Abrupt loss of power
Discussion in '1st Gen. Tacomas (1995-2004)' started by keeneaux, Sep 21, 2010.
  1. Oct 6, 2010 at 9:08 PM
    Gundy315
    Gundy315 Well-Known Member
    Houston
    06 PreRunner DC SB
    OME 885, 5100s, 3-leaf AAL, Camburg ball-joint UCAs, Moto Metal 957 (17x9; black), 285/70-17 Kumho KL78, color-matched grille w/ grillcraft mesh upper & lower, All-Pro rear bumper, Leather Seats, WeatherTech mats, JVC DDIN H/U (w/ BT, & Sat), Pioneer 6.5" comps, 500w amp & 10" sub,
    Don't listen to this guy. He likes SLOW veedubs. :D
  2. Oct 6, 2010 at 9:14 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I had a similar problem with my '97 4Runner. It turned out to be a dirty mass airflow sensor. They are delicate so don't touch them. Buy a can of MAS cleaner and follow the directions. Worth a try and cheap.
    BTW- If you are going to blow holes in your block fill the valve covers with 40 pounds of tannerite and shoot them with a 36-06. Take videos for us please.
  3. Oct 7, 2010 at 6:19 AM
    vegetopia
    vegetopia newbie
    Jamie
    Houston
    08 DCSB TRDOR 4x4 MANUAL
    2008 Toyota Tacoma 4x4 TRD Off Road SR5 Double Cab 6.0L 6MT
    :eek:
  4. Oct 7, 2010 at 6:54 PM
    keeneaux
    keeneaux [OP] Member
    Louisiana
    04 PreRunner SR5 3.4l V-6
    Well... since I have been using the non-ethanol fuel, my truck has been running like the trusty Toyota it is!!!! It hasn't burped, coughed , or farted! I am considering running the ethanol enriched fuel, maybe 5gal. worth, just to confirm the fuel was indeed the culprit. And just in case anybody isn't aware of this, ethanol will actually absorb moisture out of the air, which in turn, contaminates the fuel tank itself. Knayrb, nothing gets by you, does it? LOL
  5. Oct 7, 2010 at 7:37 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    were you running e85?
  6. Oct 8, 2010 at 4:38 AM
    keeneaux
    Louisiana
    I had been using super unleaded which is 93 octane.
  7. Oct 8, 2010 at 8:30 AM
    borderbrat
    Jeremy
    Victoria BC, Canada
    hmm that is strange. Did you always fill up at the same station before you switched? I could understand shitty performance if you were mistakenly running E85 but not premium. It has the less ethanol than lower octanes.
  8. Nov 19, 2013 at 4:55 AM
    OCAT T5I
    OCAT T5I Member
    Robert
    Raleigh, NC
    97 4wd V6 LX 5-speed
    Having the exact same problem with my 97 taco 3.4. Gonna have to find a non-ethanol station and give this a try. It's just weird because I fill up at the same station for the last 5 months and just now starting to do this... We shall see.
  9. Nov 20, 2013 at 10:12 AM
    keeneaux
    Louisiana
    IT isn't the ethanol. Turns out, the waterpump had coolant weeping out of tattle-tail hole, which would drip onto the crank position sensor terminal. The corrosion was cleaned off, and problem went away. Apparently, the corrosion changed the resistance on the crank position sensor, which caused the problem on my truck. I hope this helps your plight!
  10. Nov 21, 2013 at 4:07 AM
    OCAT T5I
    OCAT T5I Member
    Robert
    Raleigh, NC
    Thanks! I'll have to check that out this weekend. What do you mean by tattle tail hole? Never heard of that part on the pump, haha. It is almost time for a timing/pump replace but I was hoping to wait till at least another year or till 180k miles.
  11. Nov 22, 2013 at 4:13 AM
    keeneaux
    Louisiana
    The weep hole.
  12. Nov 26, 2013 at 7:29 AM
    CrunchyTaco99
    CrunchyTaco99 Well-Known Member
    Joe
    North Georgia
    99 TRD Tacoma
    33x12.50 Pro Comp M/T's All-Pro Coils, UCA and 3" leafs.
    Any chance you can take a photo or describe that part that was corroded? Little clipped wire right below the pump? I couldn't really find anything. Did you have to pull parts off? How did you find this problem?
    Thanks!
  13. Nov 26, 2013 at 7:51 AM
    BamaToy1997
    Bill
    Navarre, FL
    Wow. Interesting failure to say the least. I have seen some strange things before. I am honestly surprised that a code did not set, because most DTC diagnostics include sudden, erratic signals. Glad that you found the problem! I see it originally was happening back in 2010!
  14. Nov 27, 2013 at 4:12 AM
    keeneaux
    Louisiana
    I personally did not find it. I have a Toyota mechanic that does work on the side. The timing belt was due to be changed, so I was going to have him change the water pump while, while he was there, along with the front crank seal. He is the one who told me what he found. That is the best answer, that I can give you, as I never looked at the corroded crank position sensor he described to me.
  15. Nov 27, 2013 at 10:51 AM
    #35
    CrunchyTaco99
    Joe
    North Georgia
    99 TRD Tacoma
    Ok, thanks. I will take a look.
  16. Nov 27, 2013 at 10:12 PM
    #36
    lunch box
    lunch box diesel mechanic
    2000 trd tacoma
    diff lock grey wire mod k&n77series cold air intake 2nd gen s/c water meth injection 7th injector urd 5100s lift all the way around add a leaf new excedy clutch and rear main seal scan guage 2 wet okole covers.bazooka tube.& some minor body stuff.TRD supercharger,URD 7th injector kit
    methonal is the godsend for detonation ethanol is corn piss thats nothing but hype Ill feed corn to a goat but putting it in my engine just pissis me off.
  17. Oct 3, 2017 at 7:19 PM
    #37
    Taco2525
    Taco2525 Well-Known Member
    Los Angeles
    2009 access cab trd-offroad 4x4
    So I'm having loss of power issue also if going up steep hills in let's say 2nd gear I'll pin it to the floor and Pretty much nothing will happen besides the truck slowly reving down and eventually stalling. Also I'll sit on a slightly elevated hill release the clutch in first instead of crawling steadily like most manuel vehicles it slowly revs down and just about stalls before I press the clutch to prevent the stall I cleaned the maf tried the injector cleaner now I'm trying to figure out what to check next it's got 275/70s
  18. Oct 7, 2017 at 10:37 AM
    #38
    GCBHM
    GCBHM New Member
    Gene
    2004 Prerunner
    You may want to check out the manifold air intake valve. Mine was doing exactly what you described, so I cleaned that valve area really good, and it purred like a kitten.
  19. Aug 17, 2018 at 4:41 PM
    #39
    pappy47630
    pappy47630 New Member
    Joe
    2004 Tacoma
    none
    I had same problem........after changing fuel filter, having fuel system cleaned and new plugs . Still had problem with no faults....
    I decided to clean MAF sensor and when I opened hood I noticed the lid on air filter box was open.
    I replaced filter and closed lid and so far so good.
    Not sure why Toyota did not catch it when I had them do fuel system clean.
    and I believe when I had oil changed a few weeks before fuel system cleaning.
    They opened and did not close it all the way. I noticed the problem the day after oil change
    600 miles from home.
  20. Aug 17, 2018 at 5:10 PM
    #40
    tony2018
    tony2018 Well-Known Member
    torque lite app and bluetooth obd reader comes to mind here.
