ABS and Brake warning light on
Discussion in 'Technical Chat' started by dlee120, Jan 4, 2012.
  1. Jan 4, 2012 at 4:37 PM
    dlee120
    dlee120 [OP] Member
    I saw a couple forums about this but I think mine is a little unique. My ABS warning light and Brake warning light have come on after I had to jump my '07. Any ideas on what would cause this. I'm assuming it's something electrical but not sure how/what to check. Any thoughts?
  2. Jan 4, 2012 at 4:40 PM
    Tacoma Mike
    Southern Maine
    I hope you didn't jump it backwards..... :eek:
    Need to have the codes scanned before anyone can help you...
    Oh Welcome to TW
    Key-Rei likes this.
  3. Jan 4, 2012 at 4:44 PM
    dlee120
    dlee120 [OP] Member
    Thanks for the welcome. I hope I didn't either but thinking back, I might have. F***! Did I fry something?
  4. Jan 4, 2012 at 6:18 PM
    Tacoma Mike
    Southern Maine
    If you did then you very well could have. Unfortunately i did a thread on this when this question was asked.
    I'm not going to scare you "YET" but the results that i had to repair were very expensive.
    You really need to get it scanned and then once you know the results you need a diag procedure to get to the root of the problem.
    It could be as simple as a popped fuse.
    Does your speedo still work ??
    Key-Rei likes this.
  5. Jan 4, 2012 at 6:27 PM
    dlee120
    dlee120 [OP] Member
    The speedo and everything else on the dash works perfectly fine. My brakes are working normally also.
  6. Jan 4, 2012 at 6:36 PM
    Tacoma Mike
    Southern Maine
    That's a good start...... not out of the woods yet.
    Have your fuses checked and scan the whole vehicle for codes.
    A health check by a dealer TIS Techstream machine is perfect for this situation.
    Good luck..
  7. Jan 4, 2012 at 6:39 PM
    dlee120
    dlee120 [OP] Member
    Thank you Mike! I appreciate you sharing your knowledge, thoughts and input.
  8. Jan 5, 2012 at 8:06 PM
    dlee120
    dlee120 [OP] Member
    My right rear wheel sensor went bad according to the vehicle code. Is this something that can be changed relatively easily? I know the part runs close to $200 and wouldn't mind saving on the labor if it's possible for someone with very basic car knowledge to change.
  9. Jan 6, 2012 at 6:07 AM
    disk_55FL
    disk_55FL Well-Known Member
    disk
    Buckeye
    '17 TRD Sport MT
    Do you have anything plugged into your OBDII port ? ( Scangage, etc )
    I had a similar issue.....:rolleyes:
    ilubtimmyhos likes this.
  10. Jan 6, 2012 at 12:59 PM
    Tacoma Mike
    Southern Maine
    Really......Jump start and now a bad WSS.
    Interesting.....
    Yes you can change it.
    It's only one bolt that holds it in. As long as it's not frozen in the housing it will be a 15 min job.
    I will tell you we have had issues with some of the wiring and connectors corroding. So it looks like just a sensor and you pull it apart and the green fuzz stares at ya or you get high resistance in the harness. Cleaning it never seems to work for long so we just end up changing both FYI...
    The only thing that bothers me is this happened just after you jumped it.
    It could be a coincidence.....
    I would hope he cleared the code for you to see if it popped right back on.
    If it's out now then run it for a bit. If it comes back on then you know what you need to do.
  11. Jan 25, 2012 at 1:33 PM
    Tacoma Mike
    Southern Maine
    FWTW.
    Had a 06 taco come in with abs and brake light on.
    Customer had tried to jump the truck backwards.
    Had Left rear wheel speed sensor circuit code.
    Went through diagnostics and the final diag is a bad ABS Actuator.
    Same situation as dlee120.
    I hope he comes back with an update.
    EVERYONE really needs to pay attention while trying to jump a vehicle.
    All it takes is one slip and it's going to cost you thousands of dollars.
    Double check and triple check before you make that final connection.
    Newer vehicles have no margin for error for voltage spikes or rev polarity..
    I really hate seeing stuff like this..... :(
    Key-Rei likes this.
  12. Jan 26, 2012 at 11:16 AM
    dlee120
    dlee120 [OP] Member
    I haven't taken any steps towards correcting my issue other than getting the right rear wheel speed sensor code diagnosed. The ABS no longer works (which doesn't bother me terribly since I felt the ABS was a little too sensitive), which I expected since the panel light came on. As you said Tacoma Mike, the situation you came across sounds just like mine. If it looks like a duck and talks like a duck...it's gotta be a bad ABS actuator. I'm not sure if I'll get this repaired. It sounds as if it will be a costly one.
    I've certainly learned my lesson on taking care to jump a vehicle correctly, no matter how many times I've done it previously.
    Thank you again Tacoma Mike!
  13. Nov 19, 2013 at 8:03 PM
    toddnicc
    toddnicc Member
    2007 stock
    Hey found this thread in searching around...
    Anyone have any input or conclusion?
    I have the exact situation/problem as dlee120 with a 2007 access cab!
    But with rear left wheel sensor code.
  14. Nov 19, 2013 at 8:14 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Did you jump your battery backwards?
  15. Nov 19, 2013 at 8:33 PM
    toddnicc
    toddnicc Member
    2007 stock
    well I wasnt there but apparantely that is what happened
  16. Nov 19, 2013 at 8:40 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    When you replace your sensor check for oil on it. You may have a seal leak which will throw it out again. Also worn bearings will throw the sensors/ abs/ brake/ speedo/ odometer out of whack.
  17. Nov 19, 2013 at 8:46 PM
    toddnicc
    toddnicc Member
    2007 stock
    Have checked all fuses .. and had codes read today after reading through some threads here. I don't have the codes here but they were for a volt spike(which the tech cleared) and a open connection to the left rear speed sensor.
    So he figured it was possibly in the wiring harness connection since he could mess with connection a bit and get the light off...but the code kept showing up after a short time..I don't know exactly how long. Maybe only a few seconds?
    aaaand couldn't test the sensor itself until he was sure the connection was good.
    (read replace harness)
    Said he thought the abs actuator would be a long shot and it was possibly just a coincidence that it came on at the same time as jump...but that seems like a stretch of a coincidence after reading some similar situations here?
  18. Nov 19, 2013 at 8:47 PM
    toddnicc
    toddnicc Member
    2007 stock
    where would oil be coming from at the rear speed sensor?
  19. Nov 19, 2013 at 8:48 PM
    toddnicc
    toddnicc Member
    2007 stock
    thanks for some quick replies btw..wasn't expecting that!
  20. Nov 20, 2013 at 9:21 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    From the rear, either the brakes (wheel cylinder leaking) or from the axle (bad seal).
