About to pull the trigger on a 2020, looking for advice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fzj80 guy, Apr 17, 2020.
  1. Apr 17, 2020 at 2:01 PM
    Fzj80 guy
    Fzj80 guy [OP] Member
    I'm about to purchase a 2020 TRD Off Road. I'm leaning toward a manual transmission, due to what I have read on here about the automatics. Am I wrong? Or has Toyota solved the previous AT problems for 2020? I look forward to the feedback. Thanks!!
    Mopar Mussel likes this.
  2. Apr 17, 2020 at 2:04 PM
    Couesfanatic
    Couesfanatic Well-Known Member
    Go drive an auto first, it's not that bad
  3. Apr 17, 2020 at 2:06 PM
    TacoTime850
    TacoTime850 Always Maybe Sometimes Never
    Everywhere and Nowhere
    2019 DCSB 4x4
    2.5” lift, Fox 2.5 ext tvl adjustable w/ DSC, SPC adjustable UCAs, Icon RXT leaf pack, Superbump stops, 17x9 Fuel Podium Bronze wheels, 285/70/17 Cooper STT Pro
    Solved, and welcome to TW!! :cheers:
  4. Apr 17, 2020 at 2:09 PM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    I am a MT fan, almost every vehicle I have owned has been MT, for the taco I went with an AT so I could be lazy (offroading and in traffic). No issues with my transmission. It hunts a bit but it doesn't bother me. Do an extended test drive (overnight if you can) and see what you think of it.
    Note - I have heavy 33" tires so my truck hunts for gears more than a stock truck and it still doesn't bother me but everyone and their acceptance levels are different. Good luck with your purchase/new truck.
    Edit - I have a 19
  5. Apr 17, 2020 at 2:13 PM
    ZekeR7
    ZekeR7 Well-Known Member
    2018 TRD Off-Road 4x4 Quicksand
    I have a 2018 AT and don't mind it.
    It is a bit underpowered for a truck due to gearing and tune, but if you are going to mod it (increase weight, tire, etc), you will probably going to regear anyway (unless you don't care for it hunting gears). After re-gearing you may want a tune. Not necessary though.
    Fzj80 guy[OP] likes this.
  6. Apr 17, 2020 at 2:14 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Had a17 automatic zero problems with transmission, it's the gearing and a high rpm engine that makes the transmission work more than it should have to. Have a 19 manual now and it's geared pretty good for the engine. Personally I like the manual better but nothing wrong with the automatic either.
  7. Apr 17, 2020 at 2:16 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Try em! Before you buy em! Unless you know you you want a manual.
    Fzj80 guy[OP] and Blackbeard83 like this.
  8. Apr 17, 2020 at 2:20 PM
    TacoTime850
    2019 DCSB 4x4
    OP, just to be clear, the Tacoma had some updates in 2019 and 2020 to the ECU. The engine feels more powerful and the trans shifts better.
    I own a 2019 and I had a 2020 rental for a week. The 2020 felt even better than my 2019 as far as shifting and felt power. I think they did something extra with the programming in the 2020 models.
    You should probably ask only those that have driven both a 2020 and also a 2016-2019
  9. Apr 17, 2020 at 3:07 PM
    TRDProOne
    TRDProOne Well-Known Member
    CA
    2019 TRD Pro in Super White
    The Aisin AC60F 6-spd automatic slush box is pretty bulletproof. I feel that my 2019 AT shifts just fine.
  10. Apr 17, 2020 at 3:35 PM
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    I have a 2018 TRD OR AT and haven't had any issues with the transmission.. Drive both and then decide which one you like better. Good luck with your decision.
  11. Apr 17, 2020 at 3:41 PM
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    no problems with my 2019 OR AT. The real issue is an underpowered engine with not much torque at the lower end. The gear hunting you mentioned is the transmission trying to compensate for the lack of engine power. With the MT you can control this to your liking and it also comes with a lower geared rear so that helps a bit. I don't think anyone can decide for you. Test drive and decide. Me... if I had it to do over, I'd still go with the AT, especially since a good deal of my driving is in town and I like to eat and drink (soft drinks and coffee) while I drive.
