about to place my order for OME lift kit
Discussion in 'ToyTec Lifts' started by ross123, Jan 17, 2012.
  1. Jan 17, 2012 at 10:02 PM
    ross123
    ross123 [OP] Well-Known Member
    fort bragg
    i just have one question im ordering the 886 coils because i just put my deposit down on a relentless fab bumper. will i need any spacers to get a full 3" lift with the 886's and a bumper?
  2. Jan 18, 2012 at 9:13 AM
    ToyTec Lifts
    ToyTec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    Nope! 886's will give you the full lift without spacers.
    Let me know if you have any other questions
    Thanks!
    Dylan
  3. Jan 19, 2012 at 9:58 PM
    ross123
    fort bragg
    ok one more question what are the rear shock stone guards?
  4. Jan 20, 2012 at 1:01 PM
    ToyTec Lifts
    Rocky Mountains
    Here ya go
  5. Jan 20, 2012 at 1:11 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I hope you plan on having a winch up there also, 886's are pretty damn stiff. They're made to support 3" of lift with the ARB bumper and a winch. The Relentless plate bumper weighs just over 1/2 of what the ARB bumper weighs (I believe ARB weighs around 180 lbs and Relentless weighs around 100 lbs). Make sure you're getting the correct coils, 886's might be overkill.
  6. Jan 20, 2012 at 4:00 PM
    ross123
    fort bragg
    yeah im buying the warn m8000. still think the 886's are over kill?
  7. Jan 20, 2012 at 4:42 PM
    Pugga
    Massachusetts
    F-150 Mod
    I think you're officially in that 'gray area' :)
    Lighter plate bumper but a winch. With steel line you're probably better off with the 886, with synthetic line you'll be further into that gray area.
    I'm kind of surprised the Toytec guys didn't mention anything about this earlier but hopefully either they or someone who's running your set-up can chime in with their input. You might want to look through the Relentless Fab sub-forum, I'm sure someone is running the same or a similar set-up as you.
  8. Jan 20, 2012 at 4:47 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    I ordered my OME with the 885s I also ordered an Elite bumper 105-110lbs and a VR1000 winch.
    I also ordered from Toytech when i told them about my situation because I'm a reg cab they said with a bumper and winch the 885s will be fine because I already weigh less than the AC and DC.
    What truck do you have? The cab style will help influence your decision as well.
  9. Jan 20, 2012 at 5:09 PM
    ross123
    fort bragg
    i got a double cab
  10. Jan 20, 2012 at 5:15 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    I would say go with the 886s the bumper and winch should be enough weight along with
    the DC so keep the ride fairly normal don't quote me I'm just going off of what was explained to me by Toytech
  11. Jan 20, 2012 at 5:20 PM
    ross123
    fort bragg
    yeah thats what i was thinking. ill wait alittle bit and see if anyone else chimes in. i have plenty of time to order. my bumper wont be ready for a couple months anyways.
  12. Jan 20, 2012 at 5:23 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    im in the same bumper wait boat.
  13. Jan 30, 2012 at 10:59 PM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Some good info here. So theoretically, with a DCLB 4x4, relentless type of front bumper, winch, ATO skids and sliders, you would definitely go with 886s?
  14. Jan 30, 2012 at 11:16 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I would
  15. Jan 30, 2012 at 11:51 PM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Yes
  16. Feb 3, 2012 at 11:12 PM
    penguins_cc
    Will
    Bellevue, WA
    Thanks Oz and Mitch. For once I came on the site and realized I could spend LESS $$ than I intended to spend when I originally logged on to the site. I think OMEs will work better for my style of wheeling and where I live than the lift I had originally settled on.
  17. Feb 4, 2012 at 8:42 AM
    Mitch
    Mitch
    Spokane, WA
    No problem. Now you just have to find the right place to order from.
  18. Feb 8, 2012 at 9:32 PM
    MonkeyChief
    MonkeyChief Mr. Magoo
    Citizen #1839-7634-001
    In the desert, by the beach, under the mountains
    2012, DCSB, 4x4, TRD Sport (for the skewp)
    884, OME shocks 4 corners, no badges / decals
    I can't comment on the 886 specifically as I am running a smaller lift, but as far as the OME setup, the ride is great all around on road, definitely a huge improvement over stock, which was pretty sloppy.
  19. Feb 8, 2012 at 9:35 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    are you running with the sway bar on or off?
  20. Mar 14, 2012 at 11:44 AM
    jkirkpatrick
    jkirkpatrick Well-Known Member
    Edmonton
    2000, build thread soon
    Stealth sub box, total stereo overhaul, 883 OME with Nitros, Dakars, All Pro bumper, Engo 10,000lb winch w/ synthetic line, ARB rear locker, All Pro full skids, All Pro sliders, 7069 Pro Comp with 285/75/16 Duratracs, front sway bar delete, CBI rear bumper, regeared 4.88
    Dylan - PM sent!
