About to run this thing off a cliff!
Discussion in '1st Gen. Tacomas (1995-2004)' started by CaptSlappy, Feb 7, 2025.
  1. Feb 7, 2025 at 6:44 AM
    CaptSlappy
    CaptSlappy [OP] Member
    04 Pre-Runner
    None
    I will try to make this short. My daughter was driving the 04 Pre-Runner V6 Auto. She call says the truck stopped. I go out took about a half hour to get to her. The truck starts right up i drive it home no issues. Two days later my wife goes to move it out of the driveway and she calls me and said there is no reverse. I get home go out the truck runs and drives perfectly. I take it to work the next day an hour each way no issues. The next day I drive to work again. I am about three miles from work and i lose forward momentum give it some more throttle the RPM's go way up truck will maintain speed but not accelerate much at all. the check engine light comes on and the temp gauge pegged and no reverse. I pull over turn off the truck sit for less than 5 minutes. I start the truck back up no issues except the check engine light, the temp gauge normal and reverse is working. I drive the rest of the way to work no issues. I checked the codes they were 02 sensor codes. I erased the codes and drove home and to work the next couple of day no issues. Third day same thing happened engine light (same codes) temp gauge pegged, no acceleration, and no reverse. I pulled over turned it off started back up immediately no more issues that day. It is very intermittent. I have checked every thing I can think of. I am at my wits end. Can anyone point me in a direction?
    Thank you,
    Slappy
  2. Feb 7, 2025 at 6:50 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    smell the trans fluid & look at condition / color by any chance?
  3. Feb 7, 2025 at 6:51 AM
    Glamisman
    Glamisman Well-Known Member
    While I cant give you a magic bullet fix I can point you to some common things, will they "fix it", maybe.
    On the intake manifold right by the DIAGNOSE plug there is a group of ground wires, these are for most of the computers electronics. Give each wire a wiggle and check for a loose eyelet.
    Has it rained hard recently where you live?
    Black97v6MT and time623 like this.
  4. Feb 7, 2025 at 7:11 AM
    CaptSlappy
    04 Pre-Runner
    None
    Slater* the trans fluid was clean smelled fine. I am meticulous with maintenance. I did however drain and installed a new filter flushed lines and cooler. Thank you.
    Black97v6MT and Steves104x4 like this.
  5. Feb 7, 2025 at 7:12 AM
    CaptSlappy
    04 Pre-Runner
    None
    Glamisman* I will check that. When this first started happening rain was not a factor. Thank you.
  6. Feb 7, 2025 at 7:23 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Definitely sounds electrically controlled. Reminds me of an experiance in a 1988 pickup.
    Although a much simpler year of basics it would intermittantly lack power, act up or often shut down completely, only to restart within a short time or even start up immediately. Felt electrical in nature. Could not find the issue forever. Some days my bi polar beast would be fine. Turned out @ 100k the neg. battery cable had internal corrosion. No visable signs, blue fuzzed or swollen. Once the artirial electrical blockage was removed by transplanting with a free flowing new cable she purred like a kitten with 9 more lives.
    I was once told something that has served me well. An old timer mechanic claimed 90% of electrical issues can be traced back to a bad ground (or resistance). Cold wet weather brings out these gremlins. Another rule that had helped me anyway, I start with all known issue repairs first. Often the mystery issues are related and go away.
    Hope this can help
  7. Feb 7, 2025 at 7:44 AM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    +1 on the Intake Manifold Ground. Left that loose after a spark plug job once and the truck just randomly died on the highway. Took forever on the side of the road to figure out what the hell happened, but it was just that loose ground.
  8. Feb 7, 2025 at 7:48 AM
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    Could be the start of the dreaded A.P.P.S malfunctioning? Maybe multiple issues its an 04
  9. Feb 7, 2025 at 9:17 AM
    CaptSlappy
    04 Pre-Runner
    None
    Not sure what the APPS is. would you mind elaborating?
    Thank you,
    Slappy
  10. Feb 7, 2025 at 9:18 AM
    CaptSlappy
    04 Pre-Runner
    None
    I will give it a look.
    Thank you,
    Slappy
  11. Feb 7, 2025 at 9:19 AM
    Moonrman
    Hill Country, TX
    Accelerator pedal position sensor its on the throttle body.
  12. Feb 7, 2025 at 9:22 AM
    CaptSlappy
    04 Pre-Runner
    None
    Thank you. I have never heard it refered to as the APPS I have always called it a TPS Throttle Position Sensor
    Slappy
  13. Feb 7, 2025 at 9:22 AM
    Moonrman
    Hill Country, TX
    2 different things
  14. Feb 7, 2025 at 9:32 AM
    CaptSlappy
    04 Pre-Runner
    None
    Okay, I'll look into that.
    Thank you,
    Slappy
  15. Feb 7, 2025 at 9:40 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Does the horn work? With the truck idling does the fan belt run smoothly? No strange noises?
  16. Feb 7, 2025 at 9:45 AM
    CaptSlappy
    04 Pre-Runner
    None
    Yes, yes, and no noise
    Thank you,
    Slappy
    Steves104x4[QUOTED] likes this.
  17. Feb 7, 2025 at 9:46 AM
    CaptSlappy
    04 Pre-Runner
    None
    I see it has a sensor on both sides of the throttle body. Thank you.
    Slappy
    Black97v6MT likes this.
  18. Feb 7, 2025 at 9:48 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe make sure someone’s left foot (sorry, other left foot) hasn’t pulled apart some wiring up under the dash
  19. Feb 7, 2025 at 9:53 AM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    I can tell you that I just went through a similar situation with my Nephews 4Runner and I found a couple bad grounded wires under the hood and on the frame under the vehicle. After cleaning up all the grounds and tightening everything up he has not had anymore trouble. Hope this helps.:fingerscrossed:
  20. Feb 7, 2025 at 10:18 AM
    CaptSlappy
    04 Pre-Runner
    None
    Yeah i went under there too
    Thank you,
    Slappy
