About to buy the lift!
Discussion in 'Suspension' started by Gus 524, Feb 25, 2013.
  1. Feb 28, 2013 at 6:57 PM
    Gus 524
    Gus 524 [OP] Well-Known Member
    Justin
    MN
    09 tacoma SR5 4WD 4-cylinder
    just bought it! cant wait! :D
  2. Mar 5, 2013 at 6:19 PM
    Gus 524
    Justin
    MN
    You sir are correct. Front coil overs are backordered for a month.
  3. Mar 6, 2013 at 4:29 PM
    pivey14
    pivey14 Well-Known Member
    Austin, TX
    2023 Lunar Rock TRD Off-Road 4x4
    Fuel Wheels Clash Bronze 6-Lug Wheel; 17x9; -12mm Offset 285/70/17 Nitto Ridge Grapplers 1” Front Spacer 2" Rear Block TRD Pro Grille with Raptor Lights TRD Pro Floor Liners TRD Pro Shifter Knob Lunar Rock Interior Trim BAMF Rock Sliders
    Did you get the top place spacer to bring it to 3"? If you did just the 5100s at .85 and Eibach Spings it should bring you to 2.5", which means you don't need new UCA's. If you did get the top plate spacer, you may want to invest in some UCA's. I'm gonna do the same lift as you in the near future, that is if you are only lifting 2.5" in the front and 2" in the rear.
  4. Mar 6, 2013 at 5:13 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Just to let you know UCAs will still have a huge benefit even if you only lift the front 2.5 inches.
  5. Mar 6, 2013 at 5:40 PM
    Gus 524
    Justin
    MN
    I did not get the top spacers. I have a 4 bannger so I will sit a tad higher then 2.5 in the front. I think sometime down the road I will get the top spacers. And I most likely get new uca's when I can afford it.
    Thanks for that info. Yea I have heard from a few people that uca's help out a lot. Any type or brand of uca's you would recommend for someone on a tight budget?
  6. Mar 6, 2013 at 7:39 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Its a 1/4" spacer that adds 1/2" to your lift.
  7. Mar 6, 2013 at 9:47 PM
    Gus 524
    Justin
    MN
    So buying to of those would give you another .5 in in front. Then I'm also curious on the cv angles?
  8. Mar 6, 2013 at 10:23 PM
    bullaculla
    Da big big island!
    Actually, this is the spacers in the toytec drop down options for your lift: it says the spacers will give double cabs full 3" of lift. Might be too much for your access cab. the 1/4" spacer I linked earlier is usually used for just the drivers side to fix the taco lean. But you should be able to run it on both sides to get a little more lift.
    I'm not real familiar with the OME lifts.
    Lots of people run 3" of lift, but you do have to worry about CV boots wearing out.
    :edit:
    MY BAD! I thought you were going OME. I got confused with another thread. :D
