About to do 5100's but have a question
Discussion in 'Suspension' started by L.V.T., Oct 28, 2010.
  1. Oct 28, 2010 at 9:04 PM
    L.V.T.
    L.V.T. [OP] jackalope killer
    Las Vegas
    '10 TRD D-Cab
    Tint, Shaved Mud Flaps ;), Train Horns, 2.5" Fat Bob's front lift, Rear TSB spring lift, DuraTrac's
    Ok, so I'm about to get some 5100's all around for the truck, but I have a couple questions. First; do I need to replace the front UCA's? I've noticed that almost everyone who has a lift replaces them but I'm not sure why.
    Secondly; I have read that doing the 5100's leaves you with only 1" of down-travel. Is this true? And what is down-travel? Does that mean there will only be 1" of "compression stroke" for the front suspension? I really want to lift the truck a couple inches but if it's gonna ride stiff or like crap I don't want to go this route because it's my daily driver.
    Thanks -Tony
  2. Oct 28, 2010 at 11:55 PM
    wolfdog2314
    wolfdog2314 Well-Known Member
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    What setting do u want to put the 5100's to?
  3. Oct 29, 2010 at 12:22 AM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Pretty sure the down travel is the rebound stroke (i think) I have 5100's waiting for me at the post office, can't wait!
  4. Oct 29, 2010 at 4:29 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Down travel is the distance the shock can extend when the load is lifted off the tire (like when you hit a bump or the tire comes off the ground. Limited down travel means the shock will bottom out and make noises and potentially break. I'm not sure how much DT you have with the 5100s
    UCAs allow for alignment specs to be corrected for taller lifts (like 2.5" and greater). You may or may not need them depending on how high you want to set your 5100s. But changing them out can pretty much never hurt and it's easier to do them all at once than to try piece by piece.
  5. Oct 29, 2010 at 4:36 AM
    badguybuster
    badguybuster Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    ^ well said. However, I have my Tundra 5100s set at 2.5 and I have plenty of flex in my shocks. No worries man. Guys have been using them for a long time now. Also, you may wanna ad a small bead of JB weld under the retaining ring if you really abuse them.
  6. Oct 29, 2010 at 8:52 AM
    L.V.T.
    Las Vegas
    '10 TRD D-Cab
    I would defenatly run them at the max setting. I don't really do any "hard core" off roading, I'm just after the lifted look really. Are front spacers like the toytec kit a good thing for someone who does light off road and mostly street driving? If so I think that what I'm gonna do.
  7. Oct 29, 2010 at 10:03 AM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    Just get the 5100's and put them at 2.5 setting (the top groove) You should still have plenty of down travel...like at least 1.5". You might have to get new UCA's at that height if you can't get the alignment corrected after. Chris4x4 said thay you shouls have at least 1.8 caster or else the truck will wander on the HWY. I have 2.6" of lift in the front and was just able to eek out 2.0 caster. You might get lucky like me. I would stay away from the spacer lifts...
  8. Oct 29, 2010 at 11:18 AM
    L.V.T.
    Las Vegas
    '10 TRD D-Cab
    Why do you say to stay away from the spacer lifts?
  9. Oct 29, 2010 at 11:50 AM
    Fabulous
    Fabian
    Calgary, AB
    Just search on here for peoples opinions on them...they are not well liked. The 5100's are not much more, and are a better way to go in mine, and a lot of others opinions.
  10. Oct 29, 2010 at 3:10 PM
    durf4694
    durf4694 giggity giggity
    ny
    06 tacoma sport
    K&N cold air kit, Kenwood double din with dvd player, navigation, rear cam. hook up with One JL 12" sub powered by a 800 watt pioneer amp, Sirius/XM satellite radio, TRD Neoprene Seat covers, Tinted windows all around, Trifecta Tonneau Cover, Billies at 1.75 and a 1.5 block in the back
    ^^^^ Yes ! Most likely your going to get a better ride out new brand new billies other than cramming a spacer in your strut. Read the forums. Downsouth motor sports has untouchable prices on those shocks. Anyone interesting in doing a group buy for billies?(if it offers a good benefit)
  11. Oct 29, 2010 at 3:13 PM
    Fabulous
    Fabian
    Calgary, AB
  12. Oct 29, 2010 at 7:52 PM
    L.V.T.
