About to roll over 200,000 miles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BUFU, Apr 11, 2020.
  1. Apr 11, 2020 at 5:37 PM
    BUFU
    BUFU [OP] Member
    2005 White Tacoma
    265/75R16 Falken Wildpeak AT3W, Stealth Custom Series SR8, Fox 2.5 front, Fox 2.0 rear, JBA UCA
    For people who have 2nd gens over 200,000 what should I be preparing for? I've owned the truck since 17x,xxx and I've maintained it well. I've already changed idler pulleys, drive belt, tensioner, alternator, both front wheel bearings and CV axles. I'm getting ready to replace everything suspension/some steering except for the sway bar (coilovers, leaf packs, lower ball joint, both tie rod ends, all bushings, sway bar links, upper control arms.) I love this truck and it's relatively rust free for being a 2005. The frame is in great shape and the engine is running as smoothly as a used 1GR can run. I have a lot more planned for this truck and I also daily it so I do need it. I want to be prepared for deadline situations.
    Should I have an engine gasket kit on hand?
  2. Apr 11, 2020 at 6:02 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Spark plugs, coolant, transmission fluid if it hasn’t been done.
  3. Apr 12, 2020 at 8:13 PM
    zano
    zano Well-Known Member
    south chicago burbs
    2011 TX Bro
    2.25" lift, SPC UCA, Dobinson's C59-314 coils & 500lb leaf packs, Billy 5100's & 5125, Tom Woods 1pc ds, TRD exhaust, OEM black tube steps, Konig Countersteer (FN) wheels, Michelin LTX/AT2's
    I'm at 160k miles and in the same boat. What do higher mileage taco owners recommend replacing? I recently (over the course of a year) replaced water pump, thermostat, radiator hoses, coolant, tensioner pulley, idler pulleys(noisey), spark plugs, clock spring, Tom Woods 1 pc ds, and rebuilt 3rd member (ECGS). Installing suspension & brakes next weekend..Dobinson's C59-314 front coil springs & their medium duty 500-800lb leaf packs, Mevotech supreme UCA's & LCA's, 5100's, calipers, pads, rotors...around $4500 in parts alone but the truck has been rock solid reliable and would like to keep it that way. How long do alternators & starters typically last on our trucks? Mine are original.
  4. Apr 12, 2020 at 8:57 PM
    dustinJ
    dustinJ Taco abuser
    Dustin
    Amarillo tx
    09 dcsb Super white 4x4 sr5.
    Bilstein 5100 at 2.5 inch OME dakars with the big overload removed 265/75/16 on stock wheels 290,000 miles and counting
    Y'all are pretty well covering it. But don't forget front and rear diff lube. Mine has 350k on it and I'm not scared to go anywhere in it. Just regular maintenance and you'll be good. I'm pretty sure I have oe starter and alternator on still but I bought the truck with 220k on it.
    Sugar Silva likes this.
  5. Apr 12, 2020 at 10:16 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    Would do water pump as well, and maybe radiator hoses. Would also do both lower ball joints if you're only doing one.
    It being a 2005 do you know if any head gasket work has been done? You may want to do that too
  6. Apr 13, 2020 at 3:24 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Don’t forget valve cover gasket even if you don’t do the head gasket
  7. Apr 13, 2020 at 3:40 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    My 07 is at 203,000. Prior to 200,000 I replaced the plugs and serpentine belt at 100,000, shocks at 125,000. At 165,000 fluid was replaced in both diffs and the transfer case and a 2nd set of plugs along with a new belt prior to a road trip from GA to the Grand Canyon. A U joint failed on the trip, but Toyota reimbursed me for that cost. The alternator died at about 180,000. The front brakes have been replaced 3 times with the rotors turned twice. I'll need new rotors next time. I've only replaced rear brakes once.
    That's it. I've never replaced the factory AT fluid or coolant. This summer I'll have the coolant and all hoses replaced. Up until 4 years ago I averaged about 20,000 miles/year on it and changed the oil every 10,000. It is driven a lot less now, about 7-8,000 miles each year so I change the oil at 5,000 now.
  8. Apr 13, 2020 at 3:48 AM
    Crosis
    Dunedin Fl
    Do you do a lot of towing or drive hard? 3 sets of pads and two rotor turns seems like a lot. I am at 103k and still on my original pads, shoes rotors and drums.
    BillsSR5 likes this.
  9. Apr 13, 2020 at 6:01 AM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    my orig. alternator lasted to about 425,000 miles
    On my third water pump but this one is lasting the longest, well over 150,000 on it now
    flushed trans every 100,000
    OCI every 10,000
    Front passenger-side wheel bearing replaced around 294,00
    Rear passenger side wheel bearing replaced around 328,000
    Rear drivers side wheel bearing replaced at 439,000 (had to do the rear brakes and did not want it to go and start leaking diff fluid all over the brand new brake shoes, bearing was not showing signs of going bad)
    Fuel pump replaced around 322,000
    front brakes around every 100,000
    replaced front coil overs about every 100,000 miles
    had rear leafs replaced twice I think, both free from toyota
    can't think of another major part I've replaced?
    At 439,000 miles now, I drive almost all highway miles and I bought it brand new back in 07
  10. Apr 13, 2020 at 6:52 AM
    Hikerbox
    Hikerbox Well-Known Member
    2015 SR5 Access Cab
    I'll just add replace your radiator caps - the seals go bad on every vehicle and they can drip coolant into places that make you think you have a real leak. Same goes for gas caps - the emissions system will act screwy if it doesn't seal properly. Ignition coils can also start to go and create a misfire and are worth the hundred bucks to replace every 150k or so.
    UOFan likes this.
  11. Apr 13, 2020 at 2:14 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    About 200k... if the truck has been cared for, just do the regular scheduled maintenance. I wouldn't worry about engine gaskets. Other wear parts that don't have service intervals (u-joints, shocks, etc) will make noise or provide some other indication before they fail.
  12. Apr 13, 2020 at 2:30 PM
    5150Bronco
    5150Bronco Well-Known Member
    Bay Area, Ca.
    2013 Tacoma 4x4 Access Cab-Special Order.
    That’s rad! Congrats! Lol...
    Maybe wheel bearings, but you should be good I would think. If they still fit tight that is...
  13. May 25, 2020 at 10:03 AM
    Ardub 06
    Ardub 06 New Member
    2005 Speedway Blue prerunner
    2” Lift
    I’m at 250k with my 05, if not done yet do wheel bearings and ball joints.....Good pm schedule will save you some headache.
