ABS and Brake warning light on
Discussion in 'Technical Chat' started by dlee120, Jan 4, 2012.
  1. Apr 21, 2018 at 4:32 PM
    #41
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Oh I know it can be fixed but I'm mad and don't even wanna look at it.
    It's also leaking oil from the timing cover plate.
    Maybe it's finally time to do that V8 swap I've always wanted to do
  2. Apr 21, 2018 at 5:26 PM
    #42
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    I seen lemons and am craving some lemonade
  3. Apr 23, 2018 at 12:47 PM
    #43
    TireFire
    Olympic Peninsula
    @Tacoma Mike
    P0500 vehicle speed sensor...
    Did I mention odometer and trip meter stopped running also?
    And I found out the terminal under the 10amp AC fuse in the engine compartment doesn't have power but all the other fuses and relays are good and have power. Could that be why my HVAC is dead? The only thing working is the recirculating button's LED...
  4. Apr 23, 2018 at 4:59 PM
    #44
    TireFire
    Olympic Peninsula
    Can anyone post or email me the electrical diagram for a 07 V6 4x4 auto SR5 plz? I cannot find it.
  5. Apr 23, 2018 at 6:23 PM
    #45
    Tacoma Mike
    Southern Maine
    Speedo runs through the abs.
    I would have to see the schematic for flow but iirc the dead fuse, could be for the mag clutch. So that’s after the head unit. I maybe wrong but I can’t remember all this shit..
  6. Apr 23, 2018 at 7:43 PM
    #46
    TireFire
    Olympic Peninsula
    So you're saying that code could still mean my ABS actuator is the culprit?
  7. Apr 24, 2018 at 2:47 AM
    #47
    Tacoma Mike
    Southern Maine
    What I’m saying is you need to get the abs squared away.
    Phantom codes are the nightmare of techs.
    The ecu doesn’t see that speed signal it may throw it.
    I’ve seen all sorts of variations of codes and lights.
    Get that thing scanned. You can’t avoid it.....
    All you are doing it guessing right now..
  8. Apr 24, 2018 at 5:29 PM
    #48
    TireFire
    Olympic Peninsula
    Dropped it off at my trusted shop (owner was Toyota tech) and apparently it died when they drove it into their garage. Well this crap started Saturday and I had the truck on a trickle charger till Sunday and have since driven the truck maybe 50 miles total over a few days. They said the kickpanel fuse box is dead and not putting out a signal to the alternator. Weird timing: I barely unclipped a few plugs and unbolted the guy so I can plug in the towing converter behind it. And my fairly new (fabricated and installed in December) AGM battery is at 12.3V
    Trying to find the part now apparently the dealer quoted them $900 for the fuse box. F that. I can't find the part number. 07 V6 4x4 automatic SR5 dbl cab
  9. Apr 24, 2018 at 5:40 PM
    #49
    Tacoma Mike
    Southern Maine
    Sometimes it doesn’t take much.
    Like shorting something out. All circuit boards and computer stuff in those things.
    On a good note.
    It could take care of everything....
    Still wish they could have gotten codes,out of it ...
  10. Apr 24, 2018 at 5:53 PM
    #50
    TireFire
    Olympic Peninsula
    Actually I forgot to mention that I also installed a Add A Fuse to power my compass and temp mirror and I used the accessory circuit but pretty sure that was after the ABS lights and all that jazz happened
  11. Apr 25, 2018 at 9:26 AM
    #51
    TireFire
    Olympic Peninsula
    Well, I did get the code myself: P0500 vehicle speed sensor...
    I'm at a wrecker now getting a new cabin fuse box for 40 bones so I don't have to pay the stealership $900.
    How do you test the vehicle speed sensor to rule it out?
  12. Apr 28, 2018 at 1:56 PM
    #52
    TireFire
    Olympic Peninsula
    It did take care of everything. Mechanic Replaced the cabin fuse box with one I found at the junkyard at it fixed all the issues I experienced
  13. Apr 28, 2018 at 2:06 PM
    #53
    Tacoma Mike
    Southern Maine
    Great news. That’s why you never jump to conclusions even it lights are on.
    It’s always something. Lol
    Key-Rei and TireFire[QUOTED] like this.
  14. Apr 29, 2018 at 9:54 AM
    #54
    TireFire
    Olympic Peninsula
    Yep, thanks for your pointed advice!
    Tacoma Mike[QUOTED] likes this.
  15. Sep 12, 2018 at 4:59 AM
    #55
    ilubtimmyhos
    ilubtimmyhos Brewer
    Adam
    Haymarket, VA
    2012 Blue Tacoma 4x4 Pre-Runner
    4x4 Conversion w/ FJ T-Case, King 2.5 Extended Travel Coilovers w/ JBA UCAs, King 12" 2.0 Smoothies w/ BAMF relocate in the rear, OME Dakar leaf pack, 4.56 gears w/ ARB air locker, Archive Hammer Hangers w/ crossbar brace, ARB Snorkel, Custom Bed cap w/ Roofnest Sparrow XL, Retrofit Headlights, Wrapped in 3M Satin Perfect Blue
    I know this is old, but I have this issue. Only when my UltraGuage is plugged in. Did you end up figuring it out?
  16. Feb 14, 2021 at 6:22 PM
    #56
    Tacoma in Tacoma
    Tacoma in Tacoma New Member
    Scrolled through this thread quickly, only because I didn’t see anyone else posted this, make sure your rear differential lock button is off, fixed it for me, cheers
  17. Sep 25, 2022 at 8:11 PM
    #57
    smokindave
    smokindave Member
    Dave
    Bakersfield
    05 Tacoma Dbl cab TRD
    No mods yet. My 4th Toyota, but my 1st TRD 2WD, all others have been lifted 4WD
    I am having a similar issue. My ABS/Brake light just lit up this week and my RPM gauge is not working now, but when I get in my truck the gauge makes a grinding sound before I start my truck. I am changing front and rear brakes this week because it is time to. Just wanting to know if anyone has had the same issue before.
  18. Oct 28, 2022 at 10:33 AM
    #58
    Kirk36
    Kirk36 New Member
    2007 Blue Tacoma TRD offroad
    I have the same thing going on with mine except I didn't jump my off. Got in it this morning to go to work. Looked at my dashboard and my brake light and ABS lights were on. Any suggestions
  19. Oct 28, 2022 at 12:22 PM
    #59
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    check your fluid reservoir level. There is a low level sensor in it. If it is low, check for leaks and for worn brake pads.
    Dm93 likes this.
