ABR Twin On Board Air !EXPLOSION!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Freeheelbillie, Dec 3, 2021.
  1. Dec 3, 2021 at 4:39 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Mine be running good. Use it often.
  2. Dec 3, 2021 at 4:43 PM
    Freeheelbillie
    Freeheelbillie [OP] Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    So was mine until today. Was fast running 35s from 12psi back to 40psi too.
    I'll get it figured out one way or the other...but I'm agitated for sure.
    At least it didn't happen on the trial I guess.
    Superdave1.0[QUOTED] likes this.
  3. Dec 3, 2021 at 4:54 PM
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    Did you have the amperage adjusted on the SPOD for the compressor? Not sure if your capable of doing that on them. I’m a switchpro kinda guy myself :D
    Yea I would first check power to the switch, to the compressor, and to the pressure switch. Then check all remaining bolts to see if maybe something popped loose. Then from there just check motors for obvious failure/burns. Check if motors smell toasted as well
  4. Dec 3, 2021 at 4:57 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    What's odd is that when I power up the switch it gains power and "tries" to run normally. In the off position, it runs like 1/2 or less power.
  5. Dec 3, 2021 at 5:04 PM
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    Sound like a pressure switch.
  6. Dec 3, 2021 at 5:06 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Sounds like that's the easier and cost-effective fix.
    Does anyone have the PN?
  7. Dec 3, 2021 at 5:07 PM
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    I don’t. When mine messed up I just contacted ARB direct. Mine was replaced under warranty
  8. Dec 3, 2021 at 5:10 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    Harrop:anonymous:
  9. Dec 3, 2021 at 5:12 PM
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    Harrop for front locker and ARB for air :thumbsup:
    tacotoe[QUOTED] and Superdave1.0 like this.
  10. Dec 3, 2021 at 5:12 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    harrop?
    Edit. Never mind. Got it
    tacotoe[QUOTED] likes this.
  11. Dec 3, 2021 at 5:18 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    I apologize, my reply wasn't helpful. Harrop makes an e-locker. Electronic. It's been awhile since I researched them but believe it's a magnet that engages the drive gear. When I first looked for my 3rd gen they weren't available but they are now.
    I went entirely different direction for off road toy instead. Spent a lot more money too:anonymous:
  12. Dec 3, 2021 at 5:26 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
  13. Dec 3, 2021 at 5:44 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    How is it wired? It sounds like you have a wiring problem as well. Even if a pressure switch fails, if it’s wired correctly you shouldn’t have what you’re experiencing.
    But some compressor manufacturers do give you shit wiring diagrams due to the expense of wiring thing correctly, no idea if ARB is in that category or not. On a side note, I’ve never understood the popularity of this particular compressor, it really is crap compared to alternatives except the size and ease of install.
  14. Dec 3, 2021 at 5:54 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Did your pressure relief valve freeze closed? If there was water present, it would not allow the valve to relieve the excess pressure from the frioze pressure switch.
    Temps near or at freezing temps create wired issues with pnumatics when it comes to mechanical items.
  15. Dec 3, 2021 at 6:09 PM
    #35
    mutely
    pressure switch should cut power before the pressure release valve kicks in. Plus there is no tank on this type of compressor, so probably no pressure release valve that could get frozen. Pressure switch is to protect compressor, pressure valve is to protect tank.
  16. Dec 3, 2021 at 6:10 PM
    #36
    Freeheelbillie
    Billie
    Saint Clair, MI
    It was almost 40 degrees today.
    But this is Michigan, so moisture and freeze-thaw are a fact of life. It taxes the hell out of just about anything mechanical and/or electrical.
  17. Dec 3, 2021 at 6:15 PM
    #37
    Freeheelbillie
    Billie
    Saint Clair, MI
    It's odd as in; More issues than once, all at once, related, or systemic from the failure itself.
    It's popular because of its compact size and ease of install.
    I agree that ARB seems to have let its quality slide over the years...
  18. Dec 3, 2021 at 6:20 PM
    #38
    mutely
    it might not be more than one issue. Let’s say you have a wiring problem, and the compressor runs 1/2 power in the off position. You may only just have noticed that, it could have been running 1/2 power for the last year or so every time you start the vehicle. That would certainly explain the failure. I’m not saying that is the cause, only that the two might be very related.
  19. Dec 3, 2021 at 6:22 PM
    #39
    Freeheelbillie
    Billie
    Saint Clair, MI
    Possible for sure. Electrical gremlins are the worst.
  20. Dec 3, 2021 at 6:32 PM
    #40
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    Was truck running when you used the compressor?
