About to run this thing off a cliff!
Discussion in '1st Gen. Tacomas (1995-2004)' started by CaptSlappy, Feb 7, 2025.
  1. Feb 7, 2025 at 10:22 AM
    CaptSlappy
    CaptSlappy [OP] Member
    04 Pre-Runner
    None
    Yeah, I've been doing that no luck yet. I've been pulling connectors too checking for corrosion or any sign of water intrusion.
    Thank you,
    Slappy
    TomTwo[QUOTED] likes this.
  2. Feb 7, 2025 at 12:29 PM
    Glamisman
    Glamisman Well-Known Member
    I mentioned rain for 2 reasons, one is corrosion on ground wires, the second is that some tacomas, and non one knows why, will start to leak on the PS area in front of the windshield and there is a possibility of water getting into the PCM .
    There is/was a guy here that chased codes, chased grounds and just plain 'ol had a difficult time. He pulled the PCM and opened it up to find a burned spot on the board. There is no way to diagnose that and as I heard a old timey tech say, show me whats good and ill show you whats bad. I like to eliminate the easy things first even if they are considered out of the norm.
    Steves104x4 likes this.
  3. Feb 7, 2025 at 1:05 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Buggered up ecu, maybe.
  4. Feb 7, 2025 at 1:11 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    These trucks are pretty hard to kill. Make sure it's a VERY tall cliff.
    rocknbil and Moonrman like this.
  5. Feb 7, 2025 at 1:13 PM
    eon_blue
    Azusa, CA
  6. Feb 10, 2025 at 7:19 AM
    CaptSlappy
    04 Pre-Runner
    None
    Thank you,
    Slappy
  7. Feb 10, 2025 at 3:04 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Go unplug the connectors for the ecu. I've seen it where the transmission harness leaks and pushes fluid all the way up to the ecu connectors and intermittently shorts stuff.
