About to hit 200,000 miles on my 2010 V6 Tacoma, seeking advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ink junky, Feb 7, 2025.
  1. Feb 7, 2025 at 2:14 PM
    ink junky
    ink junky [OP] I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    I bought my truck brand new back in 2010 and I have only ever done the basic maintenance on it, regular oil changes, transmission oil change recently and I really need to get on the ball and do the oil change on the differentials. I also changed the spark plugs around 6 months ago.
    Question: For a truck I've had for 15 years now, and about to hit the 200,000 mile mark, what are some things you all highly suggest/recommend I do as far as maintenance goes?
  2. Feb 7, 2025 at 4:02 PM
    Nctrucknut336
    Nctrucknut336 Member
    08 trd sport
    Stay on top of any frame rust
    Flori-duh Taco and kidthatsirish like this.
  3. Feb 7, 2025 at 4:13 PM
    point45
    point45 Well-Known Member
    SoCal, OC
    05 DCSB TRD offroad
    Change the belt, inspect the carrier bearing, engine pullys, coolant and brake fluid flush.
  4. Feb 7, 2025 at 4:37 PM
    ink junky
    TACO LOVER
    TEXAS
    You know, I'll start looking! Thank you!
  5. Feb 7, 2025 at 4:38 PM
    ink junky
    TACO LOVER
    TEXAS
    I'll start inspecting everything tomorrow. Thank you!!!
  6. Feb 7, 2025 at 4:42 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  7. Feb 7, 2025 at 4:42 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Try and get all the fluids on a regular schedule. Ie. Tranny, diffs, transfer case every 30k, coolant every 60k, ps and brake fluid every 60k, air filters every 15k, and so forth 200k is a good point to start. And just keep with it and 500k shouldn’t be a problem. If you do this correctly at ea 60k interval every one of these items gets done all at once.
    ink junky[OP] and TacoMatic4x4 like this.
  8. Feb 7, 2025 at 5:12 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    When my cars hit 200K, and if I intend to keep the vehicle at least another 100K, I replace everything in the cooling system - water pump, radiator, thermostat, bypass hoses, fan clutch, fan, etc … I stick with Aisin parts when I can. The radiator I have a CST in my Taco and have no issues with TYC and Denso in our sedans.
    scocar likes this.
  9. Feb 7, 2025 at 6:26 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The serpentine belt needs to be replaced every 100,000 miles. That's the only thing that jumps out at me.
    scocar and ink junky[OP] like this.
  10. Feb 8, 2025 at 8:27 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Coolant system is very important. If you don’t change or at least flush the system the coolant breaks down and will attach gaskets such as the head. You don’t want to get into that
  11. Feb 8, 2025 at 8:57 AM
    Patch Barracks
    Patch Barracks Well-Known Member
    New Taco Owner
    2016 4 door Tacoma
  12. Feb 8, 2025 at 8:58 AM
    Patch Barracks
    New Taco Owner
    2016 4 door Tacoma
    Please explain the best way to do this and how to prevent frame rust.
    Thanks.
  13. Feb 8, 2025 at 9:26 AM
    Clearwater Bill
    Billy
    Largo Florida
    Do you live where it snows and roads are salted?
    ink junky[OP] likes this.
  14. Feb 8, 2025 at 1:20 PM
    Patch Barracks
    New Taco Owner
    2016 4 door Tacoma
    One of my Tacomas is up in Ann Arbor for two years studying at UMich.
    It will return home to Tigerland next spring.
  15. Feb 8, 2025 at 5:04 PM
    ink junky
    TACO LOVER
    TEXAS
    Dm93[QUOTED] likes this.
  16. Feb 8, 2025 at 5:06 PM
    ink junky
    TACO LOVER
    TEXAS
    I'll buy the part!!! :)
    Hopefully it's nothing too bad to replace by myself.
    Dm93 likes this.
  17. Feb 8, 2025 at 5:07 PM
    ink junky
    TACO LOVER
    TEXAS
    No, sir. I live in Central Texas.
    Dm93 likes this.
  18. Feb 8, 2025 at 5:14 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Not terrible, if you pull the tensioner back it has a hole to insert a drill bit, allen key, or other suitable tool to lock it in the de-tensioned position.
    Personal preference but I remove the fan and fan shroud to make installing the belt super easy but you don't have to.
    Make sure to spin all the pulleys while you have the belt off to check for noise and check them for play/looseness.
    SWPA Tacoma likes this.
  19. Feb 8, 2025 at 7:09 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    If it's an automatic, I would add a transmission fluid drain and fill to your list. If it has lived a hard life (towing, hot enviroment location) maybe a pan removal and new filter. Repeat the drain and fill every 50,000 miles thereafter, but leave out the pan drop and filter change
    until you hit 300,000. :thumbsup: :proposetoast:
  20. Feb 9, 2025 at 1:37 PM
    gotoman1969
    I’m down in SA.
