About to hit 100k, what should I service?
Discussion in 'Technical Chat' started by headhunter247, May 17, 2010.
  1. May 17, 2010 at 12:12 PM
    headhunter247
    headhunter247 [OP] Well-Known Member
    St. Louis, MO area
    18 Taco Double Cab TRD
    5100's all around, OME 888 and Dakars. ProComp Series 05. Cooper SST Maxx 275s.
    I have heard that the timing chain needs replaced at 100k, but was quoted at $800- $1100 to change it.
    First off, what are thoughts on this? What are side effects if I didnt replace it?
    What else should I look into replacing?
  2. May 17, 2010 at 1:40 PM
    headhunter247
    St. Louis, MO area
    Thanks for that. I was reading on how much the timing belt costs to replace. I'll wait til that breaks.
    I'm guessing this is in the service manual but is there one place to find a snapshot of all the grease zerks?
  3. May 17, 2010 at 1:44 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    If your truck is a 2x4 it will not have grease zerks.
  4. May 17, 2010 at 2:03 PM
    headhunter247
    St. Louis, MO area
    4x4 all the way baby....
  5. May 17, 2010 at 2:15 PM
    Muy Grande
    Muy Grande Well-Known Member
    Dallas, TX; RGV, TX
    06 DC TRD
    Suspension: DHoes up front, Dakar and OME out back. Audio: Alpine w205 w/ pair of Alpine Amps, Image Dynamic 6.5 Component Speakers up front and Image Dynamic Subs in the Back. Armor: ARB Bull Bar, Rocktek rear bumper and custom rock sliders. Other: Rigid Industries LED Light Bar, Platinum DieHard Battery, BlueSea Fuse Block, rear lights, bed lights, leds inside.
    These trucks have a timing chain, no need to change at 100k.
    The only thing you need to change is the "Coolant". It has a special pink coolant that last 100k miles.
  6. May 18, 2010 at 6:25 AM
    headhunter247
    St. Louis, MO area
    Anyone have any ideas on a single place that lists all the grease zerks?
  7. May 20, 2010 at 12:32 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    100k-120k Timing chain/belt and water pump are normally the big services that need to be done.
  8. May 20, 2010 at 12:34 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    I found this on someones sig the other day....
  9. May 21, 2010 at 7:24 PM
    Barnone
    Barnone Guest
    headhunter,
    FYI from a sticky above:
    Tacoma 1995-2008 4 Cylinder Chain
    1995-2004 V6 Belt
    2005-2008 V6 Chain
    Your info says you have a 05 so you have a chain therefore no belt to change.
    Don't go back to whoever quoted you a price to change your chain.:)
  10. May 22, 2010 at 8:08 PM
    tacomabiker
    tacomabiker Well-Known Member
    Dan
    Maryland
    05 Toyota Tacoma V6 4x4 Offroad
    Leer Shell, Tow Package,
    Timing belts are usually replaced at 90,000 miles.
    Timing CHAINS are usually replaced at 250,000 miles. 2nd gen's have the timing chains. be thankful...