  12. Apr 17, 2020 at 3:44 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    Buy a low milage second gen. Much better vehicle
    jetfishn and AKGSD like this.
  13. Apr 17, 2020 at 3:45 PM
    NickTaco
    NickTaco Well-Known Member
    SF BayArea
    23' TRD OR DCLB 4X4 MGM
    I had a '16 AT for 3 years. A lil bit gear hunting here and there.
    Now own '19 for 8 months, 4k miles. No hunting at all.
  14. Apr 17, 2020 at 4:05 PM
    Blackbeard83
    Blackbeard83 Well-Known Member
    Sam
    Massachusetts
    2020 TRD Sport 4x4 ACLB MBM MT
    currently stock
    I love my MT. But it sounds like the AT has been fixed for the 2019-2020? Like all have said test drive both. I think that will be the only way to really decide what will be best for you.
    Fzj80 guy[OP] and rblalliance like this.
  15. Apr 17, 2020 at 4:11 PM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    The 2020 refresh makes a difference. My 2020 is definitely an improvement over my old 2017.
  16. Apr 17, 2020 at 4:14 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    LOL!
    BSFord, Thegenerik1 and Fzj80 guy[OP] like this.
  17. Apr 17, 2020 at 4:21 PM
    j_gets
    j_gets Active Member
    Idaho Falls, ID
    2020 White TRD Offroad
    I've driven manual trans vehicles for the better part of 3 decades and love my 3rd pedal. I hunted down a MT TRD Offroad at a dealer 30 miles away and after looking at that and an identically specd (apart from trans) AT TRD Offroad on the same lot, I went with the AT.
    For me the decision came down to a few things:
    Smart key entry/exit. This is not available with MT, while the AT comes with it (at least on the TRD OR.) Not having to fumble with keys and being able to just touch the door handle to lock and unlock is super convenient especially when having to wrestle with kids or dogs or bags. While it might sound dumb or petty, after getting used to the convenience of having this on other vehicles it was the primary difference that pushed me to the AT.
    Push-button start. Not as big of a deal as the entry/exit for me, but again a small convenience to not have to worry about digging my keys out of my pocket or satchel.
    Remote start. It's cold in the winter and hot in the summer where I live, and I wanted the ability to easily and cheaply add remote start. Can be done with MT, but is more costly.
    Gas mileage. The AT was rated at slightly better MPG than MT.
    Crawl control also seems like some pretty cool tech - I'll be interested to see how that actually performs but haven't had the opportunity yet on that front.
    I was also a bit concerned about the AT given what I had seen in past reviews and such, but after driving it and after having had it for several weeks now, it has so far been a non-issue for me.
    BSFord, DR TACO, Ramsus and 3 others like this.
  18. Apr 17, 2020 at 4:35 PM
    Fzj80 guy
    Thank you all for the feedback and taking it easy on a Taco rookie. It's much appreciated!! I'm a hardcore Land Cruiser guy and learning about Tacos... I'll give the AT's another look. They are certainly more readily available. I was going to have to order an MT., none in my area.
    I'll be building the OF for an expedition run to Alaska next year, so regearing isn't a problem. Though, learning Tacos is a bit of a learning curve! :)
    Here's a pic of my latest Toyota build...
    I'm sure I'll have many more questions in the future. Thank you for your patience!
    Cheers!
  19. Apr 17, 2020 at 4:55 PM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    I absolutely love driving my 2020 AT Pro. No issues with the transmission from my perspective.
  20. Apr 17, 2020 at 5:05 PM
    Blackbeard83
    Sam
    Massachusetts
    currently stock
    Sweet looking Land Cruiser and I forgot to mention welcome to the forum!
