About to pull the trigger on some 295's, need some advice
Discussion in 'Wheels & Tires' started by Toy Yoda, Jun 13, 2013.
BFG AT KO's or General Grabber AT2's
  1. BFG's
    8 vote(s)
    72.7%
  2. General Grabber AT2
    3 vote(s)
    27.3%
  1. Jun 13, 2013 at 2:18 PM
    Toy Yoda
    Toy Yoda [OP] gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    Okay so I've been running BFG AT KO's for 2 years now in 285/75/16 and i want something a little bigger. My front set up is OME 886's with 5100's at 0" and and ARB bumper with warn 8000lb winch. I dont rub at all with the 285's and never have, most people are shocked when i tell them that theyre 285's because they look so small in the wheel well. im pretty sure im getting like 3.25-3.5" of lift since im a prerunner, but im still a little nervous about the 295's because I dont want to do the CMC at all. Are there any kind of measurements i can take to figure out if theyll rub? as i understand it, the 295's are 33.6-33.8" tall and 11.6" wide, would that small of an increase up from the 285's be a problem? here's a pic of the space i've got. (im not worried about the rear at all)
    edit: gonna go with the grabbers or BFG's again, leaning towards the grabbers because of the price and theyre about half an inch larger than the BFG's. so i might just get 285/75/16 grabber AT2's because theyre a 33.1 where the BFG's are a 32.8, or should i go with the 295's which are a 33.6 or the BFG's which are a 33.2
  2. Jun 13, 2013 at 2:21 PM
    Toy Yoda
    Garrett
    06 DCLB
  3. Jun 13, 2013 at 6:52 PM
    Toy Yoda
    Garrett
    06 DCLB
  4. Jun 13, 2013 at 7:11 PM
    BulletToothTony
    BulletToothTony Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    Go for it. Should work :cool:
  5. Jun 13, 2013 at 7:14 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Jośe
    Woodlandland hills , CA
    Taco
    Lift- king 2.5 with light racing uppers,tc coil bucket gusset, 4 in spindles,timbern bumps all around ,wheelers 3 addaleaf, ato shackle flip kit with 6 inch HD shackles. Armor- tire gate, custom tube bumper, kr fab rear bumper,trail gear wiy 78 in sliders Performance-intake manifold spacer, hps silicone hoses Random stuff- kenwood head unit,b&m t shifter, hood bug deflector, rear dust lights with custom bed bar and hi lift mount.
    You may need todo the Cmc/ plus trimming
  6. Jun 14, 2013 at 5:37 AM
    Toy Yoda
    Garrett
    06 DCLB
    yeah thats what im afraid of, i really want to test fit some 295's on the front but idk if tire shops do that haha, might have to call up a buddy with 295's on his 4runner and get him to let me try his out just to see
  7. Jun 18, 2013 at 9:48 AM
    DevL
    DevL Well-Known Member
    How did you get to understand they are 33.8" x 11.6"? The specs for the BFG 295/75r16 AT KO are listed as 33.2" x 11.5" and the only way to possibly avoid rubbing is to never run a caster correcting UCA with those tires. I'm running a wider tire than your 295 BFG... a 285 Nitto Trail grappler, which is about the same height (just .05" shorter) and the CMC was not an option with replacement UCA.
    And no that is not a typo... that 285 is wider than your 295. The reason tire calculators are worthless.
  8. Jun 18, 2013 at 11:09 AM
    Toy Yoda
    Garrett
    06 DCLB
    The BFG's run small
  9. Jun 24, 2013 at 6:31 AM
    Toy Yoda
    Garrett
    06 DCLB
    bumparooski
  10. Aug 13, 2013 at 5:59 PM
    0LyRunner
    0LyRunner Well-Known Member
    Steven
    DuPont, WA
    2009 PreRunner DCSB
    ProComp ES9000 and ES6000 3' Lift with Rear AAL, 16" Tuff A/T's, with 295/75/R16 BFG A/T KO's, Satoshi TRD Signature Grill, Spyder Halo-Projector Headlights, EZ Down Tailgate, EZ Lift Hood, WeatherTech Floor Liners, Sockmonkey All Black Bed Side Decals & 3RD Brake Light TRD Sticker, Engine Cover Custom Painted, Red Calipers, Undercover Classic, [Plasti-Dipped: Lower Valence, Fog Light Housing, Emblems, Rims], Side Steps, Center Console & Glove Box Divider, Seat belt ding (off).
    I ordered 275/70R16... and those are way too small on a +3" lift.
    Hit up the shop and they are ordering me a bigger size, going with
    the 295/75's. I know trimming will happen and I know I might hit the
    UCA's. Easy fix should be wheel spacers, but I'm also looking into new UCA's
    so if your still needing help, they will be in this weekend I will post pics when
    that happens.
  11. Sep 11, 2013 at 8:51 PM
    0LyRunner
    Steven
    DuPont, WA
    2009 PreRunner DCSB
    I got them on just fine. Trimmed away a little in the front.
    They both stuff in the wheel well really good. Really nice fit.
    I rub the Upper A-Arm but its not big deal. I love the look 100x better.
    Good luck
  12. Sep 11, 2013 at 10:18 PM
    sn0b0rdr
    sn0b0rdr NICK
    Nick
    Gilbert, AZ
    08 Tacoma TRD Sport 4x4
    Icon extended travel coilovers w/ resi's, Camburg UCA's, Total Chaos LCA's, Icon 2.5" rear shocks w/ resi's, Deaver leaf pack, TRD Intake/Exhaust, Hi-Lift jack and mount, oversize spare tire/wheel, LEX custom front bumper, SDHQ Offroad in Gilbert, AZ is where it's at!
    I'm runnin the 295/70/17 Nitto Trail Grapplers with my Icon extended coilovers and Camburg UCA's, They barely rub when I'm fully turned one way or another.
  13. Sep 12, 2013 at 9:34 AM
    mh.meier
    mh.meier PB MIKE Vendor
    MAD MIKE
    Flagstaff AZ
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper(, color matched -Heretic Studios 20" single row light bar -Rigid Dually D2 Flood pods -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -AVID Offroad weld on slider -BAMF Bed corner tie down brackets -Custom chopped front fenders -Front custom satoshi gille, color matched -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Dirt King stock length lowers (soon to be installed) -Sway-A-Way 2.0 rear ext travel shocks -All-pro Expo LEaf packs w/ custom bumps -35" Goodyear Wrangler MTR's w/ Kevlar -16" SCS SR8's in Black -Custom Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    255/85/16
  14. Sep 12, 2013 at 9:41 AM
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    yea that's the way to go.
  15. Sep 12, 2013 at 9:45 AM
    mh.meier
    MAD MIKE
    Flagstaff AZ
    Thats my next. Love my 285 KM2's but I like the benifits of the skinnier/taller tire.
