake line has to be disconnected to pull the axle. How much fluid did you loose then?
    winkel likes this.
  3. Jan 18, 2025 at 3:30 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
  4. Jan 18, 2025 at 3:36 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Also, what do you mean by "have no brakes"? Please explain a bit more so we can help.
    For the grinding, when you drained the rear diff fluid, did it have any glitter in it?
    Have you verified that your front dust shields, behind the rotors, are not rubbing? Grinding sounds can be deceptive relative to location.
    NmapFE and TnShooter like this.
  5. Jan 18, 2025 at 4:04 PM
    Kibmj43
    Kibmj43 [OP] Member
    Mason
    All of them
    Never touched the module, Master cylinder never dropped even a little. I plugged the ends of the lines immediately upon pulling them.
    Grinding sound happens always.
  6. Jan 18, 2025 at 4:06 PM
    Kibmj43
    Kibmj43 [OP] Member
    Mason
    All of them
    I have confirmed it wasn't the front dust shields. That's what I originally thought it was, but its coming from the rear right of the truck. And by no brakes, i mean I literally have no brakes. But when I bleed them, no air is coming out of the system at all, master cylinder is topped off. I've gone around the entire truck a few times and I'm getting no more air. Obviously there was air to start, but no more air is trapped in the system, that i can tell.
  7. Jan 18, 2025 at 4:35 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I know this might sound strange but, have you checked your exhaust and exhaust heat shields?
  8. Jan 18, 2025 at 4:44 PM
    Kibmj43
    Kibmj43 [OP] Member
    Mason
    All of them
    This does not sound strange.
    The last of "fixes" and or upgrades are that my exhaust tips need replaced. I've looked from every conceivable angle and idk what they could be hitting on to make a grinding sound. There are no shields under my truck. Guy that had it before me offroaded quite heavily in its first 25k miles of life I believe, and he had removed them, or someone else did and sold them for scrap. My exhaust tips are rusted through, but that is literally the very last on my to do list. But it isnt that, that I know of.
  9. Jan 18, 2025 at 4:48 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Brake issue - I would recommend checking to make sure that all brake line fittings are tight/not leaking in areas you touched them, if all that's good have a dealer or indie shop do a complete abs brake flush using a scan tool.
    Grinding noise - does the noise only happen when the vehicle is driving, when about when going in reverse, can you jack up each wheel and easily spin it by hand, does the noise start or stop at particular speeds, does it change turning left or right?
    The more info you can provide the better recommendations can be provided.
  10. Jan 18, 2025 at 4:50 PM
    Kibmj43
    Kibmj43 [OP] Member
    Mason
    All of them
    Starts at 15mph, nothing stops it after that. Not hitting the brakes, turning, reversing it happens at 15mph too, nothing stops it.
  11. Jan 18, 2025 at 4:51 PM
    Brownmatthall
    Brownmatthall Well-Known Member
    Saratoga Springs, NY
    2016 TRD OR DCSB
    Wheel cylinder?
  12. Jan 18, 2025 at 4:52 PM
    Kbar
    Kbar Well-Known Member
    Western WA
    22 OR
    Mayhap the exhaust is resonating some loose crap in there.
    Master cylinder might be bust on brakes
  13. Jan 18, 2025 at 4:54 PM
    joeyv141
    New Jersey
    You've put it in neutral and reverse the engine slowly to make sure its not engine related? Does the brake pedal pulse? Just thinking maybe the ABS is unhappy and those pumps can make strange noises. Any warning lights on? Does the noise pitch change with speed or is the noise frequency constant regardless of speed?
    Edit - Don't hit the brakes, just very very lightly apply them, I have a weird vibration noise that I chased for about 2 hours before figuring out one of the brake pad anti rattle clips was loose causing a rattle, it went away when I very lightly applied brakes was my (eventual) clue.
    If its a bearing, wheel or driveshaft, the frequency should change somewhat depending on vehicle speed.
  14. Jan 18, 2025 at 4:55 PM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    Definitely get a shop that can cycle the abs pump to exchange brake fluid.
    As far as the grinding, could the custom driveshaft, carrier bearing, or U joint be in play? How is your pinion angle? Could the pinion bearing be worn? Could the ring carrier bearings be worn? Does the pitch of the grinding change with wheel speed or engine speed? You may just have to carefully look at everything that rotates.
    Edited for a huge number of autocorrect mistakes
  15. Jan 18, 2025 at 5:33 PM
    Kibmj43
    Kibmj43 [OP] Member
    Mason
    All of them
    Nope, wheel cylinder is fine.
  16. Jan 18, 2025 at 5:33 PM
    Kibmj43
    Kibmj43 [OP] Member
    Mason
    All of them
    Idk, Would it sound grindy?
  17. Jan 18, 2025 at 5:35 PM
    Kibmj43
    Kibmj43 [OP] Member
    Mason
    All of them
    It gets louder after 15mph, but doesnt start until then, and nothing else changes it.
    Zero warning lights anywhere in the truck. Idk whats going on with the brakes, i've never had any trouble bleeding brakes before, and they worked fine before this.
  18. Jan 18, 2025 at 5:36 PM
    Kibmj43
    Kibmj43 [OP] Member
    Mason
    All of them
    Checked all these things today. The new driveline has less than 20k miles on it, its all as tight as the skin on a grape.
  19. Jan 18, 2025 at 6:26 PM
    winkel
    Corydon, IN
    So when you have the no brake issue, is the pedal going to the floor, or is there pressure, but no feeling of braking relative to the truck slowing down?
  20. Jan 18, 2025 at 7:10 PM
    kidthatsirish
    Bleed your brakes again....
    Kolter45 likes this.