    Las Vegas
    '10 TRD D-Cab
    So if I only have 1.5" of down travel, and I run over speed bumps too fast, and the shock extends all the way (because most speed bumps are more than 1.5") I could potentially end up with a broken shock? Am I understanding this correctly?
  13. Oct 29, 2010 at 9:37 PM
    Fabulous
    Fabian
    Calgary, AB
    It will be fine. There are tonnes of guys on here that have 2.5-3" of lift (which leaves you with 1" down travel) and they are fine...I wouldn't worry about it. The spacers do the same thing, but leave you with a rough ride...
  14. Oct 29, 2010 at 9:45 PM
    L.V.T.
    Las Vegas
    '10 TRD D-Cab
    Ok, so I'm about to order a set but if there's a chance I might need new UCA's I'm not gonna do it. So how likely is it that I will need them for my truck not to wander all over the place while driving? Because $300 for 2.5" is ok with me, but with UCA's it brings it to just under $900 which is too much for 2.5" I think.
  15. Oct 30, 2010 at 12:10 AM
    Sabre
    Sabre Well-Known Member
    Kyle
    Silverdale, WA
    2014 F-150 FX4
    i ordered 5100's yesterday i got them today in the mail from down south defintly go with them!!!!!
  16. Oct 30, 2010 at 12:15 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Bro' , get the 5100's front & rear, get them installed & get on with your 'Taco life. :D:D
    It's my opinion & my understanding that the 2.5" lift is the max you can get with the stock UCA's & still achieve decent alignment when you're done....
  17. Oct 30, 2010 at 4:34 AM
    southerntaco889
    southerntaco889 Well-Known Member
    Bartow, GA
    07 PreRunner DC TRD Sport
    5100's @ 2.5/285 BFG A/T's/blacked-red badges/strobes/siren/PA/roof rack soon to come/brush guard soon to come
    Totally agreed. 5100's are the way to go. I've ridden in spacer lifted trucks and the ride sucks. I just put 5100s at 2.5 on my DC with some 285's and love it. I only bottomed the shock out once and that was cause I was Baja'in through a plowed field and hit a hole:D. No problems with alignment either other than just a tick off on the caster like previously said. It's not really enough to notice IMO. And def go with Sonny at DSM. They rock.
  18. Oct 30, 2010 at 6:50 AM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    I just ordered a set from DSM also, just got them in the mail yesterday but wont be able to get them on till next weekend, their price is untouchable, im setting mine at .85 to level the truck out
  19. Oct 30, 2010 at 12:48 PM
    Fabulous
    Fabian
    Calgary, AB
    Every truck is different, so you might not be able to get a perfect alignment which is the 0 toe, 0 camber, and 2.4 caster. I have 2.6" of lift, and my caster is at 2.0, which is where it was the last time I had an alignment about 9 months ago. My truck drives no different than it did before the lift...just a little firmer, but nice. If your really worried about the alignment, then put them at the 1.75 setting. Lots of guys got 2" of lift on that setting from what I read. It's up to you, but the 5100's are a great product, and at $283 for all four it's a steal!
  20. Oct 30, 2010 at 12:54 PM
    jwhelan
    jwhelan Well-Known Member
    JW
    Dallas Texas
    05 TRD Silver
    TRD PreRunner, 5100's on all four fronts @ 1.75, AAL, SP performance rotors, hawk pads, 17" FJ Cruiser wheels P/C black, 265/65/17 BFGR Rugged Trails, BHLM , painted grill, blacked out emblems
    Here is mine with 5100's at the middle setting and AAL in the rear..
