above coil spacer and coilover combo???????
Discussion in 'Suspension' started by Joeymgd78, Dec 12, 2011.
  1. Dec 12, 2011 at 5:13 AM
    Joeymgd78
    Joeymgd78 [OP] Well-Known Member
    Joey
    at the moment Afghanistan
    2008 Tacoma SR5 TRD Offroad 4.0 V6 Double Cab
    this maybe a stupid question and i sorry if it is but im new to this. is it possible to use both a adjustable coilover and a above coil spacer for a higher lift in the front? if it is possible is it a bad idea and why? thank you:confused:
  2. Dec 12, 2011 at 5:25 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Why would you purchase an adjustable coil over and still use a spacer? It's generally a bad idea to stack lifts. Just crank the coil overs up if you want more lift in the front.
  3. Dec 12, 2011 at 5:28 AM
    Joeymgd78
    Joey
    ok thank you for the info
  4. Dec 12, 2011 at 5:29 AM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    More than likely your stock UCA will rub your coils, besides that you most likely would also damage your shocks. If you need more height for tires, cut more or go to a small body lift.
  5. Dec 12, 2011 at 5:31 AM
    Joeymgd78
    Joey
    ok thats the answer i was looking for thank you very much 186000mps now i have to find a place that will ship coilovers to a apo address i have looked everywhere with no luck at all
  6. Dec 12, 2011 at 5:33 AM
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Wesley Chapel, FL
    08 PreRunner SR5 TRD Sport
    Stuff and Things
    since you have a prerunner, why don't you look into getting lift spindles?
  7. Dec 12, 2011 at 5:36 AM
    Joeymgd78
    Joey
    yes i thought about the spindles and no body could tell if they are easy to install. i want to do the lift my self and im no mechanic also i am having a hard time finding spindle lifts
  8. Dec 12, 2011 at 5:38 AM
    FearNothing321
    Tony
    Wesley Chapel, FL
    Stuff and Things
    Total Chaos and Camburg are the two more popular spindle lifts out there
    TC are 3.5" of lift
    Camburg's are 4" of lift
  9. Dec 12, 2011 at 5:41 AM
    Joeymgd78
    Joey
    yeah i looked at the camburgs but how hard is the install on those and if i go 4 in the front how much should i raise it in the back to level it out
  10. Dec 12, 2011 at 5:44 AM
    FearNothing321
    Tony
    Wesley Chapel, FL
    Stuff and Things
    Idk how the install goes, but check out here
    AP Expo springs should level it out (you will also need new rear shocks as well)
  11. Dec 12, 2011 at 5:47 AM
    DreDog
    DreDog Well-Known Member
    Andrew
    Camburg spindles in front. 3 inch leaf pack in the back. That's what I have and it sits level. The leaf pack was bolt on and took like 2 hours. And the spindles are a little more difficult, but are still bolt on and take about 5 hours. Not too bad at all. I did mine by myself
  12. Dec 12, 2011 at 5:58 AM
    Joeymgd78
    Joey
    thanks for the link fearnothing321 its awesome and thanks for all of your help
  13. Dec 12, 2011 at 6:02 AM
    Joeymgd78
    Joey
    dredog does the camburg come with decent instructions did you need any crazy uncommon tools and do you have to be very knowledgable on trucks to do it youreslf and did the spindles come with everything you needed to install them?
  14. Dec 12, 2011 at 6:11 AM
    FearNothing321
    Tony
    Wesley Chapel, FL
    Stuff and Things
    no problem dude :thumbsup:
  15. Dec 12, 2011 at 6:13 AM
    FearNothing321
    Tony
    Wesley Chapel, FL
    Stuff and Things
    It shouldn't be anything out the ordinary, just take your time. You are going to need new U bolts for the rear springs tho
