ABS and LSD lights on dash
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4banger5spd, Aug 20, 2014.
  1. Aug 20, 2014 at 7:57 AM
    4banger5spd
    4banger5spd [OP] Member
    rock wood ontario
    2.7l 5spd manual 4x4 cab and a half
    Started my truck yesterday and both the LSD and ABS light came on. There not flashing just stay lit while im driving.
    Anyone with more knowledge than me have an idea on where to start without taking it to the dealer?
    Thanks
  2. Aug 20, 2014 at 7:59 AM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    ABS wheel speed sensor, most likely.
  3. Aug 20, 2014 at 8:13 AM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Wheel speed sensors are actually pretty easy to diagnose if you have a digital meter. Remove the plug, put your meter on it, turn the wheel. You should get around 200mv if I recall correctly. I did it on my son's ZR2. On those, rust under the surface where the sensor mounts was enough to drop the voltage enough to trigger the light. I cleaned the surface with a file, remounted it, and was good to go. There is a reluctor wheel inside the hub assembly, distance to the sensor is critical. Again, my experience is with a GM, but I assume that it would be the same.
  4. Aug 20, 2014 at 5:38 PM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    I would check the fuses first. If I remember correctly ABS1 will light abs and traction control, ABS2 will light abs, traction control and brake lights.
