About to submit my order. Tacoma World gets to decide, 265 or 285?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BraskaTaco, Apr 16, 2016.
  1. Apr 16, 2016 at 12:33 PM
    BraskaTaco
    BraskaTaco [OP] Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    Most of my miles are racked up on gravel roads. I take a roadtrip about once a month to either the mountains or rougher terrain. I city drive about 15 miles per day to work M-F. Last year I put roughly 18,000 total miles on my previous SUV.
    What size should I get?? :D
  2. Apr 16, 2016 at 12:41 PM
    JWL
    JWL Well-Known Member
    Jeff
    Greenville, SC
    08 DCSB 4x4 TRDOR
    OME 885, Bilstein 5100, JBA UCAs, 2" Single AAL
    What kind of lift do you have, if any? 265/75/16 and 265/70/17 will fit stock suspension without rubbing but be ready to do some cutting/trimming even with a lift to fit 285s.
    I vote for the 265s though.
    LTZBURNER1296 and MadDaddy like this.
  3. Apr 16, 2016 at 12:42 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
  4. Apr 16, 2016 at 12:42 PM
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    OME's 3" and TC UCA's are on order :) I'm ok with a little trimming, mostly I guess I'm wondering if the mileage hit would be worth it..
  5. Apr 16, 2016 at 12:43 PM
    BlueHeli
    BlueHeli Well-Known Member
    AZ
    2017 Quicksand TRD OFFROAD 6MT
    None
  6. Apr 16, 2016 at 12:43 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    285 because fuck it
  7. Apr 16, 2016 at 12:44 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'd do the 285s then, or 255/85/16 for less frame rub. Only reason j didn't this time around is because my truck has 3.58 axle gears.
  8. Apr 16, 2016 at 12:44 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    265's are fine
    ChadsPride likes this.
  9. Apr 16, 2016 at 12:46 PM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    City mileage for me going from stock 265/60r17 to 265/75r16 was 25% less range. It sucks. I went from 400-420 miles per tank to 290-320 miles per tank. I can only imagine 285s making it substantially worse.
    My fall commute is 75 miles a day M-F. It's gonna KILL me.
    In hindsight, I should've down 255s, honestly.
    1truckdriver likes this.
  10. Apr 16, 2016 at 12:51 PM
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    Maybe a stupid question, but would 285's cause premature wear on the engine itself?
    MadDaddy likes this.
  11. Apr 16, 2016 at 12:57 PM
    Pigpen
    Dan
    Northwest Montana
    255 is the way to go
    Darth_Yota, Kyitty and MadDaddy like this.
  12. Apr 16, 2016 at 12:58 PM
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    Wish duratrac or ko2 were offered in 255..
    Pigpen[QUOTED] likes this.
  13. Apr 16, 2016 at 12:59 PM
    JWL
    Jeff
    Greenville, SC
    08 DCSB 4x4 TRDOR
    Going from 265/70 to 265/75 noticeably dropped my mileage, but not by that much. I definitely won't be going up to 285s but if you like the look and don't mind the mileage difference id say go for it!
  14. Apr 16, 2016 at 1:02 PM
    chiefcrunchy
    chiefcrunchy Well-Known Member
    Brian
    Between North and South Virginia
    '15 DC MGM TRD Sport 4x4 6spd 4.0
    5100s, 885s, deaver AAL, Waiting impatiently to install Demello front bumper, Mobtown sliders & skids, and safari snorkel.
  15. Apr 16, 2016 at 1:04 PM
    Pigpen
    Dan
    Northwest Montana
    Then 285
  16. Apr 16, 2016 at 1:05 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    Go big or go home, 285's!!
  17. Apr 16, 2016 at 1:34 PM
    BlueHeli
    AZ
    None
    Go with a diffefent brand. Dont be afraid to not be brand loyal
    DustStorm4x4 likes this.
  18. Apr 16, 2016 at 1:36 PM
    mrsteve
    mrsteve Well-Known Member
    Leesburg, Virginia
    2012 DC TRD Sport
    I've got 285s KO2s. OME 3" lift. 15mpg...
    MTopp and el_turks like this.
  19. Apr 16, 2016 at 1:51 PM
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    Is that also with size correction?
  20. Apr 16, 2016 at 1:59 PM
    mrsteve
    Leesburg, Virginia
    2012 DC TRD Sport
    It's like a 6% difference, so okay 16 mpg...
