About to embark on an adventure. (Valve cover gasket)
Discussion in '1st Gen. Tacomas (1995-2004)' started by sir1123, Feb 1, 2011.
  1. Feb 1, 2011 at 5:16 PM
    sir1123
    sir1123 [OP] Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    Has anybody replaced their valve cover gasket before? if so how long was the labor and how tediouse was it? do you need any special tools? is reassymbly a bitch? really not looking forward to this but must be done. it is a tiny leak but i HATE leaks.
    Thanks:confused::mad:
  2. Feb 2, 2011 at 5:39 PM
    cab4you26
    cab4you26 Well-Known Member
    Corey
    VA
    97 Tacoma, 5spd 2.7L
    Wheelers Offroad black steel wheels, 12 disc changer, spray in bedliner, Black UWS toolbox, Kelly Safari TSR's, Dynomax Super Turbo
    is it the 4 or 6 cylinder?
  3. Feb 2, 2011 at 6:46 PM
    sir1123
    Charleston
    6 cyl.
  4. Feb 2, 2011 at 7:01 PM
    shaniac
    shaniac Well-Known Member
    Charleston, SC
    2014 Double-Cab Tacoma SR5 V6 4x4
    If you have the 3.4 liter V6 you will have to remove the intake, throttle body and intake tube as well as removing some of the vacuum lines to get to the top bolts on the valve covers...Not too hard but may be a little time consuming.
  5. Feb 2, 2011 at 7:01 PM
    shaniac
    Charleston, SC
    I'm going to have to do the same myself pretty soon...
  6. Feb 2, 2011 at 7:10 PM
    sir1123
    Charleston
    just ordered the intake manifold gasket to and it was a bit pricy...jeezzz
  7. Feb 2, 2011 at 7:12 PM
    sir1123
    Charleston
    around where you live in the c town? and you got anymore pics or your rig?
  8. Feb 2, 2011 at 7:17 PM
    shaniac
    Charleston, SC
    I live in the North area right off of Dorchester Rd...You?
    As far as pics, I don't have any more of mine...It is a work in progress but I keep dumping money into my other hobby, LOL.
  9. Feb 2, 2011 at 7:31 PM
    sir1123
    Charleston
    west ashely
  10. Feb 2, 2011 at 7:43 PM
    shaniac
    Charleston, SC
    A stones throw across the Ashley River...LOL
  11. Feb 2, 2011 at 7:47 PM
    shaniac
    Charleston, SC
    Oh and where did you purchase your intake manifold gaskets? I have not priced them yet but I am sure you can get a set of Fel-Pro from Parks a lot cheaper than the dealer. When I took my throttle body off to clean my Idle Speed Control Valve, both gaskets together ran me close to $4...I know the intake manifold gaskets are larger than the throttle body gaskets but I can't imagine them being over $20...
  12. Feb 2, 2011 at 8:10 PM
    sir1123
    Charleston
    auto parts warehouse..upper manifold gasket kit one is $75 and the other is $101
  13. Feb 2, 2011 at 8:21 PM
    shaniac
    Charleston, SC
    You have got to be kidding me?!?!? I may call Parks in the morning to compare...if it is that much, I may hold off a little longer on the valve cover gasket replacement.
    I would also gets some throttle body cleaner and a new throttle body gasket and a Idle Control Air Speed Valve gasket and clean the valve since you will have it off...those two gaskets will run you around $4 for both.
    Another thing since you will have the intake manifold off, If you have the funds, I would look at replacing the fuel injectors....they are a bit pricey but you are going to be in that area, cheaper now than later since you will have to remove the intake to get to them.
  14. Feb 2, 2011 at 8:30 PM
    sir1123
    Charleston
    that not a bad idea the injectors but they seem to be fine i say that only because i am still getting good gas milage but being 11 years old it would only benefit
  15. Feb 3, 2011 at 7:55 AM
    cakesprez
    cakesprez Active Member
    Kyle
    Charleston, SC
    96 tacoma lx 4x4 overland wanna be
    ome shocks front and rear, 880s with 1 trim packer, wheeler 1 1/2s, custom front bumper, snorkel, header, supertrapp, wood grain personal, 31" coopers, busted ass shell, thule rack
    Where in west ashley do you live? I am in Avondale right by Genes. Ive never seen you around. I would check with autozone on the manifold gaskets. They are usually pretty fair
  16. Feb 3, 2011 at 6:28 PM
    sir1123
    Charleston
    South windamire
  17. Feb 3, 2011 at 6:30 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    Mine is leaking a small bit too. :annoyed:
  18. Feb 3, 2011 at 7:06 PM
    Miata Tech
    Miata Tech Well-Known Member
    Jim
    Lawrence, KS
    2002 4X4 SR-5 TRD
    ChaseCam Video System, Optima YellowTop, ScanGauge II, Heated Drivers Seat, Sirius Satellite Radio, K&N Drop In, E-Locker Guard, Extang Black Max Tonneau , Streamlight Stinger, All Synthetic Fluids, USA-Spec iPhone Interface, Gentex Auto Dimming Compass/Temp Mirror
    You might as well check your valve adjustment while you are that far in.
    I think I paid about $20 for the upper intake gaskets and $35 for the valve cover set. Both were Felpro.
  19. Feb 3, 2011 at 7:20 PM
    sir1123
    Charleston
    how long did this take you
  20. Feb 5, 2011 at 9:22 AM
    Miata Tech
    Jim
    Lawrence, KS
    2002 4X4 SR-5 TRD
    About 3 hours or so. Not counting the time it took to take the valve covers to the car wash to clean them off.
